Surferride
- Oct 1, 2023
Hi Community,
I am migrating from a Synology NAS DS1513+ which has been running for 10 years so far. But I am not in good mood with what Synology is doing nowadays (older processors, lock down environment, lack of proper compatibility with big drives pushing for their own brand, etc.) So I am thinking on building a server with TrueNAS or unRAID that would allow me to run not only the NAS but has also enough power VMs, Plex Server, Containers, etc.
I am inclined to go for the Supermicro SuperWorkstation 531A-IL which has the W680 chipset and would allow me to have a Gen 13 Intel processor with a lot of power and integrated iGPU for hardware transcoding when needed. And I think (if I am not mistaken) it should be quite power efficient no?.
I´ve been doing a lot of research, if I end up using ZFS, I understand I would benefit of ECC RAM, but there are very limited options in regards to motherboards that dont cost a fortune and support Intel Gen 13th gen. I also would like to have 2 x M2 fast nVME drives mirrored for cache or boot volumes that will hold all the containers too so they are snappy. I already purchased 2x Seagate EXOS 20 TB CMR drives that I understand should go well with whatever I decide to build.
Electricity costs here in Switzerland have skyrocketed so I would like to keep things running as smooth as possible, for example spinning down drives in the night if not needed and any other good best practice. I plan to use the current or a new UPS with the system to protect it in case of power outage and have it properly shut down.
I plan to backup to locally attached external USB drives, and also against the old Synology NAS DS1513+ while its till running, maybe I even consider taking this old NAS to a friends house for remote backup.
What do you think about my plan? Any other recommendations on hardware? Another alternative is to build another less powerful type of NAS and run the containers and Plex in something like a Beelink or Intel NUC which I also understand can be power efficient. This Intel NUC style of PC could also have the external USB drives for loal backups attached to it.
For now I am running my network at 1Gbps, but would start thinking to be able to upgrade my house to 10 Gbps to benefit from my local internet provider speeds offering 10 Gbps for USD 10 more than what I am paying now.
Sorry for the extense of this post, and thank you for your time reading it and suggesting ideas and components.
