kirkdickinson
- Jun 29, 2015
I have never set up a FreeNAS system. Years ago I did set it up in VMWare to play with and get a feel for it, I ended up going a different route. I have an aging XP Server that could die anyday and doesn't have nearly enough storage. I am trying to figure out the best route to go and FreeNAS looks like the ticket. I mostly need a file server in a Windows/Mac office environment. I will also be backing up data from workstations and maybe even storing some disk images.
I have a wishlist on Newegg
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=20397949
(there are two Motherboards in there because I haven't decided.)
Here is the list that I have right now:
Questions:
What is the difference between SATA and SAS? Are those differences important in a build like this?
Can SATA drives be run on SAS controller? Is that bad?
Is SATA 6.0 going to make a difference on a system like this over SATA 3.0?
In my old RAID 6 configuration I think I have about 66% usable vs total drive capacity. (5 750 gig drives gives me about 2.4 Gig) What is the usable capacity vs total drive space in a ZFS environment?
I picked a small SSD boot drive instead of a thumbdrive because it is way faster and not much more expensive. The specs say that 8Gig is enough, I picked a 16, is that really enough?
Thank You,
Kirk
iStarUSA D-406-B6SA-RED-ND Red Steel 4U Rackmount Server Case
Model #:D-406-B6SA-RED-ND
Item #:N82E16811165089
SUPERMICRO MBD-X10SLL-F-O uATX Server Motherboard LGA 1150 DDR3 1600
Model #:MBD-X10SLL-F-O
Item #:N82E16813182819
CORSAIR RM Series RM850 850W ATX12V v2.31 and EPS 2.92 80 PLUS GOLD Certified Full Modular Active PFC Power Supply
Model #:RM850
Item #:N82E16817139056
Intel Xeon E3-1231V3 Haswell 3.4GHz LGA 1150 80W BX80646E31231V3 Server Processor
Model #:BX80646E31231V3
Item #:N82E16819117316
2 - Axiom 16GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model MC730G/A-AX
Model #:MC730G/A-AX
Item #:N82E16820613571
6 - Seagate NAS HDD ST4000VN000 4TB 64MB Cache SATA 6.0Gb/s Internal Hard Drive
Model #:ST4000VN000
Item #:N82E16822178393
MyDigitalSSD Super Boot Drive 50mm SATA III (6G) mSATA SSD (16GB)
Model #:728028335828
Item #:9SIA53D1SC4529
Model #:RM850
Model #:MC730G/A-AX
Model #:ST4000VN000
Questions:
Thank You,
Kirk
