Stux
 - Jun 2, 2016
Okay, its a little bit hard to help as basically your question consists of "what do you think of this obsolete hardware, its cheap?"
We need a different approach :)
We could recommend up2date hardware, and then you would have a baseline to step back from. Another approach is to recommend you look into a used Dell C2100 system, or similar used systems. Beware, these systems get retired because they use a lot of power, and modern systems use less.
https://forums.freenas.org/index.php?threads/ode-to-the-dell-c2100-fs12-ty.43665/
Anyway, for a regular NAS, made with up-to-date modern/new components I would start by recommending an X11SSM-F, the goto LGA1151 board.
https://www.supermicro.com.tw/products/motherboard/Xeon/C236_C232/X11SSM-F.cfm
And add a Pentium, i3 or Xeon depending on performance requirements. And then a single stick of 16GB DDR4 RAM.
Now, if you look at how expensive that is for new up2date hardware, then you have a baseline, to step back from.
You should consult the Hardware Recommendations Guide, its pretty dang good.
https://forums.freenas.org/index.php?resources/hardware-recommendations-guide.12/
X8/Nehalem and X9/SandyBridge is not on the list.
Regarding 650$ Xeon D board... you're paying for 2 10gbe connectors and 16 SAS lanes. That's worth maybe $3-400$, but you can add that capability via PCIe cards one day, so if you have no immediate need, then don't pay that. It really wasn't an appropriate recommendation.
