(Interrupt throttling) happens on the smaller block sizes; anything up to 8-16KiB. I'm now thinking it is this throttling that might be hampering the performance with those small block sizes, as for the larger block sizes the performance is comparable to when power management is set to performance. Is there a way to circumvent the throttling other than changing the power mngmt setting to test this hypothesis? I'm hoping I'd be able to have power management set balanced and still have the higher performing log devices (total power draw goes up from ~140W to ~250W on idle)...
root@titan:~ # smartctl -a /dev/nvme0 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p6 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Number: INTEL SSDPEL1K100GA Serial Number: PHKM034100FX100D Firmware Version: E2010485 PCI Vendor/Subsystem ID: 0x8086 IEEE OUI Identifier: 0x5cd2e4 Controller ID: 0 NVMe Version: <1.2 Number of Namespaces: 1 Namespace 1 Size/Capacity: 100,030,242,816 [100 GB] Namespace 1 Formatted LBA Size: 512 Namespace 1 IEEE EUI-64: 5cd2e4 b6f07b0100 Local Time is: Mon Jul 26 16:14:19 2021 AEST Firmware Updates (0x02): 1 Slot Optional Admin Commands (0x0007): Security Format Frmw_DL Optional NVM Commands (0x0006): Wr_Unc DS_Mngmt Log Page Attributes (0x0a): Cmd_Eff_Lg Telmtry_Lg Maximum Data Transfer Size: 32 Pages Supported Power States St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat 0 + 10.00W - - 0 0 0 0 0 0 Supported LBA Sizes (NSID 0x1) Id Fmt Data Metadt Rel_Perf 0 + 512 0 2 1 - 512 8 2 2 - 512 16 2 3 - 4096 0 0 4 - 4096 8 0 5 - 4096 64 0 6 - 4096 128 0 === START OF SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED SMART/Health Information (NVMe Log 0x02) Critical Warning: 0x00 Temperature: 43 Celsius Available Spare: 100% Available Spare Threshold: 0% Percentage Used: 0% Data Units Read: 6 [3.07 MB] Data Units Written: 17,507 [8.96 GB] Host Read Commands: 280 Host Write Commands: 416,250 Controller Busy Time: 0 Power Cycles: 4 Power On Hours: 0 Unsafe Shutdowns: 0 Media and Data Integrity Errors: 0 Error Information Log Entries: 0 Error Information (NVMe Log 0x01, 16 of 64 entries) No Errors Logged
root@titan:~ # diskinfo -wS /dev/nvd0 /dev/nvd0 512 # sectorsize 100030242816 # mediasize in bytes (93G) 195371568 # mediasize in sectors 0 # stripesize 0 # stripeoffset INTEL SSDPEL1K100GA # Disk descr. PHKM034100FX100D # Disk ident. Yes # TRIM/UNMAP support 0 # Rotation rate in RPM Synchronous random writes: 0.5 kbytes: 19.6 usec/IO = 24.9 Mbytes/s 1 kbytes: 16.7 usec/IO = 58.6 Mbytes/s 2 kbytes: 17.3 usec/IO = 112.7 Mbytes/s 4 kbytes: 13.4 usec/IO = 290.5 Mbytes/s 8 kbytes: 19.0 usec/IO = 411.8 Mbytes/s 16 kbytes: 27.7 usec/IO = 564.5 Mbytes/s 32 kbytes: 43.4 usec/IO = 720.1 Mbytes/s 64 kbytes: 74.8 usec/IO = 835.3 Mbytes/s 128 kbytes: 148.1 usec/IO = 844.0 Mbytes/s 256 kbytes: 285.2 usec/IO = 876.6 Mbytes/s 512 kbytes: 516.2 usec/IO = 968.7 Mbytes/s 1024 kbytes: 971.7 usec/IO = 1029.1 Mbytes/s 2048 kbytes: 1878.6 usec/IO = 1064.6 Mbytes/s 4096 kbytes: 3702.5 usec/IO = 1080.4 Mbytes/s 8192 kbytes: 7344.9 usec/IO = 1089.2 Mbytes/s
Synchronous random writes: 0.5 kbytes: 16.2 usec/IO = 30.2 Mbytes/s 1 kbytes: 16.5 usec/IO = 59.3 Mbytes/s 2 kbytes: 17.1 usec/IO = 114.5 Mbytes/s 4 kbytes: 14.2 usec/IO = 275.3 Mbytes/s 8 kbytes: 17.6 usec/IO = 442.7 Mbytes/s 16 kbytes: 26.7 usec/IO = 585.7 Mbytes/s 32 kbytes: 42.5 usec/IO = 735.5 Mbytes/s 64 kbytes: 74.8 usec/IO = 836.1 Mbytes/s 128 kbytes: 148.7 usec/IO = 840.6 Mbytes/s 256 kbytes: 282.9 usec/IO = 883.8 Mbytes/s 512 kbytes: 514.8 usec/IO = 971.3 Mbytes/s 1024 kbytes: 967.6 usec/IO = 1033.4 Mbytes/s 2048 kbytes: 1883.4 usec/IO = 1061.9 Mbytes/s 4096 kbytes: 3703.2 usec/IO = 1080.2 Mbytes/s 8192 kbytes: 7340.4 usec/IO = 1089.9 Mbytes/s
intelmas start -intelssd 0 -nvmeformat LBAformat = 3
root@titan:~ # diskinfo -wS /dev/nvd0 /dev/nvd0 4096 # sectorsize 100030242816 # mediasize in bytes (93G) 24421446 # mediasize in sectors 0 # stripesize 0 # stripeoffset INTEL SSDPEL1K100GA # Disk descr. PHKM034100FX100D # Disk ident. Yes # TRIM/UNMAP support 0 # Rotation rate in RPM Synchronous random writes: 4 kbytes: 13.1 usec/IO = 298.6 Mbytes/s 8 kbytes: 17.1 usec/IO = 456.2 Mbytes/s 16 kbytes: 27.6 usec/IO = 565.7 Mbytes/s 32 kbytes: 42.5 usec/IO = 735.9 Mbytes/s 64 kbytes: 72.9 usec/IO = 856.9 Mbytes/s 128 kbytes: 135.1 usec/IO = 925.3 Mbytes/s 256 kbytes: 255.5 usec/IO = 978.5 Mbytes/s 512 kbytes: 509.0 usec/IO = 982.4 Mbytes/s 1024 kbytes: 972.2 usec/IO = 1028.6 Mbytes/s 2048 kbytes: 1879.6 usec/IO = 1064.1 Mbytes/s 4096 kbytes: 3693.3 usec/IO = 1083.0 Mbytes/s 8192 kbytes: 7320.3 usec/IO = 1092.8 Mbytes/s
root@titan:~ # gpart show nvd0 => 6 24421435 nvd0 GPT (93G) 6 122 - free - (488K) 128 24421313 1 freebsd-zfs (93G) root@titan:~ # gpart delete -i 1 nvd0 nvd0p1 deleted root@titan:~ # gpart add -i 1 -t freebsd-zfs -a 512k -s 16G nvd0 nvd0p1 added root@titan:~ # gpart show nvd0 => 6 24421435 nvd0 GPT (93G) 6 122 - free - (488K) 128 4194304 1 freebsd-zfs (16G) 4194432 20227009 - free - (77G)
root@truenas[~]# smartctl -a /dev/ada1 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p6 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Micron 5100 Pro / 52x0 / 5300 SSDs Device Model: Micron_5100_MTFDDAK1T9TCC Serial Number: --- LU WWN Device Id: --- Firmware Version: D0MU075 User Capacity: 1,920,383,410,176 bytes [1.92 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: Solid State Device Form Factor: 2.5 inches TRIM Command: Available, deterministic, zeroed Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Tue Aug 3 15:17:26 2021 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 6697) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 14) minutes. Conveyance self-test routine recommended polling time: ( 3) minutes. SCT capabilities: (0x0035) SCT Status supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 100 100 050 Pre-fail Always - 21 5 Reallocated_Sector_Ct 0x0032 100 100 001 Old_age Always - 95 9 Power_On_Hours 0x0032 100 100 001 Old_age Always - 29340 12 Power_Cycle_Count 0x0032 100 100 001 Old_age Always - 71 170 Reserved_Block_Pct 0x0033 100 100 010 Pre-fail Always - 95 171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0 172 Erase_Fail_Count 0x0032 100 100 001 Old_age Always - 0 173 Avg_Block-Erase_Count 0x0032 099 099 000 Old_age Always - 83 174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 55 183 SATA_Int_Downshift_Ct 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0032 100 100 000 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 20 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 123 194 Temperature_Celsius 0x0022 065 059 000 Old_age Always - 35 (Min/Max 17/41) 195 Hardware_ECC_Recovered 0x0032 100 100 000 Old_age Always - 1 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 95 197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 1 199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0 202 Percent_Lifetime_Remain 0x0030 099 099 001 Old_age Offline - 1 206 Write_Error_Rate 0x000e 100 100 000 Old_age Always - 0 246 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 326665288896 247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 10195047722 248 Bckgnd_Program_Page_Cnt 0x0032 100 100 000 Old_age Always - 7222013067 180 Unused_Rsvd_Blk_Cnt_Tot 0x0033 000 000 000 Pre-fail Always - 55014 210 RAIN_Success_Recovered 0x0032 100 100 000 Old_age Always - 1468 211 Integ_Scan_Complete_Cnt 0x0032 100 100 000 Old_age Always - 4 212 Integ_Scan_Folding_Cnt 0x0032 100 100 000 Old_age Always - 2
root@truenas[~]# diskinfo -wS /dev/ada1 /dev/ada1 512 # sectorsize 1920383410176 # mediasize in bytes (1.7T) 3750748848 # mediasize in sectors 4096 # stripesize 0 # stripeoffset 3720981 # Cylinders according to firmware. 16 # Heads according to firmware. 63 # Sectors according to firmware. Micron 5100 MTFDDAK1T9TCC # Disk descr. --- # Disk ident. Yes # TRIM/UNMAP support 0 # Rotation rate in RPM Not_Zoned # Zone Mode Synchronous random writes: 0.5 kbytes: 63.2 usec/IO = 7.7 Mbytes/s 1 kbytes: 63.1 usec/IO = 15.5 Mbytes/s 2 kbytes: 65.5 usec/IO = 29.8 Mbytes/s 4 kbytes: 65.2 usec/IO = 59.9 Mbytes/s 8 kbytes: 72.5 usec/IO = 107.7 Mbytes/s 16 kbytes: 89.3 usec/IO = 175.0 Mbytes/s 32 kbytes: 121.5 usec/IO = 257.2 Mbytes/s 64 kbytes: 185.8 usec/IO = 336.4 Mbytes/s 128 kbytes: 316.6 usec/IO = 394.9 Mbytes/s 256 kbytes: 566.5 usec/IO = 441.3 Mbytes/s 512 kbytes: 1070.2 usec/IO = 467.2 Mbytes/s 1024 kbytes: 2085.4 usec/IO = 479.5 Mbytes/s 2048 kbytes: 4078.0 usec/IO = 490.4 Mbytes/s 4096 kbytes: 8079.1 usec/IO = 495.1 Mbytes/s 8192 kbytes: 15873.4 usec/IO = 504.0 Mbytes/s
root@truenas[/]# smartctl -a /dev/ada4 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Samsung based SSDs Device Model: Samsung SSD 883 DCT 480GB Serial Number: --REDACTED-- LU WWN Device Id: --REDACTED-- Firmware Version: HXT7904Q User Capacity: 480,103,981,056 bytes [480 GB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: Solid State Device Form Factor: 2.5 inches TRIM Command: Available, deterministic, zeroed Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-4 T13/BSR INCITS 529 revision 5 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Aug 19 18:57:47 2021 AEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x53) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 35) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 2 177 Wear_Leveling_Count 0x0013 100 100 005 Pre-fail Always - 0 179 Used_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 0 180 Unused_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 1432 181 Program_Fail_Cnt_Total 0x0032 100 100 010 Old_age Always - 0 182 Erase_Fail_Count_Total 0x0032 100 100 010 Old_age Always - 0 183 Runtime_Bad_Block 0x0013 100 100 010 Pre-fail Always - 0 184 End-to-End_Error 0x0033 100 100 097 Pre-fail Always - 0 187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0032 073 070 000 Old_age Always - 27 194 Temperature_Celsius 0x0022 073 060 000 Old_age Always - 27 (Min/Max 19/30) 195 ECC_Error_Rate 0x001a 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0 199 CRC_Error_Count 0x003e 100 100 000 Old_age Always - 0 202 Exception_Mode_Status 0x0033 100 100 010 Pre-fail Always - 0 235 POR_Recovery_Count 0x0012 100 100 000 Old_age Always - 0 241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 0 242 Total_LBAs_Read 0x0032 099 099 000 Old_age Always - 6301 243 SATA_Downshift_Ct 0x0032 100 100 000 Old_age Always - 0 244 Thermal_Throttle_St 0x0032 100 100 000 Old_age Always - 0 245 Timed_Workld_Media_Wear 0x0032 100 100 000 Old_age Always - 65535 246 Timed_Workld_RdWr_Ratio 0x0032 100 100 000 Old_age Always - 65535 247 Timed_Workld_Timer 0x0032 100 100 000 Old_age Always - 65535 251 NAND_Writes 0x0032 100 100 000 Old_age Always - 0
root@truenas[/]# diskinfo -wS /dev/ada4 /dev/ada4 512 # sectorsize 480103981056 # mediasize in bytes (447G) 937703088 # mediasize in sectors 4096 # stripesize 0 # stripeoffset 930261 # Cylinders according to firmware. 16 # Heads according to firmware. 63 # Sectors according to firmware. Samsung SSD 883 DCT 480GB # Disk descr. --REDACTED-- # Disk ident. Yes # TRIM/UNMAP support 0 # Rotation rate in RPM Not_Zoned # Zone Mode Synchronous random writes: 0.5 kbytes: 41.7 usec/IO = 11.7 Mbytes/s 1 kbytes: 42.5 usec/IO = 23.0 Mbytes/s 2 kbytes: 44.2 usec/IO = 44.2 Mbytes/s 4 kbytes: 47.4 usec/IO = 82.4 Mbytes/s 8 kbytes: 54.4 usec/IO = 143.6 Mbytes/s 16 kbytes: 75.7 usec/IO = 206.3 Mbytes/s 32 kbytes: 108.1 usec/IO = 289.0 Mbytes/s 64 kbytes: 173.0 usec/IO = 361.2 Mbytes/s 128 kbytes: 302.8 usec/IO = 412.8 Mbytes/s 256 kbytes: 571.9 usec/IO = 437.1 Mbytes/s 512 kbytes: 1136.0 usec/IO = 440.2 Mbytes/s 1024 kbytes: 2220.9 usec/IO = 450.3 Mbytes/s 2048 kbytes: 4390.1 usec/IO = 455.6 Mbytes/s 4096 kbytes: 8701.8 usec/IO = 459.7 Mbytes/s 8192 kbytes: 17365.9 usec/IO = 460.7 Mbytes/s
root@truenas[/]# smartctl -a /dev/ada4 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Samsung based SSDs Device Model: Samsung SSD 860 EVO 1TB Serial Number: --REDACTED-- LU WWN Device Id: --REDACTED-- Firmware Version: RVT04B6Q User Capacity: 1,000,204,886,016 bytes [1.00 TB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches TRIM Command: Available, deterministic, zeroed Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-4 T13/BSR INCITS 529 revision 5 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Aug 19 18:02:03 2021 AEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x53) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 85) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 4168 12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 85 177 Wear_Leveling_Count 0x0013 099 099 000 Pre-fail Always - 5 179 Used_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 0 181 Program_Fail_Cnt_Total 0x0032 100 100 010 Old_age Always - 0 182 Erase_Fail_Count_Total 0x0032 100 100 010 Old_age Always - 0 183 Runtime_Bad_Block 0x0013 100 100 010 Pre-fail Always - 0 187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0032 076 057 000 Old_age Always - 24 195 ECC_Error_Rate 0x001a 200 200 000 Old_age Always - 0 199 CRC_Error_Count 0x003e 100 100 000 Old_age Always - 0 235 POR_Recovery_Count 0x0012 099 099 000 Old_age Always - 25 241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 8780283195
root@truenas[/]# diskinfo -wS /dev/ada4 /dev/ada4 512 # sectorsize 1000204886016 # mediasize in bytes (932G) 1953525168 # mediasize in sectors 0 # stripesize 0 # stripeoffset 1938021 # Cylinders according to firmware. 16 # Heads according to firmware. 63 # Sectors according to firmware. Samsung SSD 860 EVO 1TB # Disk descr. --REDACTED-- # Disk ident. Yes # TRIM/UNMAP support 0 # Rotation rate in RPM Not_Zoned # Zone Mode Synchronous random writes: 0.5 kbytes: 669.2 usec/IO = 0.7 Mbytes/s 1 kbytes: 705.6 usec/IO = 1.4 Mbytes/s 2 kbytes: 672.4 usec/IO = 2.9 Mbytes/s 4 kbytes: 670.0 usec/IO = 5.8 Mbytes/s 8 kbytes: 649.8 usec/IO = 12.0 Mbytes/s 16 kbytes: 666.7 usec/IO = 23.4 Mbytes/s 32 kbytes: 736.1 usec/IO = 42.5 Mbytes/s 64 kbytes: 847.5 usec/IO = 73.8 Mbytes/s 128 kbytes: 1098.1 usec/IO = 113.8 Mbytes/s 256 kbytes: 1530.7 usec/IO = 163.3 Mbytes/s 512 kbytes: 1721.0 usec/IO = 290.5 Mbytes/s 1024 kbytes: 2836.5 usec/IO = 352.6 Mbytes/s 2048 kbytes: 5078.4 usec/IO = 393.8 Mbytes/s 4096 kbytes: 9496.4 usec/IO = 421.2 Mbytes/s 8192 kbytes: 17990.0 usec/IO = 444.7 Mbytes/s
root@freenas[~]# smartctl -a /dev/nvme0 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p6 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Number: RMS-200 Serial Number: 0085217 Firmware Version: ae34b8cc PCI Vendor/Subsystem ID: 0x1cc7 IEEE OUI Identifier: 0x00e0cf Controller ID: 0 NVMe Version: <1.2 Number of Namespaces: 1 Namespace 1 Size/Capacity: 8,581,545,984 [8.58 GB] Namespace 1 Utilization: 0 Namespace 1 Formatted LBA Size: 512 Local Time is: Thu Aug 26 21:58:21 2021 PDT Firmware Updates (0x09): 4 Slots, Slot 1 R/O Optional Admin Commands (0x0006): Format Frmw_DL Optional NVM Commands (0x0006): Wr_Unc DS_Mngmt Log Page Attributes (0x01): S/H_per_NS Supported Power States St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat 0 + 25.00W - - 0 0 0 0 100 100 Supported LBA Sizes (NSID 0x1) Id Fmt Data Metadt Rel_Perf 0 - 512 0 3 1 - 512 8 3 2 - 4096 0 0 3 - 4096 8 0 === START OF SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED SMART/Health Information (NVMe Log 0x02) Critical Warning: 0x00 Temperature: 52 Celsius Available Spare: 0% Available Spare Threshold: 0% Percentage Used: 0% Data Units Read: 95,516,794,919 [48.9 PB] Data Units Written: 1,006,800,245,478 [515 PB] Host Read Commands: 1,148,560,059 Host Write Commands: 9,453,074,925 Controller Busy Time: 931,385 Power Cycles: 42 Power On Hours: 22,542 Unsafe Shutdowns: 36 Media and Data Integrity Errors: 0 Error Information Log Entries: 1 Error Information (NVMe Log 0x01, 16 of 63 entries) No Errors Logged root@freenas[~]#
Even Optane would be burning out at that kind of write load I have to imagine.RMS-200 Quick Update, Was going to see if I could be there for when it hit 500pb but missed it by a little
root@waldorf[~]# smartctl -a /dev/nvme0 |less smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Number: RMS-200 Serial Number: 0031867 Firmware Version: ae34b8cc PCI Vendor/Subsystem ID: 0x1cc7 IEEE OUI Identifier: 0x00e0cf Controller ID: 0 NVMe Version: <1.2 Number of Namespaces: 1 Namespace 1 Size/Capacity: 8,581,545,984 [8.58 GB] Namespace 1 Utilization: 0 Namespace 1 Formatted LBA Size: 512 Local Time is: Wed Sep 1 12:27:39 2021 BST Firmware Updates (0x09): 4 Slots, Slot 1 R/O Optional Admin Commands (0x0006): Format Frmw_DL Optional NVM Commands (0x0006): Wr_Unc DS_Mngmt Log Page Attributes (0x01): S/H_per_NS Supported Power States St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat 0 + 25.00W - - 0 0 0 0 100 100 Supported LBA Sizes (NSID 0x1) Id Fmt Data Metadt Rel_Perf 0 - 512 0 3 1 - 512 8 3 2 - 4096 0 0 3 - 4096 8 0 === START OF SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED SMART/Health Information (NVMe Log 0x02) Critical Warning: 0x00 Temperature: 36 Celsius Available Spare: 0% Available Spare Threshold: 0% Percentage Used: 0% Data Units Read: 99,211,764,012 [50.7 PB] Data Units Written: 1,620,540,716,700 [829 PB] Host Read Commands: 455,532,805 Host Write Commands: 309,357,943,886 Controller Busy Time: 377 Power Cycles: 19 Power On Hours: 29,197 Unsafe Shutdowns: 9 Media and Data Integrity Errors: 0 Error Information Log Entries: 0 Error Information (NVMe Log 0x01, 16 of 63 entries) No Errors Logged
root@waldorf[~]# diskinfo -wS /dev/nvd0 /dev/nvd0 512 # sectorsize 8581545984 # mediasize in bytes (8.0G) 16760832 # mediasize in sectors 0 # stripesize 0 # stripeoffset RMS-200 # Disk descr. 0031867 # Disk ident. Yes # TRIM/UNMAP support 0 # Rotation rate in RPM Synchronous random writes: 0.5 kbytes: 23.1 usec/IO = 21.1 Mbytes/s 1 kbytes: 23.7 usec/IO = 41.3 Mbytes/s 2 kbytes: 24.2 usec/IO = 80.6 Mbytes/s 4 kbytes: 24.6 usec/IO = 159.0 Mbytes/s 8 kbytes: 26.0 usec/IO = 300.8 Mbytes/s 16 kbytes: 32.4 usec/IO = 481.8 Mbytes/s 32 kbytes: 40.2 usec/IO = 777.7 Mbytes/s 64 kbytes: 62.5 usec/IO = 999.4 Mbytes/s 128 kbytes: 86.3 usec/IO = 1448.9 Mbytes/s 256 kbytes: 117.4 usec/IO = 2130.0 Mbytes/s 512 kbytes: 197.1 usec/IO = 2536.4 Mbytes/s 1024 kbytes: 345.4 usec/IO = 2895.1 Mbytes/s 2048 kbytes: 652.4 usec/IO = 3065.5 Mbytes/s 4096 kbytes: 1225.1 usec/IO = 3265.1 Mbytes/s 8192 kbytes: 2399.6 usec/IO = 3333.8 Mbytes/s
Wow. I notice that techbuyer have one listed on Ebay UK, as a graphics card!!
Now gone
Apparently the auto-backup to flash functionality is disabled by default, and needs to be re-enabled on every boot. Auto-restore is also disabled by default but at least persists. I've requested access to the code/firmware, might need to go under NDA which will complicate things.
Could you help me with some cli-utilities and/or linux drivers for NV16xx?
Unfortunately, I couldn't find anything usable and downloads from PMC's site are no longer availale (for instance, from the "documentation" tab at http://216.241.235.166/products/storage/flashtec_nvram_drives/nv1616/).
I would be grateful for any information, especially for a source code of utilities and/or drivers (for any OS), etc.
And another RMS-200... Not sure whether the total written is a concern (>800PB)... but got it cheap just to try out. Nothing tuned at all, just threw it into my trusty old HPE Microserver G8;
Code:root@waldorf[~]# smartctl -a /dev/nvme0 |less smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Number: RMS-200 Serial Number: 0031867 Firmware Version: ae34b8cc PCI Vendor/Subsystem ID: 0x1cc7 IEEE OUI Identifier: 0x00e0cf Controller ID: 0 NVMe Version: <1.2 Number of Namespaces: 1 Namespace 1 Size/Capacity: 8,581,545,984 [8.58 GB] Namespace 1 Utilization: 0 Namespace 1 Formatted LBA Size: 512 Local Time is: Wed Sep 1 12:27:39 2021 BST Firmware Updates (0x09): 4 Slots, Slot 1 R/O Optional Admin Commands (0x0006): Format Frmw_DL Optional NVM Commands (0x0006): Wr_Unc DS_Mngmt Log Page Attributes (0x01): S/H_per_NS Supported Power States St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat 0 + 25.00W - - 0 0 0 0 100 100 Supported LBA Sizes (NSID 0x1) Id Fmt Data Metadt Rel_Perf 0 - 512 0 3 1 - 512 8 3 2 - 4096 0 0 3 - 4096 8 0 === START OF SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED SMART/Health Information (NVMe Log 0x02) Critical Warning: 0x00 Temperature: 36 Celsius Available Spare: 0% Available Spare Threshold: 0% Percentage Used: 0% Data Units Read: 99,211,764,012 [50.7 PB] Data Units Written: 1,620,540,716,700 [829 PB] Host Read Commands: 455,532,805 Host Write Commands: 309,357,943,886 Controller Busy Time: 377 Power Cycles: 19 Power On Hours: 29,197 Unsafe Shutdowns: 9 Media and Data Integrity Errors: 0 Error Information Log Entries: 0 Error Information (NVMe Log 0x01, 16 of 63 entries) No Errors Logged
and
Code:root@waldorf[~]# diskinfo -wS /dev/nvd0 /dev/nvd0 512 # sectorsize 8581545984 # mediasize in bytes (8.0G) 16760832 # mediasize in sectors 0 # stripesize 0 # stripeoffset RMS-200 # Disk descr. 0031867 # Disk ident. Yes # TRIM/UNMAP support 0 # Rotation rate in RPM Synchronous random writes: 0.5 kbytes: 23.1 usec/IO = 21.1 Mbytes/s 1 kbytes: 23.7 usec/IO = 41.3 Mbytes/s 2 kbytes: 24.2 usec/IO = 80.6 Mbytes/s 4 kbytes: 24.6 usec/IO = 159.0 Mbytes/s 8 kbytes: 26.0 usec/IO = 300.8 Mbytes/s 16 kbytes: 32.4 usec/IO = 481.8 Mbytes/s 32 kbytes: 40.2 usec/IO = 777.7 Mbytes/s 64 kbytes: 62.5 usec/IO = 999.4 Mbytes/s 128 kbytes: 86.3 usec/IO = 1448.9 Mbytes/s 256 kbytes: 117.4 usec/IO = 2130.0 Mbytes/s 512 kbytes: 197.1 usec/IO = 2536.4 Mbytes/s 1024 kbytes: 345.4 usec/IO = 2895.1 Mbytes/s 2048 kbytes: 652.4 usec/IO = 3065.5 Mbytes/s 4096 kbytes: 1225.1 usec/IO = 3265.1 Mbytes/s 8192 kbytes: 2399.6 usec/IO = 3333.8 Mbytes/s
So up to 256kbytes ahead of @rshakin, thereafter I'm guessing there would be some BIOS tweaking needed. Leaving it alone as it will go into my DL380p next week.
I am wondering how you got it to that speed, but I think my system is set up to handle large files or maybe there is some kind of a tweak in there. What system did you test it on ?
truenas# smartctl -a /dev/nvme0 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Number: RMS-200 Serial Number: 0031867 Firmware Version: ae34b8cc PCI Vendor/Subsystem ID: 0x1cc7 IEEE OUI Identifier: 0x00e0cf Controller ID: 0 NVMe Version: <1.2 Number of Namespaces: 1 Namespace 1 Size/Capacity: 8,581,545,984 [8.58 GB] Namespace 1 Utilization: 0 Namespace 1 Formatted LBA Size: 512 Local Time is: Wed Sep 22 22:40:19 2021 CEST Firmware Updates (0x09): 4 Slots, Slot 1 R/O Optional Admin Commands (0x0006): Format Frmw_DL Optional NVM Commands (0x0006): Wr_Unc DS_Mngmt Log Page Attributes (0x01): S/H_per_NS Supported Power States St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat 0 + 25.00W - - 0 0 0 0 100 100 Supported LBA Sizes (NSID 0x1) Id Fmt Data Metadt Rel_Perf 0 - 512 0 3 1 - 512 8 3 2 - 4096 0 0 3 - 4096 8 0 === START OF SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED SMART/Health Information (NVMe Log 0x02) Critical Warning: 0x00 Temperature: 45 Celsius Available Spare: 0% Available Spare Threshold: 0% Percentage Used: 0% Data Units Read: 99,211,766,494 [50.7 PB] Data Units Written: 1,622,149,164,390 [830 PB] Host Read Commands: 455,533,395 Host Write Commands: 309,372,726,826 Controller Busy Time: 386 Power Cycles: 21 Power On Hours: 29,198 Unsafe Shutdowns: 10 Media and Data Integrity Errors: 0 Error Information Log Entries: 0 Error Information (NVMe Log 0x01, 16 of 63 entries) No Errors Logged
truenas# diskinfo -wS /dev/nvd0 /dev/nvd0 512 # sectorsize 8581545984 # mediasize in bytes (8.0G) 16760832 # mediasize in sectors 0 # stripesize 0 # stripeoffset RMS-200 # Disk descr. 0031867 # Disk ident. Yes # TRIM/UNMAP support 0 # Rotation rate in RPM Synchronous random writes: 0.5 kbytes: 45.3 usec/IO = 10.8 Mbytes/s 1 kbytes: 45.4 usec/IO = 21.5 Mbytes/s 2 kbytes: 49.2 usec/IO = 39.7 Mbytes/s 4 kbytes: 48.3 usec/IO = 80.9 Mbytes/s 8 kbytes: 52.0 usec/IO = 150.2 Mbytes/s 16 kbytes: 60.0 usec/IO = 260.4 Mbytes/s 32 kbytes: 69.9 usec/IO = 447.0 Mbytes/s 64 kbytes: 82.2 usec/IO = 760.0 Mbytes/s 128 kbytes: 151.3 usec/IO = 826.2 Mbytes/s 256 kbytes: 203.2 usec/IO = 1230.5 Mbytes/s 512 kbytes: 239.7 usec/IO = 2086.0 Mbytes/s 1024 kbytes: 358.0 usec/IO = 2792.9 Mbytes/s 2048 kbytes: 589.1 usec/IO = 3395.0 Mbytes/s 4096 kbytes: 1060.2 usec/IO = 3772.9 Mbytes/s 8192 kbytes: 1921.4 usec/IO = 4163.6 Mbytes/s truenas#
# smartctl -a /dev/nvme3 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p7 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Number: MS000400KWDUR Serial Number: Z8W016B3 Firmware Version: HPK4 PCI Vendor ID: 0x1bb1 PCI Vendor Subsystem ID: 0x1590 IEEE OUI Identifier: 0x0004cf Controller ID: 0 NVMe Version: 1.2 Number of Namespaces: 1 Namespace 1 Size/Capacity: 400,088,457,216 [400 GB] Namespace 1 Formatted LBA Size: 4096 Namespace 1 IEEE EUI-64: 19b600 1080cf0400 Local Time is: Tue Oct 19 13:13:05 2021 EDT Firmware Updates (0x02): 1 Slot Optional Admin Commands (0x0006): Format Frmw_DL Optional NVM Commands (0x001f): Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Log Page Attributes (0x03): S/H_per_NS Cmd_Eff_Lg Maximum Data Transfer Size: 64 Pages Warning Comp. Temp. Threshold: 65 Celsius Critical Comp. Temp. Threshold: 70 Celsius Supported Power States St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat 0 + 8.25W - - 0 0 0 0 100 100 1 + 6.00W - - 1 1 1 1 100 100 2 + 4.50W - - 2 2 2 2 100 100 Supported LBA Sizes (NSID 0x1) Id Fmt Data Metadt Rel_Perf 0 + 4096 0 1 1 - 512 0 3 === START OF SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED SMART/Health Information (NVMe Log 0x02) Critical Warning: 0x00 Temperature: 36 Celsius Available Spare: 100% Available Spare Threshold: 20% Percentage Used: 0% Data Units Read: 27,056 [13.8 GB] Data Units Written: 2,059,538 [1.05 TB] Host Read Commands: 114,970 Host Write Commands: 8,455,871 Controller Busy Time: 39 Power Cycles: 24 Power On Hours: 38 Unsafe Shutdowns: 17 Media and Data Integrity Errors: 0 Error Information Log Entries: 3 Warning Comp. Temperature Time: 0 Critical Comp. Temperature Time: 0 Temperature Sensor 1: 36 Celsius Temperature Sensor 2: 67 Celsius Error Information (NVMe Log 0x01, 16 of 64 entries) No Errors Logged
# diskinfo -wS /dev/nvd3 /dev/nvd3 4096 # sectorsize 400088457216 # mediasize in bytes (373G) 97677846 # mediasize in sectors 0 # stripesize 0 # stripeoffset MS000400KWDUR # Disk descr. Z8W016B3 # Disk ident. Yes # TRIM/UNMAP support 0 # Rotation rate in RPM Synchronous random writes: 4 kbytes: 34.7 usec/IO = 112.6 Mbytes/s 8 kbytes: 37.9 usec/IO = 205.9 Mbytes/s 16 kbytes: 43.6 usec/IO = 358.8 Mbytes/s 32 kbytes: 68.4 usec/IO = 457.1 Mbytes/s 64 kbytes: 133.0 usec/IO = 470.0 Mbytes/s 128 kbytes: 264.4 usec/IO = 472.7 Mbytes/s 256 kbytes: 524.6 usec/IO = 476.5 Mbytes/s 512 kbytes: 1045.5 usec/IO = 478.2 Mbytes/s 1024 kbytes: 2072.7 usec/IO = 482.5 Mbytes/s 2048 kbytes: 4122.7 usec/IO = 485.1 Mbytes/s 4096 kbytes: 8288.2 usec/IO = 482.6 Mbytes/s 8192 kbytes: 16455.6 usec/IO = 486.2 Mbytes/s
