FlangeMonkey
- Dec 6, 2012
Can you try with the U3 one of the suggestions:
Both approaches address the same issue - in the generatedsmb4.confthere is now a settingprivate dir = /root/samba/private/that points to the directory where user passwords and other sensitive information is stored. In the past and by default that directory used to be/var/db/samba4/private/.
Hi BaT,
Can you please confirm that moving forward this is the new location for the private files? Or was this in error and this line shouldn't be present?
This will make a difference in how I will handle a workaround with a looming bug fix.
Thanks,
