Dec 3 09:05:17 freenas (da0:mps2:0:10:0): SYNCHRONIZE CACHE(10). CDB: 35 00 00 00 00 00 00 00 00 00 length 0 SMID 474 command timeout cm 0xfffffe0002183e20 ccb 0xfffff80a375a7000
Dec 3 09:05:17 freenas (noperiph:mps2:0:4294967295:0): SMID 1 Aborting command 0xfffffe0002183e20
Dec 3 09:05:17 freenas mps2: Sending reset from mpssas_send_abort for target ID 10
Dec 3 09:05:17 freenas (da0:mps2:0:10:0): READ(16). CDB: 88 00 00 00 00 01 f6 52 11 90 00 00 00 10 00 00 length 8192 SMID 851 terminated ioc 804b scsi 0 state c xfer 0
Dec 3 09:05:17 freenas (da0:mps2:0:10:0): WRITE(16). CDB: 8a 00 00 00 00 02 99 a7 5e 10 00 00 00 08 00 00 length 4096 SMID 766 terminated ioc 804b s(da0:mps2:0:10:0): READ(16). CDB: 88 00 00 00 00 01 f6 52 11 90 00 00 00 10 00 00
Dec 3 09:05:17 freenas csi 0 state c xfer 0
Dec 3 09:05:17 freenas (da0:mps2:0:10:0): CAM status: CCB request completed with an error
Dec 3 09:05:17 freenas (da0:mps2:0: (da0:mps2:0:10:0): WRITE(16). CDB: 8a 00 00 00 00 02 99 a7 67 78 00 00 00 18 00 00 length 12288 SMID 456 terminated ioc 804b 10:scsi 0 state c xfer 0
Dec 3 09:05:17 freenas 0): Retrying command
Dec 3 09:05:17 freenas (da0:mps2:0:10:0): SYNCHRONIZE CACHE(10). CDB: 35 00 00 00 00 00 00 00 00 00 length 0 SMID 89 terminated ioc 804b scsi 0 state c xfer 0
Dec 3 09:05:17 freenas (da0:mps2:0:10:0): READ(16). CDB: 88 00 00 00 00 01 cd 7f 3e a0 00 00 00 40 00 00 length 32768 SMID 917 terminated ioc 804b s(da0:mps2:0:10:0): CAM status: CCB request completed with an error
Dec 3 09:05:17 freenas (da0:mps2:0:10:0): Retrying command
Dec 3 09:05:17 freenas (da0:mps2:0:10:0): WRITE(16). CDB: 8a 00 00 00 00 02 99 a7 67 78 00 00 00 18 00 00
Dec 3 09:05:17 freenas (da0:mps2:0:10:0): WRITE(16). CDB: 8a 00 00 00 00 02 99 a7 67 a0 00 00 00 08 00 00 length 4096 SMID 420 terminated ioc 804b s(da0:mps2:0:10:0): READ(16). CDB: 88 00 00 00 00 01 cd 7f 3e a0 00 00 00 40 00 00
Dec 3 09:05:17 freenas mps2: Unfreezing devq for target ID 10
Dec 3 09:05:17 freenas (da0:mps2:0:10:0): CAM status: Command timeout
Dec 3 09:05:18 freenas (da0:mps2:0:10:0): SYNCHRONIZE CACHE(10). CDB: 35 00 00 00 00 00 00 00 00 00
Dec 3 09:05:18 freenas (da0:mps2:0:10:0): CAM status: SCSI Status Error
Dec 3 09:05:18 freenas (da0:mps2:0:10:0): SCSI status: Check Condition
Dec 3 09:05:18 freenas (da0:mps2:0:10:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred)
Dec 3 09:05:18 freenas (da0:mps2:0:10:0): Error 6, Retries exhausted
Dec 3 09:05:18 freenas (da0:mps2:0:10:0): Invalidating pack
Dec 3 09:05:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=56487936, length=4096)]
Dec 3 09:05:18 freenas swap_pager: I/O error - pagein failed; blkno 538080,size 4096, error 6
Dec 3 09:05:18 freenas GEOM_ELI: vm_fault: pager read error, pid 1823 (devd)
Dec 3 09:05:18 freenas g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=91082752, length=4096)]
Dec 3 09:05:18 freenas swap_pager: I/O error - pagein failed; blkno 546526,size 4096, error 6
Dec 3 09:05:18 freenas vm_fault: pager read error, pid 4168 (zfsd)
Dec 3 09:05:18 freenas GEOM_ELI: g_eli_write_done() failed (error=6) gptid/bda22312-c626-11e7-bce5-0cc47a12fd2c.eli[WRITE(offset=5715776118784, length=8192)]
Dec 3 09:05:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) gptid/bda22312-c626-11e7-bce5-0cc47a12fd2c.eli[READ(offset=270336, length=8192)]
Dec 3 09:05:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) gptid/bda22312-c626-11e7-bce5-0cc47a12fd2c.eli[READ(offset=9998683086848, length=8192)]
Dec 3 09:05:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) gptid/bda22312-c626-11e7-bce5-0cc47a12fd2c.eli[READ(offset=9998683348992, length=8192)]
Dec 3 09:05:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=44548096, length=16384)]
Dec 3 09:05:18 freenas swap_pager: I/O error - pagein failed; blkno 535165,size 16384, error 6
Dec 3 09:05:18 freenas vm_fault: pager read error, pid 1823 (devd)
Dec 3 09:05:18 freenas kernel: Failed to fully fault in a core file segment at VA 0x720000 with size 0x14000 to be written at offset 0x6000 for process devd
Dec 3 09:05:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=58597376, length=32768)]
Dec 3 09:05:18 freenas swap_pager: I/O error - pagein failed; blkno 538595,size 32768, error 6
Dec 3 09:05:18 freenas kernel: Failed to fully fault in a core file segment at VA 0x800679000 with size 0x2f000 to be written at offset 0xf000 for process zfsd
Dec 3 09:05:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=91029504, length=8192)]
Dec 3 09:05:18 freenas swap_pager: I/O error - pagein failed; blkno 546513,size 8192, error 6
Dec 3 09:05:18 freenas kernel: Failed to fully fault in a core file segment at VA 0x80086f000 with size 0x2000 to be written at offset 0x3e000 for process zfsd
Dec 3 09:05:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=90959872, length=4096)]
Dec 3 09:05:18 freenas swap_pager: I/O error - pagein failed; blkno 546496,size 4096, error 6
Dec 3 09:05:18 freenas kernel: Failed to fully fault in a core file segment at VA 0x8010e4000 with size 0x1000 to be written at offset 0x47000 for process zfsd
Dec 3 09:05:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=42987520, length=4096)]
Dec 3 09:05:18 freenas swap_pager: I/O error - pagein failed; blkno 534784,size 4096, error 6
Dec 3 09:05:18 freenas kernel: Failed to fully fault in a core file segment at VA 0x800800000 with size 0x800000 to be written at offset 0x1a000 for process devd
Dec 3 09:05:18 freenas kernel: pid 1823 (devd), uid 0: exited on signal 11 (core dumped)
Dec 3 09:05:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=91037696, length=4096)]
Dec 3 09:05:18 freenas swap_pager: I/O error - pagein failed; blkno 546515,size 4096, error 6
Dec 3 09:05:18 freenas kernel: Failed to fully fault in a core file segment at VA 0x80171a000 with size 0x1000 to be written at offset 0x4b000 for process zfsd
Dec 3 09:05:19 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=58589184, length=8192)]
Dec 3 09:05:19 freenas swap_pager: I/O error - pagein failed; blkno 538593,size 8192, error 6
Dec 3 09:05:19 freenas vm_fault: pager read error, pid 4168 (zfsd)
Dec 3 09:05:19 freenas kernel: Failed to fully fault in a core file segment at VA 0x80201b000 with size 0x2000 to be written at offset 0x57000 for process zfsd
Dec 3 09:05:19 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=52162560, length=4096)]
Dec 3 09:05:19 freenas swap_pager: I/O error - pagein failed; blkno 537024,size 4096, error 6
Dec 3 09:05:19 freenas kernel: Failed to fully fault in a core file segment at VA 0x802e21000 with size 0x1000 to be written at offset 0x82000 for process zfsd
Dec 3 09:05:19 freenas GEOM_ELI: g_eli_read_done() failed (error=6) gptid/bda22312-c626-11e7-bce5-0cc47a12fd2c.eli[READ(offset=270336, length=8192)]
Dec 3 09:05:19 freenas GEOM_ELI: g_eli_read_done() failed (error=6) gptid/bda22312-c626-11e7-bce5-0cc47a12fd2c.eli[READ(offset=9998683086848, length=8192)]
Dec 3 09:05:19 freenas GEOM_ELI: g_eli_read_done() failed (error=6) gptid/bda22312-c626-11e7-bce5-0cc47a12fd2c.eli[READ(offset=9998683348992, length=8192)]
Dec 3 09:05:19 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=91074560, length=8192)]
Dec 3 09:05:19 freenas swap_pager: I/O error - pagein failed; blkno 546524,size 8192, error 6
Dec 3 09:05:19 freenas kernel: Failed to fully fault in a core file segment at VA 0x803400000 with size 0x400000 to be written at offset 0x91000 for process zfsd
Dec 3 09:05:19 freenas kernel: pid 4168 (zfsd), uid 0: exited on signal 11 (core dumped)
Dec 3 09:05:36 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=96337920, length=12288)]
Dec 3 09:05:36 freenas swap_pager: I/O error - pagein failed; blkno 547809,size 12288, error 6
Dec 3 09:05:36 freenas vm_fault: pager read error, pid 3492 (python3.6)
Dec 3 09:05:36 freenas kernel: pid 3492 (python3.6), uid 0: exited on signal 11
Dec 3 09:32:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=95301632, length=4096)]
Dec 3 09:32:18 freenas swap_pager: I/O error - pagein failed; blkno 547556,size 4096, error 6
Dec 3 09:32:18 freenas vm_fault: pager read error, pid 3536 (consul)
Dec 3 09:32:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=95199232, length=32768)]
Dec 3 09:32:18 freenas swap_pager: I/O error - pagein failed; blkno 547531,size 32768, error 6
Dec 3 09:32:18 freenas vm_fault: pager read error, pid 4395 (consul)
Dec 3 09:32:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=58458112, length=12288)]
Dec 3 09:32:18 freenas swap_pager: I/O error - pagein failed; blkno 538561,size 12288, error 6
Dec 3 09:32:18 freenas vm_fault: pager read error, pid 3535 (daemon)
Dec 3 09:32:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=58466304, length=4096)]
Dec 3 09:32:18 freenas swap_pager: I/O error - pagein failed; blkno 538563,size 4096, error 6
Dec 3 09:32:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=94666752, length=32768)]
Dec 3 09:32:18 freenas swap_pager: I/O error - pagein failed; blkno 547401,size 32768, error 6
Dec 3 09:32:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=85229568, length=8192)]
Dec 3 09:32:18 freenas swap_pager: I/O error - pagein failed; blkno 545097,size 8192, error 6
Dec 3 09:32:18 freenas kernel: Failed to fully fault in a core file segment at VA 0x800821000 with size 0x2000 to be written at offset 0x27000 for process daemon
Dec 3 09:32:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=58494976, length=65536)]
Dec 3 09:32:18 freenas swap_pager: I/O error - pagein failed; blkno 538570,size 65536, error 6
Dec 3 09:32:18 freenas vm_fault: pager read error, pid 3539 (daemon)
Dec 3 09:32:18 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=58470400, length=24576)]
Dec 3 09:32:18 freenas swap_pager: I/O error - pagein failed; blkno 538564,size 24576, error 6
Dec 3 09:32:18 freenas kernel: Failed to fully fault in a core file segment at VA 0x800e00000 with size 0x400000 to be written at offset 0x4f000 for process daemon
Dec 3 09:32:43 freenas GEOM_ELI: g_eli_read_done() failed (error=6) da0p1.eli[READ(offset=95264768, length=8192)]
Dec 3 09:32:43 freenas swap_pager: I/O error - pagein failed; blkno 547547,size 8192, error 6
Dec 3 09:32:43 freenas vm_fault: pager read error, pid 4396 (consul)
