SOLVED Replaced failed disk, unreadable sectors, smartctl no error
Hobbel
Hey out there,
I've a strange problem. I replaced a failed WD Red 1TB (da3) on wednesday, following the FreeNAS doc (mark offline, replace physical, replace in GUI). After resilvering was completed, I got this alert in the GUI:
I did a
smartctl -a /dev/da3
and got
smartctl 6.4 2015-06-04 r4109 [FreeBSD 10.3-RELEASE amd64] (local build)
Copyright (C) 2002-15, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Red
Device Model:     WDC WD10EFRX-68FYTN0
Serial Number:    WD-WCC4J1XXXXXX
LU WWN Device Id: 5 0014ee 20c72537f
Firmware Version: 82.00A82
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Apr  8 11:33:16 2016 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (15360) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 174) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x303d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   100   253   021    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       1
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   100   253   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       37
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       1
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       0
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       1
194 Temperature_Celsius     0x0022   114   112   000    Old_age   Always       -       29
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Conveyance offline  Completed without error       00%        22         -
# 2  Short offline       Completed without error       00%        22         -
also did a short and conveyance SMART test.
What am I missing? Is there a way to reload the GUI alerts (not a page refresh)?
Thanks in advance
EDIT
FreeNAS-9.10-STABLE-201603252134 (412fb1c)
Bidule0hm
Server Electronics Sorcerer
And/or just reboot, IIRC the alerts are cleared on reboot.
Hobbel
@hugovsky
yeah... of course... I will do so. But why is the GUI alerting, when SMART isn't showing any error? Isn't the GUI alert parsing SMART data?
Hobbel
Bidule0hm
IIRC it's also cleared each night when the automatic scripts are launched.
Hobbel
long test finished. SMART is not seeing any errors. So why does the GUI?
Local Time is:    Fri Apr  8 21:04:26 2016 CEST
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       46
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
No Errors Logged
# 1  Extended offline    Completed without error       00%        46         -
# 2  Conveyance offline  Completed without error       00%        22         -
# 3  Short offline       Completed without error       00%        22         -
Bidule0hm
Because it displays the error of the old drive, it'll clear it if you wait long enough.
Hobbel
I'm waiting since 46 hrs and 2 "reloads" each night. It would be nice to refresh the alert system of the GUI to see if it's false positive... Like I said, a restart is no option.
It clears when you delete /tmp/.smartalert. Reboots will not clear the file. :P
Hobbel
It clears when you delete /tmp/.smartalert. Reboots will not clear the file. :p
was inside /tmp before, but only had a look at alert... in this file, the message is written under p14.
deleted /tmp/.smartalert but no change for now. will wait another night, to see if it clears.
as always... thx @cyberjock ;)
EDIT
1 minute after writing this, the alert cleared itself. it' done :)
Bidule0hm
Right, it only clears the scrub errors, I forgot about that...
