I see my problem was posted for freenas system. I wanted to check if still valid for my 13.0 U3.1 installation. It's the "device too small" error given for 7 different 6TB drives. Some were actually used previously in a working pool.
I don't recall. How do I check? I just got my motherboard back after sending it to be repaired under warranty. That took most of my attention. My current system isn't shown,
glabel list
Have you removed the partitions from the new used drives? Maybe that would help.
But I still don't understand your question. You state the question as if you previously had a problem and are asking if it's still a problem in the current TrueNAS version. I have no idea if you are replacing a 12TB drive with a smaller 6TB drive, or a 6TB drive with a 6TB drive. You just do not provide adequate information. You cannot replace a drive with a smaller sized drive, never. This has to do with the way the data/parity is allocated to the drives. You can install larger drives but not smaller drives.
My last post was a reply to Winnielinnie about the 2 GB swap reservation. I saw an older post on this error that seemed to talk about zeroing out the swap then reinstating afterwards. My original post was on reference to the old post "[EZFS_BADDEV] device is too small". The reply to joeschmck is as follows:
I'm running a 8x6TB Rz2 pool in tn13.0 u3.1. Because mobo issues 2 of the drives went down. Sent the mobo in for warranty repairs. When I installed the repaired mobo one of the drives came back online leaving one drive in removed status. I have 7 extra 6TB drives( all same exact model as the removed drive) that I've tried to use as replacements. I used the force replace option each time. All of the drives return the same error "ZFSException: device is too small" and "[EZFS_BADDEV] device is too small ".
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
