S.M.A.R.T. ATA error count increased
MichaelBatz
Hey everybody!
I woke up to this mail the other day.
Device: /dev/ada0, ATA error count increased from 675 to 677
First I thought it was a bad SATA cable. I have experienced that before, since the initial value was 675. From the S.M.A.R.T. test report, I noticed that, da0, da1, da2 and da4 also had encountered a UDMA CRC error. I haven't recived any mails about that, nor does the FreeNAS GUI inform me about it.
(I know that ada0 has 81 reallocted sector counts. I'm not 100% sure about it, but I think that was also because of the bad SATA cable, cause the value hasn't gone up since I changed the cable, which is nearly a year ago)
HTML:
|Device|Serial         |Temp|Power|Start|Spin |ReAlloc|Current|Offline |UDMA  |Seek  |High  |Command|Last|
|      |               |    |On   |Stop |Retry|Sectors|Pending|Uncorrec|CRC   |Errors|Fly   |Timeout|Test|
|      |               |    |Hours|Count|Count|       |Sectors|Sectors |Errors|      |Writes|Count  |Age |
|da0   |WD-WCC4N3YAEN2T| 35 | 9509|   56|    0|      0|      0|       0|     1|   N/A|   N/A|    N/A|   0|
|da1   |WD-WMC4N0F3STHP| 34 | 9549|   58|    0|      0|      0|       0|     1|   N/A|   N/A|    N/A|   0|
|da2   |WD-WMC4N1388846| 33 | 9549|   58|    0|      0|      0|       0|     1|   N/A|   N/A|    N/A|   0|
|da3   |WD-WMC1T1660355| 33 | 9554|   57|    0|      0|      0|       0|     0|   N/A|   N/A|    N/A|   6|
|da4   |WD-WMC4N2883748| 32 | 6553|   32|    0|      0|      0|       0|     1|   N/A|   N/A|    N/A|   0|
|da5   |WD-WMC1T1262624| 32 | 6556|   31|    0|      0|      0|       0|     0|   N/A|   N/A|    N/A|   6|
|da6   |WD-WMC4N2694052| 31 | 6554|   32|    0|      0|      0|       0|     0|   N/A|   N/A|    N/A|   6|
|da7   |Z500TF2V       | 31 | 6757|   67|    0|      0|      0|       0|     0|    25|     5|      0|   6|
|ada0 !|MK0351YHG8BE7A | 36 |23116| 2189|    0|     81|      0|       0|   677|   N/A|   N/A|    N/A|   0|
|ada1  |Z1F4BT5K       | 32 |12466| 4757|    0|      0|      0|       0|     0|     0|     0|      0|   6|
I performed an extended S.M.A.R.T. test yesterday on the 5 HDD's. Here are the smartctl -a /dev/X output for each HDD.
da0
freenas# smartctl -a /dev/da0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p31 amd64] (local build)
Model Family:     Western Digital Red
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD-WCC4N3YAEN2T
LU WWN Device Id: 5 0014ee 20b2ded73
Firmware Version: 82.00A82
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Mar 18 12:24:24 2016 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (39720) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 399) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   176   176   021    Pre-fail  Always       -       6183
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       56
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   100   253   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   087   087   000    Old_age   Always       -       9511
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       56
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       54
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       1887
194 Temperature_Celsius     0x0022   113   105   000    Old_age   Always       -       37
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       1
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%      9498         -
# 2  Short offline       Completed without error       00%      9362         -
# 3  Extended offline    Completed without error       00%      9275         -
# 4  Short offline       Completed without error       00%      9195         -
# 5  Short offline       Completed without error       00%      9003         -
# 6  Extended offline    Completed without error       00%      8915         -
# 7  Short offline       Completed without error       00%      8835         -
# 8  Short offline       Completed without error       00%      8667         -
# 9  Extended offline    Completed without error       00%      8580         -
#10  Short offline       Completed without error       00%      8500         -
#11  Short offline       Completed without error       00%      8260         -
#12  Extended offline    Completed without error       00%      8172         -
#13  Short offline       Completed without error       00%      8092         -
#14  Short offline       Completed without error       00%      7924         -
#15  Extended offline    Completed without error       00%      7838         -
#16  Short offline       Completed without error       00%      7758         -
#17  Short offline       Completed without error       00%      7519         -
#18  Extended offline    Completed without error       00%      7431         -
#19  Short offline       Completed without error       00%      7352         -
#20  Short offline       Completed without error       00%      7184         -
#21  Extended offline    Completed without error       00%      7096         -
da1
freenas# smartctl -a /dev/da1
Serial Number:    WD-WMC4N0F3STHP
LU WWN Device Id: 5 0014ee 6afc66ca7
Local Time is:    Fri Mar 18 12:26:04 2016 CET
                                        was never started.
                                        been run.
data collection:                (40380) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 405) minutes.
  3 Spin_Up_Time            0x0027   182   180   021    Pre-fail  Always       -       5900
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       58
  9 Power_On_Hours          0x0032   087   087   000    Old_age   Always       -       9552
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       58
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       55
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       1956
194 Temperature_Celsius     0x0022   114   107   000    Old_age   Always       -       36
No Errors Logged
# 1  Extended offline    Completed without error       00%      9539         -
# 2  Short offline       Completed without error       00%      9403         -
# 3  Extended offline    Completed without error       00%      9316         -
# 4  Short offline       Completed without error       00%      9235         -
# 5  Short offline       Completed without error       00%      9043         -
# 6  Extended offline    Completed without error       00%      8956         -
# 7  Short offline       Completed without error       00%      8875         -
# 8  Short offline       Completed without error       00%      8708         -
# 9  Extended offline    Completed without error       00%      8621         -
#10  Short offline       Completed without error       00%      8540         -
#11  Short offline       Completed without error       00%      8301         -
#12  Extended offline    Completed without error       00%      8213         -
#13  Short offline       Completed without error       00%      8133         -
#14  Short offline       Completed without error       00%      7965         -
#15  Extended offline    Completed without error       00%      7879         -
#16  Short offline       Completed without error       00%      7799         -
#17  Short offline       Completed without error       00%      7559         -
#18  Extended offline    Completed without error       00%      7471         -
#19  Short offline       Completed without error       00%      7393         -
#20  Short offline       Completed without error       00%      7225         -
#21  Extended offline    Completed without error       00%      7137         -
The UDMA CRC error is only shown in the overview on da0, da1, da2 and da4, not as an error like on ada0. Could that be the reason why I haven't recived any mails about it, plus that the FreeNAS GUI isn't informing be about it?
There was an ongoing scrub on the zpool, while these error were encountered.
  pool: tank
state: ONLINE
  scan: scrub repaired 0 in 45h1m with 0 errors on Thu Mar 17 04:01:19 2016
        tank                                            ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/7d0d4614-1d70-11e5-9640-0cc47a31d318  ONLINE       0     0     0
            gptid/7d9d0f81-1d70-11e5-9640-0cc47a31d318  ONLINE       0     0     0
            gptid/7e1863a0-1d70-11e5-9640-0cc47a31d318  ONLINE       0     0     0
            gptid/7e8c4e54-1d70-11e5-9640-0cc47a31d318  ONLINE       0     0     0
            gptid/7f03f0cd-1d70-11e5-9640-0cc47a31d318  ONLINE       0     0     0
            gptid/7fa080f2-1d70-11e5-9640-0cc47a31d318  ONLINE       0     0     0
            gptid/8018dd86-1d70-11e5-9640-0cc47a31d318  ONLINE       0     0     0
            gptid/80ac89ef-1d70-11e5-9640-0cc47a31d318  ONLINE       0     0     0
            gptid/811ff591-1d70-11e5-9640-0cc47a31d318  ONLINE       0     0     0
            gptid/8180504c-1d70-11e5-9640-0cc47a31d318  ONLINE       0     0     0
errors: No known data errors
I have checked the cabling. The 5 HDD's are not connected to the same SATA connector. No loose cables or anything.
I'm gonna buy a new WD Red 3TB next month to replace ada0. I'm also gonna buy a UPS, but until then, how should i proceed?
Thanks in advance!
Michael Batz
MichaelBatz
Too many characters for one post. Here are the rest of the smartctl -a /dev/X.
da2
freenas# smartctl -a /dev/da2
Serial Number:    WD-WMC4N1388846
LU WWN Device Id: 5 0014ee 6040f0ee4
Local Time is:    Fri Mar 18 12:49:58 2016 CET
                                        was never started.
                                        been run.
data collection:                (41640) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 418) minutes.
  3 Spin_Up_Time            0x0027   180   179   021    Pre-fail  Always       -       6000
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       1950
194 Temperature_Celsius     0x0022   115   107   000    Old_age   Always       -       35
No Errors Logged
# 2  Short offline       Completed without error       00%      9402         -
# 8  Short offline       Completed without error       00%      8707         -
#11  Short offline       Completed without error       00%      8300         -
#13  Short offline       Completed without error       00%      8132         -
#16  Short offline       Completed without error       00%      7798         -
#19  Short offline       Completed without error       00%      7392         -
#20  Short offline       Completed without error       00%      7224         -
da4
freenas# smartctl -a /dev/da4
Serial Number:    WD-WMC4N2883748
LU WWN Device Id: 5 0014ee 0ae821805
Local Time is:    Fri Mar 18 12:50:54 2016 CET
                                        was never started.
                                        been run.
data collection:                (40020) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 401) minutes.
  3 Spin_Up_Time            0x0027   181   181   021    Pre-fail  Always       -       5916
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       32
  9 Power_On_Hours          0x0032   092   092   000    Old_age   Always       -       6556
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       32
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       29
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       405
194 Temperature_Celsius     0x0022   117   109   000    Old_age   Always       -       33
No Errors Logged
# 1  Extended offline    Completed without error       00%      6543         -
# 2  Short offline       Completed without error       00%      6407         -
# 3  Extended offline    Completed without error       00%      6320         -
# 4  Short offline       Completed without error       00%      6239         -
# 5  Short offline       Completed without error       00%      6048         -
# 6  Extended offline    Completed without error       00%      5960         -
# 7  Short offline       Completed without error       00%      5880         -
# 8  Short offline       Completed without error       00%      5712         -
# 9  Extended offline    Completed without error       00%      5625         -
#10  Short offline       Completed without error       00%      5544         -
#11  Short offline       Completed without error       00%      5305         -
#12  Extended offline    Completed without error       00%      5217         -
#13  Short offline       Completed without error       00%      5137         -
#14  Short offline       Completed without error       00%      4969         -
#15  Extended offline    Completed without error       00%      4883         -
#16  Short offline       Completed without error       00%      4803         -
#17  Short offline       Completed without error       00%      4563         -
#18  Extended offline    Completed without error       00%      4475         -
#19  Short offline       Completed without error       00%      4397         -
#20  Short offline       Completed without error       00%      4229         -
#21  Extended offline    Completed without error       00%      4141         -
ada0
freenas# smartctl -a /dev/ada0
Model Family:     Hitachi Ultrastar 7K3000
Device Model:     Hitachi HUA723030ALA640
Serial Number:    MK0351YHG8BE7A
LU WWN Device Id: 5 000cca 225c3cddd
Firmware Version: MKAOA6L0
Sector Size:      512 bytes logical/physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 2.6, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Mar 18 12:51:18 2016 CET
Offline data collection status:  (0x84) Offline data collection activity
                                        was suspended by an interrupting command from host.
                                        been run.
data collection:                (29983) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        power-saving mode.
recommended polling time:        (   1) minutes.
recommended polling time:        ( 500) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       65536
  2 Throughput_Performance  0x0005   133   133   054    Pre-fail  Offline      -       90
  3 Spin_Up_Time            0x0007   136   136   024    Pre-fail  Always       -       543 (Average 595)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       2189
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       81
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   133   133   020    Pre-fail  Offline      -       27
  9 Power_On_Hours          0x0012   097   097   000    Old_age   Always       -       23119
10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       1139
192 Power-Off_Retract_Count 0x0032   099   099   000    Old_age   Always       -       2248
193 Load_Cycle_Count        0x0012   099   099   000    Old_age   Always       -       2248
194 Temperature_Celsius     0x0002   157   157   000    Old_age   Always       -       38 (Min/Max 18/60)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       157
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       677
ATA Error Count: 677 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 677 occurred at disk power-on lifetime: 23057 hours (960 days + 17 hours)
  ER ST SC SN CL CH DH
  84 51 00 10 30 18 03  Error: ICRC, ABRT at LBA = 0x03183010 = 51916816
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  60 20 00 0f 30 18 43 ff   1d+05:22:31.662  READ FPDMA QUEUED
  60 20 a0 f0 2f 18 40 00   1d+05:22:31.661  READ FPDMA QUEUED
  60 20 98 c8 2f 18 40 00   1d+05:22:31.661  READ FPDMA QUEUED
  60 20 90 a8 2f 18 40 00   1d+05:22:31.661  READ FPDMA QUEUED
  60 20 88 88 2f 18 40 00   1d+05:22:31.661  READ FPDMA QUEUED
Error 676 occurred at disk power-on lifetime: 23057 hours (960 days + 17 hours)
  84 51 01 0f 30 18 03  Error: ICRC, ABRT at LBA = 0x0318300f = 51916815
Error 675 occurred at disk power-on lifetime: 16552 hours (689 days + 16 hours)
  84 51 01 11 00 00 00  Error: ICRC, ABRT 1 sectors at LBA = 0x00000011 = 17
  c8 00 01 12 00 00 a0 00      00:19:18.340  READ DMA
  c8 00 01 12 00 00 a0 00      00:19:17.332  READ DMA
  c8 00 01 12 00 00 a0 00      00:19:16.325  READ DMA
  c8 00 01 11 00 00 a0 00      00:19:16.324  READ DMA
  c8 00 01 11 00 00 a0 00      00:19:15.317  READ DMA
Error 674 occurred at disk power-on lifetime: 16552 hours (689 days + 16 hours)
  c8 00 01 11 00 00 a0 00      00:19:14.309  READ DMA
Error 673 occurred at disk power-on lifetime: 16552 hours (689 days + 16 hours)
  c8 00 01 11 00 00 a0 00      00:19:13.301  READ DMA
# 1  Extended offline    Completed without error       00%     23107         -
# 2  Short offline       Completed without error       00%     22969         -
# 3  Extended offline    Completed without error       00%     22886         -
# 4  Short offline       Completed without error       00%     22802         -
# 5  Short offline       Completed without error       00%     22610         -
# 6  Short offline       Completed without error       00%     22442         -
# 7  Short offline       Completed without error       00%     22274         -
# 8  Extended offline    Completed without error       00%     22188         -
# 9  Short offline       Completed without error       00%     22106         -
#10  Short offline       Completed without error       00%     21866         -
#11  Extended offline    Completed without error       00%     21780         -
#12  Short offline       Completed without error       00%     21698         -
#13  Short offline       Completed without error       00%     21530         -
#14  Extended offline    Completed without error       00%     21447         -
#15  Short offline       Completed without error       00%     21364         -
#16  Short offline       Completed without error       00%     21124         -
#17  Extended offline    Completed without error       00%     21037         -
#18  Short offline       Completed without error       00%     20957         -
#19  Short offline       Completed without error       00%     20789         -
#20  Extended offline    Completed without error       00%     20702         -
#21  Short offline       Completed without error       00%     20621         -
Bidule0hm
Server Electronics Sorcerer
Ada0 is failing, you should replace it asap ;)
I don't check UDMA errors (but you can add the check in the script if you want it) because you can have some UDMA errors in the life of the drive (especially if one time the SATA cable wasn't connected correctly) without them causing any problems. I guess I can add a check but with a very high value by default (something like 500 or 1000 for example).
The ada0 is reported critical because it has more than 10 (or whatever the treshold value you've chosen) reallocated sectors.
MichaelBatz
Okay. I will order a WD Red 3TB soon then.
What I meant with the overview. If you look at the output for smartctl -a /dev/X. Then the UDMA CRC error isn't shown for any other drives than ada0. Like this.
You have made the status report script. Thanks for that. I like it a lot!
joeschmuck
Old Man
For Ada0 the values ID 5 and 196 are your key indicators of a hardware failure for this drive. As suggested, replace it at once.
Also, UDMA errors are data transfer errors, typically associated with a data cable but if you have swapped the data cable and the problem persists, it could be a drive electronics problem. Small counts are not to be worried about but if they continue to occur then troubleshooting should commence to isolate the failed item. In your case you have one obvious failed drive.
Bidule0hm
Oh, I believed that you talked about the exclamation mark in the output of the script.
Maybe there's a treshold where they don't show the details of the error.
You're welcome ;)
MichaelBatz
Ohh, the Reallocation Event Count. I haven't been paying attention to that value. Think I will order a new drive today!
Thanks for the answers, joeschmuck and Bidule0hm.
joeschmuck
Old Man
I created this guide to assist in troubleshooting hard drive failures. If you haven't looked at it, please do so as it should explain a lot and what specifically to look for to identify a hardware failure or data error. It will not cover every situation but does cover what problems we typically see. If there are any suggestions to make this guide more usable, please let me know.
https://forums.freenas.org/index.ph...leshooting-guide-basic-common-failures.41026/
