Resource icon
SLOG benchmarking and finding the best SLOG
HoneyBadger
Mushroom! Mushroom!
You don't need to forget that 0815 NAND with PLP might be enough for 99% of the home systems postet here.
Spot on. While overkill is fun to benchmark, it's important to build appropriate solutions.
We'd all love to be able to set up all-flash systems with NVDIMM SLOG devices and Optane special vdevs, connected via 40GbE and watch how fast they go - but many organizations and users don't need (or don't want to pay for) that kind of speed, and would be just as well served by a simpler and much less expensive setup.
Part of which is why I'm rather annoyed by the rumblings that Intel is discontinuing consumer-grade Optane devices, outside of the H20 hybrid/QLC model.
The little M10 sticks and the 900p/905p were great for the home-lab and "prosumer" workspace.
Herr_Merlin
Member
Hahah we only have 10G network here. Only the switch uplinks are 40G. Most people tend to forget that small I/O does not equal large network traffic.. looking at all those database clusters it's all small I/O
Not-very-passive-but-aggressive
Not sure if this is a factor of controller overhead or firmware design
Probably both. NAND SSDs have had monstrous amounts of engineering thrown at them to make them fast, which I don't imagine DRAM SSDs got.
Herr_Merlin
Member
Question did anyone tried the Optane DIMMs yet?
Another question - any idea how to pass them to a VM?
I might have a stupid idea for my privat ESXi and TrueNAS all in one box...
Rand
Neophyte Sage
Just got a link to this document the other day: https://lenovopress.com/lp1085-analyzing-the-performance-of-dcpmm-storage-appdirect-mode
They are mixed baggage, fast reads, slower writes. NVDimm-N is significantly faster for writes (as expected).
Edit - some numbers for optane Dimms from https://jira.ixsystems.com/browse/NAS-108510
/dev/pmem0
512 # sectorsize
270582935552 # mediasize in bytes (252G)
528482296 # mediasize in sectors
0 # stripesize
0 # stripeoffset
PMEM region 252GB # Disk descr.
E60A9A2579EB399E # Disk ident.
No # TRIM/UNMAP support
0 # Rotation rate in RPM
I/O command overhead:
time to read 10MB block 0.002218 sec = 0.000 msec/sector
time to read 20480 sectors 0.016406 sec = 0.001 msec/sector
calculated command overhead = 0.001 msec/sector
Seek times:
Full stroke: 250 iter in 0.000500 sec = 0.002 msec
Half stroke: 250 iter in 0.000486 sec = 0.002 msec
Quarter stroke: 500 iter in 0.000997 sec = 0.002 msec
Short forward: 400 iter in 0.000766 sec = 0.002 msec
Short backward: 400 iter in 0.000822 sec = 0.002 msec
Seq outer: 2048 iter in 0.001842 sec = 0.001 msec
Seq inner: 2048 iter in 0.001862 sec = 0.001 msec
Transfer rates:
outside: 102400 kbytes in 0.013630 sec = 7512839 kbytes/sec
middle: 102400 kbytes in 0.013790 sec = 7425671 kbytes/sec
inside: 102400 kbytes in 0.013994 sec = 7317422 kbytes/sec
Asynchronous random reads:
sectorsize: 1425829 ops in 3.000028 sec = 475272 IOPS
4 kbytes: 864612 ops in 3.000029 sec = 288201 IOPS
32 kbytes: 945080 ops in 3.000400 sec = 314985 IOPS
128 kbytes: 164956 ops in 3.002401 sec = 54941 IOPS
Synchronous random writes:
0.5 kbytes: 2.0 usec/IO = 241.0 Mbytes/s
1 kbytes: 2.1 usec/IO = 466.8 Mbytes/s
2 kbytes: 2.3 usec/IO = 848.2 Mbytes/s
4 kbytes: 2.6 usec/IO = 1510.5 Mbytes/s
8 kbytes: 5.1 usec/IO = 1544.3 Mbytes/s
16 kbytes: 10.8 usec/IO = 1452.0 Mbytes/s
32 kbytes: 20.8 usec/IO = 1503.5 Mbytes/s
64 kbytes: 37.7 usec/IO = 1658.9 Mbytes/s
128 kbytes: 79.2 usec/IO = 1577.3 Mbytes/s
256 kbytes: 157.2 usec/IO = 1590.8 Mbytes/s
512 kbytes: 310.1 usec/IO = 1612.5 Mbytes/s
1024 kbytes: 665.0 usec/IO = 1503.7 Mbytes/s
2048 kbytes: 1364.2 usec/IO = 1466.0 Mbytes/s
4096 kbytes: 2800.3 usec/IO = 1428.4 Mbytes/s
8192 kbytes: 5639.6 usec/IO = 1418.5 Mbytes/s
Rand
Neophyte Sage
SS530 Read intensive
smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RELEASE-p3 amd64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
Vendor:               WDC
Product:              WUSTR6416ASS204
Revision:             C925
Compliance:           SPC-5
User Capacity:        1,600,321,314,816 bytes [1.60 TB]
Logical block size:   512 bytes
Physical block size:  4096 bytes
LU is resource provisioned, LBPRZ=1
Rotation Rate:        Solid State Device
Form Factor:          2.5 inches
Logical Unit id:      0x5000cca0ab7483dc
Serial number:
Device type:          disk
Transport protocol:   SAS (SPL-3)
Local Time is:        Sat Feb 13 16:51:23 2021 CET
SMART support is:     Available - device has SMART capability.
SMART support is:     Enabled
Temperature Warning:  Enabled
 512             # sectorsize
        1600321314816   # mediasize in bytes (1.5T)
        3125627568      # mediasize in sectors
        4096            # stripesize
        0               # stripeoffset
        194561          # Cylinders according to firmware.
        255             # Heads according to firmware.
        63              # Sectors according to firmware.
        WDC WUSTR6416ASS204     # Disk descr.
        WXX22G3A        # Disk ident.
        Yes             # TRIM/UNMAP support
        Not_Zoned       # Zone Mode
         0.5 kbytes:    127.5 usec/IO =      3.8 Mbytes/s
           1 kbytes:    128.1 usec/IO =      7.6 Mbytes/s
           2 kbytes:    129.8 usec/IO =     15.0 Mbytes/s
           4 kbytes:    133.0 usec/IO =     29.4 Mbytes/s
           8 kbytes:    141.5 usec/IO =     55.2 Mbytes/s
          16 kbytes:    159.9 usec/IO =     97.7 Mbytes/s
          32 kbytes:    188.1 usec/IO =    166.1 Mbytes/s
          64 kbytes:    253.6 usec/IO =    246.5 Mbytes/s
         128 kbytes:    375.7 usec/IO =    332.7 Mbytes/s
         256 kbytes:    612.4 usec/IO =    408.3 Mbytes/s
         512 kbytes:   1083.0 usec/IO =    461.7 Mbytes/s
        1024 kbytes:   2040.3 usec/IO =    490.1 Mbytes/s
        2048 kbytes:   3942.1 usec/IO =    507.3 Mbytes/s
        4096 kbytes:   7720.6 usec/IO =    518.1 Mbytes/s
        8192 kbytes:  15359.9 usec/IO =    520.8 Mbytes/s
qbix
Neophyte
INTEL D3-S4610 960GB TLC
root@nas[~]# smartctl -a /dev/da0
Model Family:       Intel S4510/S4610/S4500/S4600 Series SSDs
Device Model:       INTEL SSDSC2KG960G801
Serial Number:      BTYG93130G0W960CGN
LU WWN Device Id:   5 5cd2e4 1514d10e3
Firmware Version:   XCV10110
User Capacity:      960,197,124,096 bytes [960 GB]
Sector Sizes:       512 bytes logical, 4096 bytes physical
Device is:          In smartctl database [for details use: -P show]
ATA Version is:     ACS-3 T13/2161-D revision 5
SATA Version is:    SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
root@nas[~]# diskinfo -wS /dev/da0
/dev/da0
        512             # sectorsize
        960197124096    # mediasize in bytes (894G)
        1875385008      # mediasize in sectors
        4096            # stripesize
        0               # stripeoffset
        116737          # Cylinders according to firmware.
        ATA INTEL SSDSC2KG96    # Disk descr.
        BTYG93130G0W960CGN      # Disk ident.
         0.5 kbytes:    115.2 usec/IO =      4.2 Mbytes/s
           1 kbytes:    115.8 usec/IO =      8.4 Mbytes/s
           2 kbytes:    116.9 usec/IO =     16.7 Mbytes/s
           4 kbytes:    116.9 usec/IO =     33.4 Mbytes/s
           8 kbytes:    125.2 usec/IO =     62.4 Mbytes/s
          16 kbytes:    142.5 usec/IO =    109.6 Mbytes/s
          32 kbytes:    178.1 usec/IO =    175.5 Mbytes/s
          64 kbytes:    248.1 usec/IO =    251.9 Mbytes/s
         128 kbytes:    400.5 usec/IO =    312.1 Mbytes/s
         256 kbytes:    664.7 usec/IO =    376.1 Mbytes/s
         512 kbytes:   1193.4 usec/IO =    419.0 Mbytes/s
        1024 kbytes:   2233.4 usec/IO =    447.7 Mbytes/s
        2048 kbytes:   4344.4 usec/IO =    460.4 Mbytes/s
        4096 kbytes:   8619.1 usec/IO =    464.1 Mbytes/s
        8192 kbytes:  16871.2 usec/IO =    474.2 Mbytes/s
douglasg
Newbie
I didn't see the 983 DCT here so here are my results:
root@truenas[~]# smartctl -a /dev/nvme2
Model Number:                       Samsung SSD 983 DCT M.2 960GB
Serial Number:                      S48ENC0N501364K
Firmware Version:                   EDA7602Q
PCI Vendor/Subsystem ID:            0x144d
IEEE OUI Identifier:                0x002538
Total NVM Capacity:                 960,197,124,096 [960 GB]
Unallocated NVM Capacity:           0
Controller ID:                      4
Number of Namespaces:               1
Namespace 1 Size/Capacity:          960,197,124,096 [960 GB]
Namespace 1 Utilization:            227,024,896 [227 MB]
Namespace 1 Formatted LBA Size:     512
Local Time is:                      Thu Mar 25 00:05:12 2021 EDT
Firmware Updates (0x17):            3 Slots, Slot 1 R/O, no Reset required
Optional Admin Commands (0x000f):   Security Format Frmw_DL NS_Mngmt
Optional NVM Commands (0x001f):     Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat
Maximum Data Transfer Size:         512 Pages
Warning  Comp. Temp. Threshold:     86 Celsius
Critical Comp. Temp. Threshold:     87 Celsius
Namespace 1 Features (0x02):        NA_Fields
root@truenas[~]# diskinfo -wS /dev/nvd2
/dev/nvd2
        512             # sectorsize
        0               # stripesize
        0               # stripeoffset
        Samsung SSD 983 DCT M.2 960GB   # Disk descr.
        S48ENC0N501364K # Disk ident.
         0.5 kbytes:     17.5 usec/IO =     28.0 Mbytes/s
           1 kbytes:     17.6 usec/IO =     55.6 Mbytes/s
           2 kbytes:     18.1 usec/IO =    107.9 Mbytes/s
           4 kbytes:     19.0 usec/IO =    205.3 Mbytes/s
           8 kbytes:     21.8 usec/IO =    358.5 Mbytes/s
          16 kbytes:     27.2 usec/IO =    575.0 Mbytes/s
          32 kbytes:     41.2 usec/IO =    759.2 Mbytes/s
          64 kbytes:     70.6 usec/IO =    885.8 Mbytes/s
         128 kbytes:    147.1 usec/IO =    849.5 Mbytes/s
         256 kbytes:    260.2 usec/IO =    960.8 Mbytes/s
         512 kbytes:    459.4 usec/IO =   1088.3 Mbytes/s
        1024 kbytes:    863.5 usec/IO =   1158.1 Mbytes/s
        2048 kbytes:   1667.3 usec/IO =   1199.6 Mbytes/s
        4096 kbytes:   3244.0 usec/IO =   1233.0 Mbytes/s
        8192 kbytes:   6503.6 usec/IO =   1230.1 Mbytes/s
I also had a 950 Pro in my system so here are those results:
root@truenas[~]# smartctl -a /dev/nvme0
Model Number:                       Samsung SSD 950 PRO 512GB
Serial Number:                      S2GMNX0H609029E
Firmware Version:                   1B0QBXX7
Controller ID:                      1
Namespace 1 Size/Capacity:          512,110,190,592 [512 GB]
Namespace 1 Utilization:            104,878,292,992 [104 GB]
Namespace 1 IEEE EUI-64:            002538 5661b053ec
Local Time is:                      Wed Mar 24 23:57:59 2021 EDT
Firmware Updates (0x06):            3 Slots
Optional Admin Commands (0x0007):   Security Format Frmw_DL
Maximum Data Transfer Size:         32 Pages
root@truenas[~]# diskinfo -wS /dev/nvd0
/dev/nvd0
        512             # sectorsize
        512110190592    # mediasize in bytes (477G)
        1000215216      # mediasize in sectors
        0               # stripesize
        0               # stripeoffset
        Samsung SSD 950 PRO 512GB       # Disk descr.
        S2GMNX0H609029E # Disk ident.
         0.5 kbytes:   1675.6 usec/IO =      0.3 Mbytes/s
           1 kbytes:   1692.3 usec/IO =      0.6 Mbytes/s
           2 kbytes:   1663.1 usec/IO =      1.2 Mbytes/s
           4 kbytes:   1740.6 usec/IO =      2.2 Mbytes/s
           8 kbytes:   1616.9 usec/IO =      4.8 Mbytes/s
          16 kbytes:   1842.3 usec/IO =      8.5 Mbytes/s
          32 kbytes:   1887.4 usec/IO =     16.6 Mbytes/s
          64 kbytes:   2178.0 usec/IO =     28.7 Mbytes/s
         128 kbytes:   2759.6 usec/IO =     45.3 Mbytes/s
         256 kbytes:   3612.3 usec/IO =     69.2 Mbytes/s
         512 kbytes:   3644.1 usec/IO =    137.2 Mbytes/s
        1024 kbytes:   3695.2 usec/IO =    270.6 Mbytes/s
        2048 kbytes:   3622.2 usec/IO =    552.1 Mbytes/s
        4096 kbytes:   5484.4 usec/IO =    729.3 Mbytes/s
        8192 kbytes:   8916.5 usec/IO =    897.2 Mbytes/s
Ralms
Junior Member
Sharing the results of a Samsung 960 EVO 250GB
root@freenas[~]# smartctl -a /dev/nvme0
Model Number:                       Samsung SSD 960 EVO 250GB
Serial Number:                      S3ESNX0K298763Z
Firmware Version:                   3B7QCXE7
Total NVM Capacity:                 250,059,350,016 [250 GB]
Controller ID:                      2
Namespace 1 Size/Capacity:          250,059,350,016 [250 GB]
Namespace 1 Utilization:            250,058,170,368 [250 GB]
Namespace 1 IEEE EUI-64:            002538 5281b2d7eb
Local Time is:                      Sun Apr  4 12:29:01 2021 WEST
Firmware Updates (0x16):            3 Slots, no Reset required
Warning  Comp. Temp. Threshold:     77 Celsius
Critical Comp. Temp. Threshold:     79 Celsius
root@freenas[~]# diskinfo -wS /dev/nvd0
/dev/nvd0
        512             # sectorsize
        250059350016    # mediasize in bytes (233G)
        488397168       # mediasize in sectors
        0               # stripesize
        0               # stripeoffset
        Samsung SSD 960 EVO 250GB       # Disk descr.
        S3ESNX0K298763Z # Disk ident.
         0.5 kbytes:    727.9 usec/IO =      0.7 Mbytes/s
           1 kbytes:    695.8 usec/IO =      1.4 Mbytes/s
           2 kbytes:    721.1 usec/IO =      2.7 Mbytes/s
           4 kbytes:    674.6 usec/IO =      5.8 Mbytes/s
           8 kbytes:    725.0 usec/IO =     10.8 Mbytes/s
          16 kbytes:    829.8 usec/IO =     18.8 Mbytes/s
          32 kbytes:    869.4 usec/IO =     35.9 Mbytes/s
          64 kbytes:    818.4 usec/IO =     76.4 Mbytes/s
         128 kbytes:    913.7 usec/IO =    136.8 Mbytes/s
         256 kbytes:   1108.7 usec/IO =    225.5 Mbytes/s
         512 kbytes:   1564.5 usec/IO =    319.6 Mbytes/s
        1024 kbytes:   2257.3 usec/IO =    443.0 Mbytes/s
        2048 kbytes:   3702.2 usec/IO =    540.2 Mbytes/s
        4096 kbytes:   6467.6 usec/IO =    618.5 Mbytes/s
        8192 kbytes:  11691.3 usec/IO =    684.3 Mbytes/s
ehsab
Member
The RMS-300 seems to stand quite good against the Optane NVDIMMs.
Optane NVDIMM
RMS-300
64 kbytes: 45.8 usec/IO = 1363.3 Mbytes/s
128 kbytes: 80.6 usec/IO = 1550.3 Mbytes/s
256 kbytes: 99.0 usec/IO = 2525.0 Mbytes/s
512 kbytes: 147.6 usec/IO = 3388.3 Mbytes/s
1024 kbytes: 256.2 usec/IO = 3902.8 Mbytes/s
Optane NVDIMM looks really fast on small writes, where the RMS-300 performs better with 256K or larger writes.
I assume those Optane numbers are from a block device configuration and not a memory mode configuration, correct?
