the result is going in more than one page with shell running in GUI 132x50. Anyway I could get it right from the beginning?Issuefor each device ada0..adaN, then pastebin the result and give us the link.Code:smartctl -x /dev/ada0
Use putty or your favorite SSH client.the result is going in more than one page with shell running in GUI 132x50. Anyway I could get it right from the beginning?
That is a great option, then you could just attach the output. However might I suggest a minor change and then you could just increment the ada0 to ada1, etc......or redirect to a file: smartctl -x /dev/ada0 > smartoutput.txt
i tried running ssh on filezilla no success. :( somehow the username password didn't match. Any youtube tutorial?Use putty or your favorite SSH client.
Could you please elaborate?...or redirect to a file: smartctl -x /dev/ada0 > smartoutput.txt
Did you enable SSH root login in the GUI?i tried running ssh on filezilla no success. :( somehow the username password didn't match. [...]
You can SFTP with Filezilla and get in, just need to make sure that's the protocol selected in the settings before you connect.Filezilla is for FTP, right?
[root@freenas] ~# smartctl -x /dev/ada3
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p25 amd64] (local build)
Model Family: Western Digital Red (AF)
Device Model: WDC WD40EFRX-68WT0N0
Serial Number: WD-WCC4E4JL9D6R
LU WWN Device Id: 5 0014ee 20baf3797
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Jan 7 16:14:14 2016 IST
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
ATA Security is: Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
been run.
data collection: (54780) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 548) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 193 193 051 - 181539
3 Spin_Up_Time POS--K 188 180 021 - 7575
4 Start_Stop_Count -O--CK 100 100 000 - 117
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 092 092 000 - 5979
10 Spin_Retry_Count -O--CK 100 100 000 - 0
11 Calibration_Retry_Count -O--CK 100 100 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 117
192 Power-Off_Retract_Count -O--CK 200 200 000 - 63
193 Load_Cycle_Count -O--CK 200 200 000 - 391
194 Temperature_Celsius -O---K 115 104 000 - 37
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 461
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 179 179 000 - 8756
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb7 GPL,SL VS 1 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 16364 (device log contains only the most recent 24 errors)
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Error 16364 [19] occurred at disk power-on lifetime: 5979 hours (249 days + 3 hours)
ER -- ST COUNT LBA_48 LH LM LL DV DC
40 -- 51 00 b0 00 01 a9 07 49 9f 40 00 Error: UNC 176 sectors at LBA = 0x1a907499f = 7130794399
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
25 00 00 00 b0 00 01 a9 07 49 58 40 08 03:19:50.043 READ DMA EXT
b0 00 d5 00 01 00 00 00 c2 4f e0 40 08 03:19:50.043 SMART READ LOG
25 00 00 00 b0 00 01 a9 07 49 58 40 08 03:19:43.045 READ DMA EXT
ec 00 00 00 01 00 00 00 00 00 00 40 08 03:19:43.045 IDENTIFY DEVICE
25 00 00 00 b0 00 01 a9 07 49 58 40 08 03:19:36.047 READ DMA EXT
Error 16363 [18] occurred at disk power-on lifetime: 5979 hours (249 days + 3 hours)
25 00 00 00 b0 00 01 a9 07 49 58 40 08 03:19:29.049 READ DMA EXT
25 00 00 00 b0 00 01 a9 07 49 58 40 08 03:19:22.051 READ DMA EXT
Error 16362 [17] occurred at disk power-on lifetime: 5979 hours (249 days + 3 hours)
60 00 10 00 10 00 00 00 40 02 90 40 08 03:19:22.027 READ FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 08 03:19:22.023 READ LOG EXT
Error 16361 [16] occurred at disk power-on lifetime: 5979 hours (249 days + 3 hours)
40 -- 51 00 b0 00 01 a9 07 49 8f 40 00 Error: UNC 176 sectors at LBA = 0x1a907498f = 7130794383
60 00 58 00 10 00 01 a9 07 21 c8 40 08 03:19:15.029 READ FPDMA QUEUED
Error 16360 [15] occurred at disk power-on lifetime: 5979 hours (249 days + 3 hours)
60 00 10 00 08 00 00 00 40 02 90 40 08 03:19:15.029 READ FPDMA QUEUED
Error 16359 [14] occurred at disk power-on lifetime: 5979 hours (249 days + 3 hours)
40 -- 51 00 00 00 01 a9 07 21 f8 40 00 Error: UNC at LBA = 0x1a90721f8 = 7130784248
2f 00 00 00 01 00 00 00 00 00 10 40 08 03:19:15.025 READ LOG EXT
60 00 58 00 08 00 01 a9 07 21 c8 40 08 03:19:08.030 READ FPDMA QUEUED
60 00 10 00 00 00 00 00 40 02 90 40 08 03:19:08.030 READ FPDMA QUEUED
Error 16358 [13] occurred at disk power-on lifetime: 5979 hours (249 days + 3 hours)
40 -- 51 00 00 00 01 a9 07 22 0f 40 00 Error: UNC at LBA = 0x1a907220f = 7130784271
2f 00 00 00 01 00 00 00 00 00 10 40 08 03:19:08.026 READ LOG EXT
60 00 58 00 00 00 01 a9 07 21 c8 40 08 03:19:01.032 READ FPDMA QUEUED
60 00 10 00 f8 00 00 00 40 02 90 40 08 03:19:01.032 READ FPDMA QUEUED
Error 16357 [12] occurred at disk power-on lifetime: 5979 hours (249 days + 3 hours)
2f 00 00 00 01 00 00 00 00 00 10 40 08 03:19:01.028 READ LOG EXT
60 00 58 00 f8 00 01 a9 07 21 c8 40 08 03:18:54.009 READ FPDMA QUEUED
60 00 10 00 f0 00 01 d1 c0 bc 90 40 08 03:18:54.009 READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Short offline Completed without error 00% 5812 -
# 2 Extended offline Completed: read failure 10% 5774 7050726168
# 3 Short offline Completed without error 00% 5620 -
# 4 Short offline Completed without error 00% 5401 -
# 5 Extended offline Completed without error 00% 5318 -
# 6 Short offline Completed without error 00% 5239 -
# 7 Short offline Completed without error 00% 5122 -
# 8 Short offline Completed without error 00% 4951 -
# 9 Extended offline Completed without error 00% 4868 -
#10 Short offline Completed without error 00% 4784 -
#11 Short offline Completed without error 00% 4545 -
#12 Extended offline Completed without error 00% 4463 -
#13 Short offline Completed without error 00% 4377 -
#14 Short offline Completed without error 00% 4209 -
#15 Extended offline Completed without error 00% 4124 -
#16 Short offline Completed without error 00% 4042 -
#17 Short offline Completed without error 00% 3826 -
#18 Extended offline Completed without error 00% 3743 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
SCT Support Level: 1
Device State: Active (0)
Current Temperature: 37 Celsius
Power Cycle Min/Max Temperature: 37/37 Celsius
Lifetime Min/Max Temperature: 29/48 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (124)
Index Estimated Time Temperature Celsius
125 2016-01-07 08:17 37 ******************
... ..( 58 skipped). .. ******************
184 2016-01-07 09:16 37 ******************
185 2016-01-07 09:17 ? -
186 2016-01-07 09:18 37 ******************
... ..(415 skipped). .. ******************
124 2016-01-07 16:14 37 ******************
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP Log 0x04) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 3 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 3 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 11997 Vendor specific
[root@freenas] ~# smartctl -x /dev/ada2
Serial Number: WD-WCC4E4JL934K
LU WWN Device Id: 5 0014ee 261047b63
Local Time is: Thu Jan 7 16:22:53 2016 IST
was never started.
been run.
data collection: (52680) seconds.
command.
power-saving mode.
recommended polling time: ( 527) minutes.
1 Raw_Read_Error_Rate POSR-K 200 199 051 - 3483
3 Spin_Up_Time POS--K 185 176 021 - 7741
193 Load_Cycle_Count -O--CK 200 200 000 - 381
194 Temperature_Celsius -O---K 114 109 000 - 38
197 Current_Pending_Sector -O--CK 200 200 000 - 44
200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 52
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
Device Error Count: 1566 (device log contains only the most recent 24 errors)
ER = Error register
Error 1566 [5] occurred at disk power-on lifetime: 5486 hours (228 days + 14 hours)
40 -- 51 00 00 00 00 02 71 91 98 40 00 Error: UNC at LBA = 0x02719198 = 40997272
60 00 e8 00 60 00 00 02 71 91 c0 40 08 15:57:41.308 READ FPDMA QUEUED
60 00 e0 00 58 00 00 02 71 90 e0 40 08 15:57:41.308 READ FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 08 15:57:41.304 READ LOG EXT
60 00 e8 00 58 00 00 02 71 91 c0 40 08 15:57:37.934 READ FPDMA QUEUED
60 00 e0 00 50 00 00 02 71 90 e0 40 08 15:57:37.934 READ FPDMA QUEUED
Error 1565 [4] occurred at disk power-on lifetime: 5486 hours (228 days + 14 hours)
2f 00 00 00 01 00 00 00 00 00 10 40 08 15:57:37.930 READ LOG EXT
60 00 e8 00 50 00 00 02 71 91 c0 40 08 15:57:34.559 READ FPDMA QUEUED
60 00 e0 00 48 00 00 02 71 90 e0 40 08 15:57:34.559 READ FPDMA QUEUED
Error 1564 [3] occurred at disk power-on lifetime: 5486 hours (228 days + 14 hours)
2f 00 00 00 01 00 00 00 00 00 10 40 08 15:57:34.555 READ LOG EXT
60 00 e8 00 48 00 00 02 71 91 c0 40 08 15:57:31.185 READ FPDMA QUEUED
60 00 e0 00 40 00 00 02 71 90 e0 40 08 15:57:31.185 READ FPDMA QUEUED
Error 1563 [2] occurred at disk power-on lifetime: 5486 hours (228 days + 14 hours)
2f 00 00 00 01 00 00 00 00 00 10 40 08 15:57:31.181 READ LOG EXT
60 00 e8 00 40 00 00 02 71 91 c0 40 08 15:57:27.815 READ FPDMA QUEUED
60 00 e0 00 38 00 00 02 71 90 e0 40 08 15:57:27.815 READ FPDMA QUEUED
Error 1562 [1] occurred at disk power-on lifetime: 5486 hours (228 days + 14 hours)
60 00 e0 00 30 00 00 02 71 90 00 40 08 15:57:27.813 READ FPDMA QUEUED
60 00 e0 00 28 00 00 02 71 8f 20 40 08 15:57:27.811 READ FPDMA QUEUED
60 00 e0 00 20 00 00 02 71 8e 40 40 08 15:57:27.809 READ FPDMA QUEUED
Error 1561 [0] occurred at disk power-on lifetime: 5486 hours (228 days + 14 hours)
40 -- 51 00 00 00 00 02 71 67 b8 40 00 Error: WP at LBA = 0x027167b8 = 40986552
61 00 18 00 58 00 01 a8 f5 5d f8 40 08 15:57:22.151 WRITE FPDMA QUEUED
61 00 30 00 50 00 01 a8 f5 4d 60 40 08 15:57:22.151 WRITE FPDMA QUEUED
61 00 30 00 48 00 01 a8 f5 5d c8 40 08 15:57:22.151 WRITE FPDMA QUEUED
61 00 28 00 40 00 01 a8 f5 5d a0 40 08 15:57:22.151 WRITE FPDMA QUEUED
61 00 18 00 38 00 01 a8 49 0b 38 40 08 15:57:22.151 WRITE FPDMA QUEUED
Error 1560 [23] occurred at disk power-on lifetime: 5486 hours (228 days + 14 hours)
40 -- 51 00 00 00 00 02 71 67 b8 40 00 Error: UNC at LBA = 0x027167b8 = 40986552
60 00 28 00 98 00 01 9a 29 e3 88 40 08 15:57:18.764 READ FPDMA QUEUED
60 00 e0 00 90 00 00 02 71 68 98 40 08 15:57:18.764 READ FPDMA QUEUED
60 00 e0 00 88 00 00 02 71 67 b8 40 08 15:57:18.763 READ FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 08 15:57:18.760 READ LOG EXT
60 00 28 00 88 00 01 9a 29 e3 88 40 08 15:57:15.378 READ FPDMA QUEUED
Error 1559 [22] occurred at disk power-on lifetime: 5486 hours (228 days + 14 hours)
60 00 e0 00 80 00 00 02 71 68 98 40 08 15:57:15.378 READ FPDMA QUEUED
60 00 e0 00 78 00 00 02 71 67 b8 40 08 15:57:15.378 READ FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 08 15:57:15.374 READ LOG EXT
60 00 e0 00 70 00 00 02 71 68 98 40 08 15:57:12.004 READ FPDMA QUEUED
# 1 Short offline Completed: read failure 90% 5811 4277199
# 2 Extended offline Completed: read failure 90% 5763 4277192
# 3 Short offline Completed without error 00% 5619 -
# 4 Short offline Completed: read failure 90% 5489 4277192
# 5 Short offline Completed without error 00% 5401 -
# 6 Extended offline Completed: read failure 90% 5306 18299056
# 7 Short offline Completed without error 00% 5239 -
# 8 Short offline Completed without error 00% 5120 -
# 9 Short offline Completed without error 00% 4951 -
#10 Extended offline Completed: read failure 90% 4856 18299056
#11 Short offline Completed without error 00% 4784 -
#12 Short offline Completed without error 00% 4545 -
#13 Extended offline Completed: read failure 90% 4449 18299056
#14 Short offline Completed without error 00% 4378 -
#15 Short offline Completed without error 00% 4209 -
#16 Extended offline Completed: read failure 90% 4114 18299056
#17 Short offline Completed without error 00% 4042 -
#18 Short offline Completed without error 00% 3826 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Current Temperature: 38 Celsius
Power Cycle Min/Max Temperature: 38/38 Celsius
Lifetime Min/Max Temperature: 27/43 Celsius
Temperature History Size (Index): 478 (475)
476 2016-01-07 08:25 37 ******************
... ..( 38 skipped). .. ******************
37 2016-01-07 09:04 37 ******************
38 2016-01-07 09:05 ? -
39 2016-01-07 09:06 38 *******************
... ..(207 skipped). .. *******************
247 2016-01-07 12:34 38 *******************
248 2016-01-07 12:35 37 ******************
... ..(226 skipped). .. ******************
475 2016-01-07 16:22 37 ******************
0x8000 4 12500 Vendor specific
yes thanks. My Alerts also show the same. But I wouldn't want to buy 2 drives right now. Buy 1 send 1 for RMA. get the 1st RMA'ed and then send second for RMA. Receive that and keep it as a spare. :)@Bhoot
Your two drives are failing. I would RMA these.
ID's 197 and 200 and the Extended test failures are the indicators here.
Your resilvering will take a bit of time since your pool is very full. Not sure you can do this where you live but here in the US we can do an Advance Replacement (I think it's called) RMA where WD takes a credit card number from you, places a charge (on hold, not actually applied) on that credit card, and ships you a replacement drive with a return shipping label. So you get the replacement drive, swap it out, put the failed drive into the box and slap on the return label. Once WD get the failed drive back within a certain period of time, they drop the pending charge. Well that is the way it happened for me a few years back. The good thing about it as I received a replacement drive quickly and didn't pay for return shipping costs.
Also, not sure when the last time you ran a Scrub was but you should do it. Also, backup all your important data somewhere. You have 2 drives failing and if a third drive starts having issue, you do risk loosing your data.
