Hi all,
My FreeNAS stopped generating Reporting graphs for ... no reason. Every time I try to access the reporting tab, I get only a cross icon, nothing more except from buttons. I also have an error in the debug traces saying "cpu-aggregator-percent file does not exist"
I tried to :
I tried to :
- Change the System Dataset
- Disable & Enable via the UI the RRD (which is painfull, since most of the time the save take ages and doesn't do anything ...)
- Stopping via command line the collectd client, removing files in /var/db/rrd/... and restarting the process by hand
- Stopping via command line, removing files, rebooting
