spacecabbie
- Aug 20, 2017
Hi all,
Been working with Freenas for about a year now maybe.
I have some questions i saved up:
1. I have 16gb of memory I run Plex / nzbget / sonarr / radarr / transmission / plexpy / webserver (spotnet)
CPU: 0.0% user, 0.0% nice, 0.0% system, 0.0% interrupt, 99.9% idle
Mem: 53M Active, 542M Inact, 505M Laundry, 13G Wired, 1110M Free
ARC: 11G Total, 2551M MFU, 8031M MRU, 29M Anon, 83M Header, 492M Other
9746M Compressed, 11G Uncompressed, 1.16:1 Ratio
Swap: 8192M Total, 1019M Used, 7172M Free, 12% Inuse
This is my load currently.
I am wondering should i start thinking of of more memory 32gb ? (note that 8gb is reserved atm for nothing see question 4.)
2. Jails I now run everything in separate jail, Can this apart from hdd space have a impact on cpu, memory, and power Usage. Instead of running all programs in one jail ?
3. Ssd install I have all my 8 sata ports in use i really like to install a ssd for par and unpacking (run the nzbget jail on that mount) and a Maintenance VM.
I could install a sata card. i prefer not to because of extra power usage. A usb stick could do it but i hear they cannot handle the continue reading and writing ?
So i am thinking a ssd via a usb 3.0 adapter is this viable ?
The Board has:
1 PCI-E 3.0 x8 (in x16),
1 PCI-E 3.0 x8,
2 PCI-E 3.0 x4 (in x8)
So maybe an PCI-E Ssd but i have used a ocd before i was not happy with it is there any PCI-E ssd that can be used in this setting ?
Any other suggestions as always are welcome.
4. I have created a VM with windows 10 on it but it runs horribly slow not sure what's going on maybe related to question 1
Also when i tinker with it and try to improve it when i reboot or change items and it shuts down. This is not a big deal it happens but when restart i get this message below when trying to boot it again.
[2018/07/06 15:24:36] (WARNING) VMService.__init_guest_vmemory():830 - ===> Cannot guarantee memory for guest id: 1
It keeps the memory reserved atm i can only clear it by rebooting freenas.
Is there a way to free up this memory without reboot?
Some additional questions about the vm:
4.1 what os is lightweight but has graphical smb explorer unrar par chrome browser support. It's supposed to be remotely run via teamviewer to do manual tasks connected to programs above it has to be graphical i am not a fan of command line work.
4.1 The vm can it be slow cause i run it on the RAIDZ2 file system ? Task Manager cpu show 100% usage and drive close to 99 at start later around 60-80%.
4.2 I would like to be able to start this vm remotely without having to allow access to freenas web interface.
==Current specs and versions (I am on nightly's atm)===
The Board has:
1 PCI-E 3.0 x8,
OS Version: FreeNAS-11.2-MASTER-201807010447 (Build Date: Jul 1, 2018 7:47) Processor: Intel(R) Xeon(R) CPU E3-1230 v6 @ 3.50GHz (8 cores) Memory: 16 GB Uptime: 5:56PM up 5 days, 1:16, 1 user last pid: 50001; load averages: 0.19, 0.20, 0.17 up 5+01:20:32 18:00:32 78 processes: 1 running, 77 sleeping CPU: 0.1% user, 0.0% nice, 0.0% system, 0.0% interrupt, 99.8% idle Mem: 98M Active, 601M Inact, 486M Laundry, 13G Wired, 945M Free ARC: 11G Total, 2502M MFU, 8076M MRU, 2244K Anon, 82M Header, 491M Other 9754M Compressed, 11G Uncompressed, 1.17:1 Ratio Swap: 8192M Total, 973M Used, 7218M Free, 11% Inuse PID USERNAME THR PRI NICE SIZE RES STATE C TIME WCPU COMMAND 241 root 18 49 0 277M 177M kqread 2 37:53 0.55% python3.6 57429 spacecabbie 21 52 0 447M 148M uwait 5 25:25 0.28% Plex Media Server 6563 spacecabbie 7 20 0 104M 18596K nanslp 7 10:24 0.11% nzbget 57430 spacecabbie 13 52 15 268M 59336K piperd 6 6:08 0.10% Plex Script Host 57522 spacecabbie 14 52 0 341M 127M piperd 5 94:31 0.07% Plex Script Host 49455 root 1 20 0 7956K 4272K CPU0 0 0:00 0.06% top 49437 root 1 20 0 7956K 3856K select 6 0:00 0.05% top 57516 spacecabbie 10 52 0 169M 3872K piperd 2 1:52 0.03% Plex Script Host 7299 spacecabbie 15 20 0 491M 143M uwait 4 16:21 0.02% mono-sgen 7306 spacecabbie 14 20 0 324M 138M uwait 4 20:55 0.01% mono-sgen 2984 www 1 20 0 12856K 2636K kqread 7 0:00 0.01% nginx 44376 root 1 20 0 13252K 8360K select 2 0:00 0.01% sshd 83463 root 1 20 0 176M 20680K select 4 0:01 0.01% smbd 2364 root 1 20 0 12496K 12604K select 4 0:12 0.01% ntpd 57435 spacecabbie 13 52 0 218M 20540K uwait 0 1:23 0.00% Plex DLNA Server 3051 root 1 20 0 135M 4824K kqread 2 0:21 0.00% uwsgi-3.6 3199 root 1 20 0 15668K 4424K select 6 0:11 0.00% httpd 5324 root 1 20 0 10472K 584K select 2 0:00 0.00% syslogd 3179 root 12 20 0 155M 37164K nanslp 3 15:03 0.00% collectd 2043 root 1 -52 r0 3528K 3592K nanslp 7 1:08 0.00% watchdogd 3833 root 15 20 0 183M 62872K umtxn 1 0:08 0.00% uwsgi-3.6 95842 spacecabbie 1 20 0 23588K 0K kqread 0 0:08 0.00% <EasyAudioEncoder> 2039 root 2 20 0 21224K 3204K kqread 3 0:07 0.00% syslog-ng 2571 root 1 20 0 85436K 47608K select 3 0:05 0.00% winbindd 2562 root 1 20 0 37200K 5676K select 4 0:05 0.00% nmbd 2566 root 1 20 0 170M 5556K select 2 0:02 0.00% smbd 351 root 2 21 0 77476K 34704K usem 1 0:02 0.00% python3.6 1183 nobody 1 20 0 7152K 2280K select 3 0:02 0.00% mdnsd 2996 nobody 1 20 0 7152K 2340K select 1 0:02 0.00% mdnsd 350 root 2 20 0 73812K 29084K piperd 4 0:02 0.00% python3.6 4985 root 1 52 0 6504K 776K nanslp 6 0:02 0.00% cron 5203 root 1 52 0 75604K 4588K ttyin 3 0:01 0.00% python3.6 2789 root 1 21 0 7108K 904K wait 5 0:01 0.00% sh 2763 root 1 20 0 8736K 1996K nanslp 0 0:01 0.00% smartd 2576 root 1 20 0 45196K 7928K select 3 0:01 0.00% winbindd 3203 root 1 20 0 15668K 284K kqread 3 0:01 0.00% httpd 6915 root 1 20 0 12592K 488K nanslp 6 0:01 0.00% cron 7313 root 1 20 0 12592K 400K nanslp 0 0:01 0.00% cron 6570 root 1 20 0 12592K 452K nanslp 4 0:01 0.00% cron 2577 root 1 20 0 128M 5052K select 5 0:01 0.00% smbd 2685 root 1 20 0 46324K 6088K select 3 0:01 0.00% winbindd 2684 root 1 20 0 45444K 4928K select 6 0:01 0.00% winbindd 6849 root 1 20 0 10500K 652K select 4 0:00 0.00% syslogd 6513 root 1 20 0 10500K 504K select 3 0:00 0.00% syslogd 7245 root 1 20 0 10500K 608K select 6 0:00 0.00% syslogd 2296 root 1 52 0 12508K 1772K rpcsvc 0 0:00 0.00% rpc.lockd 5386 root 1 20 0 12568K 448K nanslp 3 0:00 0.00% cron 2290 root 4 52 0 6264K 1804K rpcsvc 3 0:00 0.00% nfsd 2578 root 1 20 0 128M 5528K select 3 0:00 0.00% smbd 2063 root 1 20 0 6408K 1916K select 2 0:00 0.00% rpcbind 2293 root 1 20 0 268M 1824K select 7 0:00 0.00% rpc.statd 1705 root 1 20 0 9176K 2040K select 2 0:00 0.00% devd 249 root 1 52 0 16976K 2260K piperd 1 0:00 0.00% python3.6 root@FileServer:~ # zpool status -v pool: BlackHole state: ONLINE status: Some supported features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: scrub repaired 0 in 0 days 08:47:26 with 0 errors on Sun Jun 3 08:47:30 2018 config: NAME STATE READ WRITE CKSUM BlackHole ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/4c76ceb7-a3d4-11e7-80c8-ac1f6b233196 ONLINE 0 0 0 gptid/74ca7afe-9bcd-11e7-bed9-ac1f6b233196 ONLINE 0 0 0 gptid/7607e004-9bcd-11e7-bed9-ac1f6b233196 ONLINE 0 0 0 gptid/773238c7-9bcd-11e7-bed9-ac1f6b233196 ONLINE 0 0 0 gptid/782f40cb-9bcd-11e7-bed9-ac1f6b233196 ONLINE 0 0 0 gptid/78f09b23-9bcd-11e7-bed9-ac1f6b233196 ONLINE 0 0 0 gptid/79b809b6-9bcd-11e7-bed9-ac1f6b233196 ONLINE 0 0 0 gptid/7a7f7415-9bcd-11e7-bed9-ac1f6b233196 ONLINE 0 0 0 errors: No known data errors pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0 days 00:00:29 with 0 errors on Mon Jul 2 03:45:29 2018 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: No known data errors root@FileServer:~ # zpool iostat 1 capacity operations bandwidth pool alloc free read write read write ------------ ----- ----- ----- ----- ----- ----- BlackHole 15.7T 6.06T 3 45 268K 558K freenas-boot 2.71G 12.2G 0 0 13.7K 372 ------------ ----- ----- ----- ----- ----- ----- BlackHole 15.7T 6.06T 0 0 0 0 freenas-boot 2.71G 12.2G 0 0 0 0 ------------ ----- ----- ----- ----- ----- ----- BlackHole 15.7T 6.06T 0 0 0 0 freenas-boot 2.71G 12.2G 0 0 0 0 ------------ ----- ----- ----- ----- ----- ----- BlackHole 15.7T 6.06T 0 197 0 1.38M freenas-boot 2.71G 12.2G 0 0 0 0 ------------ ----- ----- ----- ----- ----- ----- BlackHole 15.7T 6.06T 0 0 0 0 freenas-boot 2.71G 12.2G 0 0 0 0 ------------ ----- ----- ----- ----- ----- ----- BlackHole 15.7T 6.06T 0 0 0 0 freenas-boot 2.71G 12.2G 0 0 0 0 ------------ ----- ----- ----- ----- ----- ----- BlackHole 15.7T 6.06T 0 12 0 443K freenas-boot 2.71G 12.2G 0 0 0 0 ------------ ----- ----- ----- ----- ----- -----
