reznor244
- Dec 16, 2023
Background:
First off, let me say thanks in advance and admit that I am a noob to NAS and zfs and undoubtedly broke rules in configuring things. I have TrueNAS running as a virtual machine in Proxmox and one day my server went down hard. I believe I had the pool imported in both Proxmox and TrueNAS (now I know better to use shares). After that, I could not get TrueNAS to boot because it fails to import the pool. At this point, I believe the pool to be completely broken and have no hope to fix it, but I would like to recover as many files as I can.
What I've tried:
I followed the steps here: https://www.truenas.com/community/threads/zfs-has-failed-you.11951/ to boot TrueNAS using Escape to Loader and boot to shell. I have then imported the pool using. The import succeeds, but I can't find any of the files in where I would expect them.
returns the following:
Attempting to mount without causes the zpool command to hang and nothing helps short of rebooting. I probably have killed the pool, but is there any chance to get my files back? I am confused about why the pool imports and reports ONLINE but the files are not there.
Background:
What I've tried:
zpool import -o readonly=on -fR /mnt/pool pool
/mnt/pool
zpool status -v
pool: pool state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A scan: scrub repaired 240K in 00:18:59 with 0 errors on Sun Nov 12 02:18:59 2023 config: NAME STATE READ WRITE CKSUM pool ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 sdb2 ONLINE 0 0 4 sda2 ONLINE 0 0 4 errors: Permanent errors have been detected in the following files: pool:<0x800e> pool/.system/rrd-b85043590a434da692c02c2416a40e36:<0x22> pool/.system/services:<0x0>
-o readonly=on
