Raid-Z2 won't fix checksum error?
meowmeows
Hey guys,
I'm in a tough spot here. I have a 10 disk Raid-Z2 config that has checksum errors that a scrub won't correct. It's on a TS140 server with a Perc H310 in IT mode. It has 32GB of ECC RAM that passes memtest86. Several of the drives are on the intel SATA controller, including /dev/ada2.
System log shows this:
Apr 14 12:23:14 meowmeows smartd[2651]: Device: /dev/ada2, 1 Currently unreadable (pending) sectors
Apr 14 12:23:14 meowmeows smartd[2651]: Device: /dev/ada2, 1 Offline uncorrectable sectors
zpool status:
zpool status
  pool: meowtank
state: ONLINE
  corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
  entire pool from backup.
  see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 0 in 2h33m with 2 errors on Thu Apr 13 22:53:59 2017
  NAME  STATE  READ WRITE CKSUM
  meowtank  ONLINE  0  0  2
  raidz2-0  ONLINE  0  0  4
  gptid/bdbcd68a-1ce8-11e7-980b-fc4dd4d2bec9  ONLINE  0  0  0
  gptid/be32356b-1ce8-11e7-980b-fc4dd4d2bec9  ONLINE  0  0  0
  gptid/be633c02-1ce8-11e7-980b-fc4dd4d2bec9  ONLINE  0  0  0
  gptid/be87fb6f-1ce8-11e7-980b-fc4dd4d2bec9  ONLINE  0  0  0
  gptid/bfc1d69d-1ce8-11e7-980b-fc4dd4d2bec9  ONLINE  0  0  0
  gptid/c00a52e2-1ce8-11e7-980b-fc4dd4d2bec9  ONLINE  0  0  0
  gptid/c09b05e3-1ce8-11e7-980b-fc4dd4d2bec9  ONLINE  0  0  0
  gptid/c0b60379-1ce8-11e7-980b-fc4dd4d2bec9  ONLINE  0  0  0
  gptid/c0fe6af3-1ce8-11e7-980b-fc4dd4d2bec9  ONLINE  0  0  0
  gptid/c1ff04b8-1ce8-11e7-980b-fc4dd4d2bec9  ONLINE  0  0  0
Smart shows the following:
smartctl -ax /dev/ada2
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:	 WL3000GSA6472E
Serial Number:	WOL240275551
LU WWN Device Id: 5 0014ee 25df939e5
Firmware Version: 01.01A01
User Capacity:	3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	7200 rpm
Device is:		Not in smartctl database [for details use: -P showall]
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Fri Apr 14 13:05:36 2017 PDT
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Disabled
Rd look-ahead is: Enabled
Write cache is:   Enabled
ATA Security is:  Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
										was completed without error.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				(31680) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 344) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x70bd) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAGS	VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate	 POSR-K   200   200   051	-	1
  3 Spin_Up_Time			POS--K   151   141   021	-	11441
  4 Start_Stop_Count		-O--CK   100   100   000	-	61
  5 Reallocated_Sector_Ct   PO--CK   200   200   140	-	0
  7 Seek_Error_Rate		 -OSR-K   200   200   000	-	0
  9 Power_On_Hours		  -O--CK   064   064   000	-	26785
10 Spin_Retry_Count		-O--CK   100   253   000	-	0
11 Calibration_Retry_Count -O--CK   100   253   000	-	0
12 Power_Cycle_Count	   -O--CK   100   100   000	-	61
183 Runtime_Bad_Block	   -O--CK   100   100   000	-	0
192 Power-Off_Retract_Count -O--CK   200   200   000	-	26
193 Load_Cycle_Count		-O--CK   200   200   000	-	34
194 Temperature_Celsius	 -O---K   115   103   000	-	37
196 Reallocated_Event_Count -O--CK   200   200   000	-	0
197 Current_Pending_Sector  -O--CK   200   200   000	-	1
198 Offline_Uncorrectable   ----CK   200   200   000	-	1
199 UDMA_CRC_Error_Count	-O--CK   200   200   000	-	0
200 Multi_Zone_Error_Rate   ---R--   200   200   000	-	7
							||||||_ K auto-keep
							|||||__ C event count
							||||___ R error rate
							|||____ S speed/performance
							||_____ O updated online
							|______ P prefailure warning
General Purpose Log Directory Version 1
SMART		   Log Directory Version 1 [multi-sector log support]
Address	Access  R/W   Size  Description
0x00	   GPL,SL  R/O	  1  Log Directory
0x01		   SL  R/O	  1  Summary SMART error log
0x02		   SL  R/O	  5  Comprehensive SMART error log
0x03	   GPL	 R/O	  6  Ext. Comprehensive SMART error log
0x04	   GPL,SL  R/O	  8  Device Statistics log
0x06		   SL  R/O	  1  SMART self-test log
0x07	   GPL	 R/O	  1  Extended self-test log
0x08	   GPL	 R/O	  2  Power Conditions log
0x09		   SL  R/W	  1  Selective self-test log
0x10	   GPL	 R/O	  1  SATA NCQ Queued Error log
0x11	   GPL	 R/O	  1  SATA Phy Event Counters log
0x24	   GPL	 R/O	  1  Current Device Internal Status Data log
0x80-0x9f  GPL,SL  R/W	 16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS	  16  Device vendor specific log
0xa8-0xb7  GPL,SL  VS	   1  Device vendor specific log
0xbd	   GPL,SL  VS	   1  Device vendor specific log
0xc0	   GPL,SL  VS	   1  Device vendor specific log
0xc1	   GPL	 VS	  93  Device vendor specific log
0xe0	   GPL,SL  R/W	  1  SCT Command/Status
0xe1	   GPL,SL  R/W	  1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
No Errors Logged
SMART Error Log Version: 1
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline	Completed without error	   00%	 26781		 -
# 2  Short offline	   Completed without error	   00%	 26050		 -
# 3  Short offline	   Completed without error	   00%	 25955		 -
# 4  Extended offline	Completed without error	   00%	 25795		 -
# 5  Short offline	   Completed without error	   00%	 25646		 -
# 6  Short offline	   Completed without error	   00%	 25551		 -
# 7  Extended offline	Completed without error	   00%	 25461		 -
# 8  Short offline	   Completed without error	   00%	 25407		 -
# 9  Short offline	   Completed without error	   00%	 25311		 -
#10  Short offline	   Completed without error	   00%	 25167		 -
#11  Extended offline	Completed without error	   00%	 25125		 -
#12  Short offline	   Completed without error	   00%	 25047		 -
#13  Short offline	   Completed without error	   00%	 24903		 -
#14  Short offline	   Completed without error	   00%	 24807		 -
#15  Extended offline	Completed without error	   00%	 24718		 -
#16  Short offline	   Completed without error	   00%	 24663		 -
#17  Short offline	   Completed without error	   00%	 24567		 -
#18  Short offline	   Completed without error	   00%	 24424		 -
#19  Extended offline	Completed without error	   00%	 24382		 -
#20  Short offline	   Completed without error	   00%	 24304		 -
#21  Short offline	   Completed without error	   00%	 24160		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
SCT Status Version:				  3
SCT Version (vendor specific):	   258 (0x0102)
SCT Support Level:				   1
Device State:						Active (0)
Current Temperature:					37 Celsius
Power Cycle Min/Max Temperature:	 25/37 Celsius
Lifetime	Min/Max Temperature:	  0/49 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:	 2
Temperature Sampling Period:		 1 minute
Temperature Logging Interval:		1 minute
Min/Max recommended Temperature:	  0/60 Celsius
Min/Max Temperature Limit:		   -41/85 Celsius
Temperature History Size (Index):	478 (263)
Index	Estimated Time   Temperature Celsius
264	2017-04-14 05:08	34  ***************
265	2017-04-14 05:09	34  ***************
266	2017-04-14 05:10	33  **************
...	..( 91 skipped).	..  **************
358	2017-04-14 06:42	33  **************
359	2017-04-14 06:43	34  ***************
...	..( 52 skipped).	..  ***************
412	2017-04-14 07:36	34  ***************
413	2017-04-14 07:37	35  ****************
...	..( 18 skipped).	..  ****************
432	2017-04-14 07:56	35  ****************
433	2017-04-14 07:57	36  *****************
...	..( 24 skipped).	..  *****************
458	2017-04-14 08:22	36  *****************
459	2017-04-14 08:23	37  ******************
...	..( 47 skipped).	..  ******************
  29	2017-04-14 09:11	37  ******************
  30	2017-04-14 09:12	36  *****************
...	..( 69 skipped).	..  *****************
100	2017-04-14 10:22	36  *****************
101	2017-04-14 10:23	35  ****************
...	..(133 skipped).	..  ****************
235	2017-04-14 12:37	35  ****************
236	2017-04-14 12:38	34  ***************
...	..( 26 skipped).	..  ***************
263	2017-04-14 13:05	34  ***************
SCT Error Recovery Control:
		   Read:	 70 (7.0 seconds)
		  Write:	 70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size		Value Flags Description
0x01  =====  =			   =  ===  == General Statistics (rev 2) ==
0x01  0x008  4			  61  ---  Lifetime Power-On Resets
0x01  0x010  4		   26785  ---  Power-on Hours
0x01  0x018  6   5634759502216  ---  Logical Sectors Written
0x01  0x020  6	   704910901  ---  Number of Write Commands
0x01  0x028  6	140317546912  ---  Logical Sectors Read
0x01  0x030  6	  1061479940  ---  Number of Read Commands
0x03  =====  =			   =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4		   25305  ---  Spindle Motor Power-on Hours
0x03  0x010  4		   25305  ---  Head Flying Hours
0x03  0x018  4			  61  ---  Head Load Events
0x03  0x020  4			 200  N--  Number of Reallocated Logical Sectors
0x03  0x028  4			 427  ---  Read Recovery Attempts
0x03  0x030  4			   0  ---  Number of Mechanical Start Failures
0x04  =====  =			   =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4			   0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4			   0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =			   =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1			  37  ---  Current Temperature
0x05  0x010  1			  34  ---  Average Short Term Temperature
0x05  0x018  1			  34  ---  Average Long Term Temperature
0x05  0x020  1			  49  ---  Highest Temperature
0x05  0x028  1			  23  ---  Lowest Temperature
0x05  0x030  1			  46  ---  Highest Average Short Term Temperature
0x05  0x038  1			  30  ---  Lowest Average Short Term Temperature
0x05  0x040  1			  45  ---  Highest Average Long Term Temperature
0x05  0x048  1			  34  ---  Lowest Average Long Term Temperature
0x05  0x050  4			   0  ---  Time in Over-Temperature
0x05  0x058  1			  60  ---  Specified Maximum Operating Temperature
0x05  0x060  4			   0  ---  Time in Under-Temperature
0x05  0x068  1			   0  ---  Specified Minimum Operating Temperature
0x06  =====  =			   =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4			 636  ---  Number of Hardware Resets
0x06  0x010  4			1749  ---  Number of ASR Events
0x06  0x018  4			   0  ---  Number of Interface CRC Errors
								|||_ C monitored condition met
								||__ D supports DSN
								|___ N normalized value
SATA Phy Event Counters (GP Log 0x11)
ID	  Size	 Value  Description
0x0001  2			0  Command failed due to ICRC error
0x0002  2			0  R_ERR response for data FIS
0x0003  2			0  R_ERR response for device-to-host data FIS
0x0004  2			0  R_ERR response for host-to-device data FIS
0x0005  2			0  R_ERR response for non-data FIS
0x0006  2			0  R_ERR response for device-to-host non-data FIS
0x0007  2			0  R_ERR response for host-to-device non-data FIS
0x0008  2			0  Device-to-host non-data FIS retries
0x0009  2		   12  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2		   12  Device-to-host register FISes sent due to a COMRESET
0x000b  2			0  CRC errors within host-to-device FIS
0x000f  2			0  R_ERR response for host-to-device data FIS, CRC
0x0012  2			0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4		60450  Vendor specific
If I try to copy the file through samba, I get a file IO error and it refuses to continue. I thought Raid-Z2 should correct this type of issue on the fly, and if not, a scrub should do it, right? What could possibly be the issue here?
Thanks in advance.
joeschmuck
Old Man
While your drive S/N: WOL240275551 is failing, I doubt it was the cause of the lost files. You are correct that a proper built system should protect against data corruption but it's possible that you have a power issue during a write operation, or maybe you were using FreeNAS 10 and it corrupted your data? You failed to specify your software version as well.
My advice is to delete the two files because they are corrupt and copy on a backup of those files, also replace the failing drive.
Have you checked the SMART status of the other drives in your pool? Are there any values in IDs 5, 196 through 200 ?
meowmeows
Joe,
SMART shows 0 as the raw value for all other drives for ID 5 (Reallocated sectors)
I should have specified that I created the pool from scratch under FreeNAS 10 as I went from a 5 disk Z2 to a 10 disk Z2 at the same time. At some point in the past 2 weeks, the ada2 developed the uncorrectable sector but I didn't deal with it at the time as I was ready to roll back to 9.10.2 U2. I decided to scrub and have ZFS fix the bad data after I rolled back. Initially, 9.10 didn't even detect the volume so I did a factory restore. When I chose to import the volume, 2 pools showed up with different IDs, though I know there should only be 1. I imported the pool and saw that the system could not restore the data. Having heard that the ZFS version has been upgraded since, I updated to 9.10 NIGHTLY (yesterday). This morning, I found that the OS version did not fix anything.
I attached an image of what happens if I try to access the file, same issue without fail every time. I am fortunate to have a recent backup of everything, but I thought a RAID-Z2 system would be immune to this type of error unless three drives failed on the exact same sector. I would hate to run into this issue in the future with a more important file. Would offlining ada2 allow me access to the file? I imagined this scenario to be handled by ZFS in the background.
meowmeows
Copying the file locally to a different pool results in the following:
cp: 00596.m2ts: Input/output error
joeschmuck
Old Man
FreeNAS 10 was not stable and had issues which is the reason it's on hold for a while and work is moving foward on FreeNAS 9.10 instead.
Since you have a full backup of your data would it be asking too much to destroy your pool and rebuild it while running FreeNAS 9.10.2-U2 ? You really may want to do this for peace of mind.
On the other hand, did you delete those files before trying to copy them? If you did then I'd run another scrub. After the scrub I'd try to copy the files back on. Also how are you sharing the file system, SMB?
Again, I'd destroy the pool, install a clean copy of 9.10.2-U2, create the pool. If no problems are encountered then I'd configure the system and start restoring the data.
What about for ID's 196 through 200? Those are important too. I just want you to be certain that you have a good system. And you can use the failing drive to rebuild your system, it alone would not have caused the issue you have. But see if you can RMA that drive as soon as you can, it will fail hard. And run frequent SMART Extended tests on it.
meowmeows
Thanks for your advice. To be clear, I trying to copy the corrupted file from the FreeNAS system. It always happens at the same % when copying (over SMB), and cp gives me a similar io error.
All other drives in the pool show 0 as the raw values for SMART IDs 196-200. I offlined ada2 and your hunch was correct - nothing changed. I'll go ahead and follow your advice and start from scratch with a new pool and 9.10.2 U2, but in the meantime, I'm running badblocks on ada2 to exercise the drive before going through with the new installation.
I'm still baffled that this could happen to a system with a good power supply, UPS, server motherboard, and ECC RAM - but maybe it was just FreeNAS 10.
joeschmuck
Old Man
If your drive is still under warranty then you should RMA it.
Oh yea, you would not have been able to copy it off, the scrub basically said that it couldn't read the entire file and couldn't fix it. These things do happen but can typically be traced back to a hardware issue (power outage, reboot, no ECC RAM, etc...). In your case it also could have been the FreeNAS 10 software, who knows. And you just had bad timing with the drive failure too, or maybe it somehow contributed to it, I don't know and would just be speculating.
rs225
This is unlikely a ZFS, or drive issue. This is typically a system issue.
The number one reason it isn't the drive is that it isn't a read error. If the drive can tell you it has a bad sector, then it can give you a read error if it tries to read that sector. So the two issues (SMART alert and file error) are most likely not (directly) connected.
When ZFS can't assign an error to a drive, it means you either have 3 drives with bad info in the same block(exceeding parity), or the checksum/parity that was computed when the block was written is corrupt. That's where the system issue comes in, no matter how unlikely either of these scenarios may seem, because, there it is.
My advice is to consider how that file got on there, and then attempt to repeat that process and see if the problem repeats. I think someone recently had repeated errors that went away when they changed the drive config, but they can't narrow down the problem to any component. If it's important at that point, you just have to choose completely different hardware and start over.
The good news is ZFS tells you it is happening. In the past, we never knew, or found out too late. And congratulations on having a backup.
