Redundant SLOG device?
Exhorder
I've got a question about SLOG. I'm not sure if it has to be redundant. What I've read so far says, that it does not need to be redundant because if device fails, the ZIL just goes to the pool where it would be without SLOG anyways.
OK, but I never had a completely failing SSD so far. If I had a failing SSD it just resulted in corrupted file systems (ext4 or XFS) because apparantly corrupted data got written to the disk. If this happens to my SLOG, what is the result? Is data on SLOG also checked before it goes to the pool? Or would only a redundant SLOG help here? Or would a redundant SLOG help here anyway?
Thanks
Correct. But if you're using sync writes heavily, this is very bad.
