Samba project announces important security update for May 24th - when will the FreeNAS update follow
D
dlavigne
Guest
Yes, once the patch is released we'll be rolling a 9.10.2-U4.
NAS-Plus
Received this today:
A new update is available for the FreeNAS-9.10-STABLE train.
Version: FreeNAS-9.10.2-U4
Changelog:
#24116 Bug Expected Update Samba to 4.5.9
Does this update incorporate a Samba security update? Has anyone installed it yet?
NAS-Plus
Good. Since you created an SMB how-to video I presume that you use SMB. Any unintended consequences to the U4 update
m0nkey_
Correct. I was even the one that opened the bug ticket in the update :)
No issues seen.
It shouldn't really cause any issues. It was a very small fix.
D-Tijori
So in terms of issue(s), seems it did something to my system. Post-installation of .U4, cannot see server folders in Windows explorer anymore.
This has happened in the past and have solved it by: deleting shares > rebooting > creating same shares again
A bit of annoyance really.
m0nkey_
Boot back into U3 and see if the problem is still there. If there were any major issues with U4, I for one will be Ɓitching, and very loudly.
D-Tijori
Tested it out and indeed after booting back in .U3, the drives have popped back up. A bit of chin scratching for the devs?
Update: So it seems like somewhat expected outcome of the update - 'Note this can disable some expected functionality for Windows clients.' (samba.org)
Koola'...2 weeks.
Will this security fix come down the 9.3 train?
