Resize Virtualbox VHD
dambrosioj
Could anyone direct me on how to resize the virtualbox VHD I have? When I set it up I chose dynamic and went with the stock 25gb. I thought the drive would expand itself but it is not.
You need to seek Virtualbox support and documentation. This forum is not appropriate for your question.
Thanks.
dambrosioj
Ok fair enough but maybe you could tell me how to access where the VHD is stored and I could move it from FREENAS to a windows machine where I know how to easily resize it. It stores the VM's in /home/vbox/VirtualBox VMs/Windows Server Environment/Windows Server Environment.vhd
but when i try to sftp into that home dir, it says it does not exist. I also tried via shell with no luck either. This is with the root user. Could you tell me how to gain access to that directory.
ikonspirasi
