Bart Grefte
- Aug 12, 2013
A while ago I got the idea of replacing one of the two stacks of external hard drives I've got with a FreeNAS-server, the 2nd stack is used as a backup-copy of the 1st stack.
So far I've got one component, which happened to be the most difficult part to get: A Stacker STC-T01. That's that huge case from Cooler Master released back in 2004, which has more than enough room for a bunch of hard drives.
As for the rest, the idea was to find an used Supermicro board, Xeon CPU and ECC-RAM, then I read that there apparently are consumer-grade motherboards and CPU's that seem to support ECC RAM.
However, supporting and actually using ECC-functionality, that's where I get stuck. I can find reports of ECC-modules being recognized, as for proof that ECC-functionality is actually being used, that is something I haven't found much about yet. Mostly just discussions about this.
Now I'm trying to decide between something like an used SuperMicro X10SLM-F and Xeon E3-1240L v3 or something like a (new) Fujitsu D3644-B with i3 8100 and CT16G4WFD8266 ECC RAM.
If ECC actually works on consumer hardware, are there any do's/don'ts to go either way?
