thatotherdude24
- Jan 28, 2018
Hardware -
Version TrueNAS-13.0-U6.1
Intel(R) Core(TM) i3-10100 CPU @ 3.60GHz
32gb RAM
120gb ssd boot
2x14tb
1x2tb
1x6tb
4x3tb (this is the fauled pool 'pool4')
Today I unplugged 2 of the drives in pool4 while cleaning the box, plugged them back in, booted the box and the pool shows as faulted.
When checking zpool status the pool does not even appear:
root@truenas[~]# zpool status
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0B in 00:01:07 with 0 errors on Sun Jan 28 03:46:07 2024
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
ada3p2 ONLINE 0 0 0
errors: No known data errors
pool: pool1
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
scan: scrub repaired 0B in 06:50:41 with 0 errors on Sun Jan 14 06:50:41 2024
pool1 ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/f1e4ddef-8cad-11ee-abe6-98b785001cb9 ONLINE 0 0 0
gptid/108807b1-8956-11ee-a49c-98b785001cb9 ONLINE 0 0 0
cache
gptid/8199af75-ac13-11ed-9f92-98b785001cb9 ONLINE 0 0 0
errors: 1 data errors, use '-v' for a list
pool: pool3
state: ONLINE
scan: scrub in progress since Sun Feb 4 00:00:01 2024
1.87T scanned at 777M/s, 332G issued at 135M/s, 2.10T total
0B repaired, 15.49% done, 03:49:36 to go
pool3 ONLINE 0 0 0
gptid/8d4e5060-84e6-11ee-85ba-98b785001cb9 ONLINE 0 0 0
When I try to import the pool I get this message:
root@truenas[~]# zpool import -F
pool: pool4
state: FAULTED
status: One or more devices are missing from the system.
action: The pool cannot be imported. Attach the missing
devices and try again.
The pool may be active on another system, but can be imported using
the '-f' flag.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-3C
pool4 FAULTED corrupted data
raidz1-0 DEGRADED
gptid/75beb47a-aa44-11ee-b2b4-98b785001cb9 ONLINE
gptid/b8397dd4-3535-11ed-9b15-98b785001cb9 ONLINE
gptid/b82a6dbe-3535-11ed-9b15-98b785001cb9 UNAVAIL cannot open
gptid/b8424e59-3535-11ed-9b15-98b785001cb9 ONLINE
root@truenas[~]# zpool import -F pool4
cannot import 'pool4': I/O error
Destroy and re-create the pool from
a backup source.
I knew 1 of the drives was dead and have one coming to replace it but the pool should still be okay since only 1 drive is dead.
Trying to online the pool:
root@truenas[~]# zpool online pool4 /dev/gptid/b82a6dbe-3535-11ed-9b15-98b785001cb9
cannot open 'pool4': no such pool
When I try and disconnect the pool from the GUI I get this error message:
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 355, in run
await self.future
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 391, in __run_body
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 981, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 1608, in export
disks = [i async for i in await self.middleware.call('pool.get_disks', oid)]
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 1608, in <listcomp>
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 1059, in get_disks
disk_path = os.path.join('/dev', d['devname'])
KeyError: 'devname'
Anybody have any suggestions or is my data gone?
32gb RAM
120gb ssd boot
2x14tb
1x2tb
1x6tb
pool: freenas-boot
state: ONLINE
ada3p2 ONLINE 0 0 0
pool: pool1
state: ONLINE
pool1 ONLINE 0 0 0
cache
pool: pool3
state: ONLINE
pool3 ONLINE 0 0 0
pool: pool4
state: FAULTED
the '-f' flag.
raidz1-0 DEGRADED
a backup source.
await self.future
KeyError: 'devname'
