SOLVED Raidz-1 Pool will not import - One or more devices missing from system
dexbot
THIS ISSUE HAS BEEN RESOLVED! Please see the update in my last post
First things first thank you for reading and I am very new to Freenas but I am loving it so far.
I have six 8Tb drives in a Raidz-1 Pool. A few days ago I went to access the server and saw the critical alert "The volume Main state is UNKNOWN"
It seems as though I had 2 drives fail at the same time! But I am not sute since all 6 drives in the pool appear to have passed both a short and long SMART scan with zero errors. I am not sure where to look to resolve this issue.
NOTE: I have a full backup of all this data. I just want to see if I can recover the pool!
Freenas Version 11.1-u6
System Specs
  • motherboard
    INTEL GA-7TESM GIGABYTE REV 1.0 LGA 1366 SYSTEM BOARD WITH 2X HEATSINKS
  • Intel Xeon X5670 (Dual)
  • Hynix 4GB 2Rx4 DDR3-1066 PC3-8500R REG ECC (8 sticks)
  • Drives - 6 HGST Ultrastar HUH728080ALE600 He8 8TB 7200RPM SATA 6Gbps 128MB HDD in RaidZ-1
  • HP 487738-001 468405-001 24-Bay 3Gb SAS Expander Card
    All 6 drives connect here
  • Onboard Network and
    671798-001 COMPATIBLE 10GB MELLANOX CONNECTX-2 PCIe 10GBe ETHERNET NIC
I did the normal troubleshooting stuff that I know such as:
gpart list
gpart show
zpool import
smartctl -a -q noserial /dev/ada2
camcontrol devlist
glabel status
Here are the results of those commands if that is useful to help me see where the issue lies.
gpart list
Geom name: da0
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 15628053127
first: 40
entries: 152
scheme: GPT
Providers:
1. Name: da0p1
   Mediasize: 2147483648 (2.0G)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   rawuuid: 9802661b-a95b-11e8-b424-50e549a919b4
   rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: da0p2
   Mediasize: 7999415648256 (7.3T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   rawuuid: 9808f2b7-a95b-11e8-b424-50e549a919b4
   rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 7999415648256
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 15628053119
   start: 4194432
Consumers:
1. Name: da0
   Mediasize: 8001563222016 (7.3T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
Geom name: da1
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 15628053127
first: 40
entries: 152
scheme: GPT
Providers:
1. Name: da1p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   rawuuid: 98ce6d16-a95b-11e8-b424-50e549a919b4
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: da1p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   rawuuid: 98d88503-a95b-11e8-b424-50e549a919b4
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 15628053119
   start: 4194432
Consumers:
1. Name: da1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r2w2e5
Geom name: da2
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 15628053127
first: 40
entries: 152
scheme: GPT
Providers:
1. Name: da2p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   rawuuid: 99876822-a95b-11e8-b424-50e549a919b4
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: da2p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   rawuuid: 998f6e83-a95b-11e8-b424-50e549a919b4
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 15628053119
   start: 4194432
Consumers:
1. Name: da2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
Geom name: da3
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 15628053127
first: 40
entries: 152
scheme: GPT
Providers:
1. Name: da3p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   rawuuid: 9a40cc18-a95b-11e8-b424-50e549a919b4
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: da3p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   rawuuid: 9a4fec72-a95b-11e8-b424-50e549a919b4
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 15628053119
   start: 4194432
Consumers:
1. Name: da3
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r2w2e5
Geom name: da4
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 15628053127
first: 40
entries: 152
scheme: GPT
Providers:
1. Name: da4p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   rawuuid: 9b0e0929-a95b-11e8-b424-50e549a919b4
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: da4p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   rawuuid: 9b17a335-a95b-11e8-b424-50e549a919b4
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 15628053119
   start: 4194432
Consumers:
1. Name: da4
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r2w2e5
Geom name: da5
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 15628053127
first: 40
entries: 152
scheme: GPT
Providers:
1. Name: da5p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   rawuuid: 9bd41a70-a95b-11e8-b424-50e549a919b4
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: da5p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   rawuuid: 9bdba397-a95b-11e8-b424-50e549a919b4
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 15628053119
   start: 4194432
Consumers:
1. Name: da5
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r2w2e5
Geom name: da6
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 60481495
first: 40
entries: 152
scheme: GPT
Providers:
1. Name: da6p1
   Mediasize: 524288 (512K)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 20480
   Mode: r0w0e0
   rawuuid: fa803646-02c0-11e8-a31a-50e549a919b4
   rawtype: 21686148-6449-6e6f-744e-656564454649
   label: (null)
   length: 524288
   offset: 20480
   type: bios-boot
   index: 1
   end: 1063
   start: 40
2. Name: da6p2
   Mediasize: 30965977088 (29G)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 544768
   Mode: r1w1e1
   rawuuid: fa934772-02c0-11e8-a31a-50e549a919b4
   label: (null)
   length: 30965977088
   offset: 544768
   type: freebsd-zfs
   index: 2
   end: 60481487
   start: 1064
Consumers:
1. Name: da6
   Mediasize: 30966546432 (29G)
   Sectorsize: 512
   Mode: r1w1e2
% zpool import
cannot discover pools: permission denied
% sudo zpool import
Password:
   pool: Main
  state: UNAVAIL
 status: One or more devices are missing from the system.
 action: The pool cannot be imported. Attach the missing
		devices and try again.
   see: http://illumos.org/msg/ZFS-8000-3C
		Main												UNAVAIL  insufficient replicas
		  raidz1-0										  UNAVAIL  insufficient replicas
			16993394389927727012							UNAVAIL  cannot open
			gptid/98d88503-a95b-11e8-b424-50e549a919b4.eli  ONLINE
			10870168831879138980							UNAVAIL  cannot open
			gptid/9a4fec72-a95b-11e8-b424-50e549a919b4.eli  ONLINE
			gptid/9b17a335-a95b-11e8-b424-50e549a919b4.eli  ONLINE
			gptid/9bdba397-a95b-11e8-b424-50e549a919b4.eli  ONLINE
gpart show
=>		 40  15628053088  da0  GPT  (7.3T)
		   40		   88	   - free -  (44K)
		  128	  4194304	1  freebsd-swap  (2.0G)
	  4194432  15623858688	2  freebsd-zfs  (7.3T)
  15628053120			8	   - free -  (4.0K)
=>		 40  15628053088  da1  GPT  (7.3T)
=>		 40  15628053088  da2  GPT  (7.3T)
=>		 40  15628053088  da3  GPT  (7.3T)
=>		 40  15628053088  da4  GPT  (7.3T)
=>		 40  15628053088  da5  GPT  (7.3T)
=>	  40  60481456  da6  GPT  (29G)
		40	  1024	1  bios-boot  (512K)
	  1064  60480424	2  freebsd-zfs  (29G)
  60481488		 8	   - free -  (4.0K)
zpool import
   pool: Main
  state: UNAVAIL
camcontrol devlist
<ATA HGST HUH728080AL T514>		at scbus0 target 8 lun 0 (pass0,da0)
<ATA HGST HUH728080AL T514>		at scbus0 target 9 lun 0 (pass1,da1)
<ATA HGST HUH728080AL T514>		at scbus0 target 10 lun 0 (pass2,da2)
<ATA HGST HUH728080AL T514>		at scbus0 target 11 lun 0 (pass3,da3)
<ATA HGST HUH728080AL T514>		at scbus0 target 12 lun 0 (pass4,da4)
<ATA HGST HUH728080AL T514>		at scbus0 target 13 lun 0 (pass5,da5)
<HP HP SAS EXP Card 2.06>		  at scbus0 target 14 lun 0 (ses0,pass6)
<Kingston DataTraveler 2.0 PMAP>   at scbus6 target 0 lun 0 (pass7,da6)
glabel status
gptid/9808f2b7-a95b-11e8-b424-50e549a919b4	 N/A  da0p2
gptid/98d88503-a95b-11e8-b424-50e549a919b4	 N/A  da1p2
gptid/998f6e83-a95b-11e8-b424-50e549a919b4	 N/A  da2p2
gptid/9a4fec72-a95b-11e8-b424-50e549a919b4	 N/A  da3p2
gptid/9b17a335-a95b-11e8-b424-50e549a919b4	 N/A  da4p2
gptid/9bdba397-a95b-11e8-b424-50e549a919b4	 N/A  da5p2
gptid/fa803646-02c0-11e8-a31a-50e549a919b4	 N/A  da6p1
sudo smartctl -a -q noserial --device=scsi da0
(I get the same result for da0-da5. All six drives are ok according to this)
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
User Capacity:		8,001,563,222,016 bytes [8.00 TB]
Logical block size:   512 bytes
Physical block size:  4096 bytes
LU is fully provisioned
Rotation Rate:		7200 rpm
Form Factor:		  3.5 inches
Device type:		  disk
Local Time is:		Wed Oct 10 20:29:04 2018 EDT
SMART support is:	 Available - device has SMART capability.
SMART support is:	 Enabled
Temperature Warning:  Disabled or Not Supported
SMART Health Status: OK
Current Drive Temperature:	 27 C
Drive Trip Temperature:		0 C
Error Counter logging not supported
[GLTSD (Global Logging Target Save Disable) set. Enable Save with '-S on']
SMART Self-test log
Num  Test			  Status				 segment  LifeTime  LBA_first_err [SK ASC ASQ]
	 Description							  number   (hours)
# 1  Background long   Completed				   -   25942				 - [-   -	-]
# 2  Background short  Completed				   -   25927				 - [-   -	-]
Long (extended) Self Test duration: 65535 seconds [1092.2 minutes]
I am not sure what to do next. I have not tried removing and readding the pool. Is that an option? or will I lose all the data?
dexbot
Well I still have not resolved this issue. Anyone have any ideas?
My current plan is to try the following tomorrow if time permits.
  • Re-seat drive connectors
  • Boot to Ununtu Live CD and test from there
  • Try moving drives from SAS controller (with SATA cables) to the onboard SATA ports
  • Try exchanging the SAS controller with another identical one from another PC I have.
What were the results of those things you tried? And from the Ubuntu live CD, what happens if you try zpool import?
dexbot
I have not had a chance to use the Ubuntu Live CD yet unfortunately. I am hoping tomorrow. I have to unrack the box and move it to my workbench and I just have not had a free moment.
The results of the zpool import is as follows
  pool: Main
  state: UNAVAIL
dexbot
Same error message when using Ubuntu Live CD =(
I swapped out the SAS card with an exact known good replacement but I still get the same error message.
Later tonight I will try to connect the drives directly to the SATA ports on the board bypassing the SAS card completely and try again.
As I said I ran a short and long SMART scan on the drives and they all report OK, so are the drives themselves OK? I guess I don't know how to see the actual "report" besides when i run
It says within the readout forall 6 hard drives that:
Is there a way to see more information about a particular scan number?
Thanks!
So that rules out the OS as a source of the problem.
Scroll further down in the report, you'll see a part that looks like this:
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline	Completed without error	   00%	 33239		 -
# 2  Short offline	   Completed without error	   00%	 33228		 -
# 3  Short offline	   Completed without error	   00%	 33204		 -
# 4  Short offline	   Completed without error	   00%	 33180		 -
# 5  Short offline	   Completed without error	   00%	 33156		 -
# 6  Short offline	   Completed without error	   00%	 33132		 -
dexbot
Here is the complete output of the following command:
The results show the same for all 6 drives da0-da5
Nothing shows in the LBA_first_err [SK ASC ASQ] columns on the output from all 6 drives
Device type:		  disk
Local Time is:		Sat Oct 20 21:07:52 2018 EDT
Current Drive Temperature:	 29 C
SMART Self-test log
# 1  Background short  Completed				   -   26031				 - [-   -	-]
# 2  Background short  Completed				   -   25982				 - [-   -	-]
# 3  Background long   Completed				   -   25942				 - [-   -	-]
# 4  Background short  Completed				   -   25927				 - [-   -	-]
dexbot
If this is useful I do get this error message during boot from both SAS controllers I have used. I have been getting this error for a while but the system worked normally even after reboots. I was unable to find anything online on how to resolve this error and it may actually be nothing or unrelated to this issue but I thought I would mention it.
g8HvpMa
Can't help with the problem but that boot error is because of the HP expander and nothing to worry about, I have the same.
JohnK
Just wondering, are you using hardware raid?
dexbot
No hardware raid. I was under the assumption that hardware raid is a bad idea when using zfs
JohnK
Yes it is bad. I’m not familiar with your hardware, other than readimg that it comes with onboard SAS with Raid.
Read some other forum posts where people had the same error after using hardware raid. So worth asking.
Stux
Don’t know enough about the encryption layer, except to point out that before you can mount the pool you have to be able to decrypt the device.
Are you getting that far?
dexbot
Ahh I was not aware of that. The pool is encrypted and I did back up the key.
How would I go about decrypting the pool?
dexbot
Oops.. of course I am unable to decrypt the array as I cannot mount it to begin the process. =)
JohnK
Just to confirm. Your SAS expander is plugged into your onboard LSI SAS and that has been flushed to IT mode?
dexbot
That is correct. The current configuration has been unchanged since August. It just failed to mount the pool last week sometime. So previously I had several months of uptime with this set up exactly as it is.
