Bhoot
- Mar 28, 2015
Here is a bit of the SMART report I am doubtful about
As you guys can see the disk was failing to go beyond 30% of the extended test. However in the last few tests it has managed to "clear" the hurdle and going to 100%. Can I trust this completely? Can/Should I RMA this disk?
This is the Full SMARTCTL output
SMART Extended Self-test Log Version: 1 (1 sectors) Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 16541 - # 2 Extended offline Completed without error 00% 16456 - # 3 Short offline Completed without error 00% 16373 - # 4 Short offline Completed without error 00% 16204 - # 5 Extended offline Completed without error 00% 16150 - # 6 Short offline Completed without error 00% 16039 - # 7 Short offline Completed without error 00% 15797 - # 8 Extended offline Completed: read failure 70% 15703 880016000 # 9 Short offline Completed without error 00% 15629 - #10 Short offline Completed without error 00% 15464 - #11 Extended offline Completed: read failure 70% 15369 880016000 #12 Short offline Completed without error 00% 15296 - #13 Short offline Completed without error 00% 15078 - #14 Extended offline Completed: read failure 60% 14984 880016000 #15 Short offline Completed without error 00% 14910 - #16 Short offline Completed without error 00% 14745 - #17 Extended offline Completed: read failure 70% 14650 880016000 #18 Short offline Completed without error 00% 14577 - 4 of 4 failed self-tests are outdated by newer successful extended offline self-test # 2
# smartctl -x /dev/ada4 smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p31 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD40EFRX-68WT0N0 Serial Number: WD-WCC4E0ESU744 LU WWN Device Id: 5 0014ee 2623ee4e2 Firmware Version: 82.00A82 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Feb 4 23:10:25 2018 IST SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM feature is: Unavailable Rd look-ahead is: Enabled Write cache is: Enabled ATA Security is: Disabled, frozen [SEC2] Wt Cache Reorder: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (52560) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 526) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0 3 Spin_Up_Time POS--K 181 178 021 - 7933 4 Start_Stop_Count -O--CK 100 100 000 - 74 5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0 7 Seek_Error_Rate -OSR-K 200 200 000 - 0 9 Power_On_Hours -O--CK 078 078 000 - 16775 10 Spin_Retry_Count -O--CK 100 253 000 - 0 11 Calibration_Retry_Count -O--CK 100 253 000 - 0 12 Power_Cycle_Count -O--CK 100 100 000 - 73 192 Power-Off_Retract_Count -O--CK 200 200 000 - 34 193 Load_Cycle_Count -O--CK 200 200 000 - 1484 194 Temperature_Celsius -O---K 116 107 000 - 36 196 Reallocated_Event_Count -O--CK 200 200 000 - 0 197 Current_Pending_Sector -O--CK 200 200 000 - 0 198 Offline_Uncorrectable ----CK 100 253 000 - 0 199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0 200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 0 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 5 Comprehensive SMART error log 0x03 GPL R/O 6 Ext. Comprehensive SMART error log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x09 SL R/W 1 Selective self-test log 0x10 GPL R/O 1 NCQ Command Error log 0x11 GPL R/O 1 SATA Phy Event Counters 0x21 GPL R/O 1 Write stream error log 0x22 GPL R/O 1 Read stream error log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xa0-0xa7 GPL,SL VS 16 Device vendor specific log 0xa8-0xb6 GPL,SL VS 1 Device vendor specific log 0xb7 GPL,SL VS 39 Device vendor specific log 0xbd GPL,SL VS 1 Device vendor specific log 0xc0 GPL,SL VS 1 Device vendor specific log 0xc1 GPL VS 93 Device vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (6 sectors) Device Error Count: 1 CR = Command Register FEATR = Features Register COUNT = Count (was: Sector Count) Register LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8 LH = LBA High (was: Cylinder High) Register ] LBA LM = LBA Mid (was: Cylinder Low) Register ] Register LL = LBA Low (was: Sector Number) Register ] DV = Device (was: Device/Head) Register DC = Device Control Register ER = Error register ST = Status register Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 1 [0] occurred at disk power-on lifetime: 8036 hours (334 days + 20 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 04 -- 51 00 00 00 00 34 73 fa 80 40 00 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- ea 00 00 00 00 00 00 00 00 00 00 40 08 1d+12:05:10.391 FLUSH CACHE EXT 61 00 10 00 70 00 00 34 73 fd 18 40 08 1d+12:05:10.390 WRITE FPDMA QUEUED 61 00 30 00 70 00 01 a0 cd d4 b0 40 08 1d+12:05:10.390 WRITE FPDMA QUEUED 61 00 08 00 70 00 01 a0 cd d4 a0 40 08 1d+12:05:10.390 WRITE FPDMA QUEUED 61 00 08 00 70 00 00 ac 7f 1d a8 40 08 1d+12:05:10.390 WRITE FPDMA QUEUED SMART Extended Self-test Log Version: 1 (1 sectors) Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 16541 - # 2 Extended offline Completed without error 00% 16456 - # 3 Short offline Completed without error 00% 16373 - # 4 Short offline Completed without error 00% 16204 - # 5 Extended offline Completed without error 00% 16150 - # 6 Short offline Completed without error 00% 16039 - # 7 Short offline Completed without error 00% 15797 - # 8 Extended offline Completed: read failure 70% 15703 880016000 # 9 Short offline Completed without error 00% 15629 - #10 Short offline Completed without error 00% 15464 - #11 Extended offline Completed: read failure 70% 15369 880016000 #12 Short offline Completed without error 00% 15296 - #13 Short offline Completed without error 00% 15078 - #14 Extended offline Completed: read failure 60% 14984 880016000 #15 Short offline Completed without error 00% 14910 - #16 Short offline Completed without error 00% 14745 - #17 Extended offline Completed: read failure 70% 14650 880016000 #18 Short offline Completed without error 00% 14577 - 4 of 4 failed self-tests are outdated by newer successful extended offline self-test # 2 SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version: 3 SCT Version (vendor specific): 258 (0x0102) SCT Support Level: 1 Device State: Active (0) Current Temperature: 36 Celsius Power Cycle Min/Max Temperature: 33/42 Celsius Lifetime Min/Max Temperature: 3/45 Celsius Under/Over Temperature Limit Count: 0/0 SCT Temperature History Version: 2 Temperature Sampling Period: 1 minute Temperature Logging Interval: 1 minute Min/Max recommended Temperature: 0/60 Celsius Min/Max Temperature Limit: -41/85 Celsius Temperature History Size (Index): 478 (229) Index Estimated Time Temperature Celsius 230 2018-02-04 15:13 36 ***************** ... ..( 20 skipped). .. ***************** 251 2018-02-04 15:34 36 ***************** 252 2018-02-04 15:35 35 **************** 253 2018-02-04 15:36 35 **************** 254 2018-02-04 15:37 36 ***************** ... ..(279 skipped). .. ***************** 56 2018-02-04 20:17 36 ***************** 57 2018-02-04 20:18 37 ****************** ... ..( 30 skipped). .. ****************** 88 2018-02-04 20:49 37 ****************** 89 2018-02-04 20:50 36 ***************** ... ..( 29 skipped). .. ***************** 119 2018-02-04 21:20 36 ***************** 120 2018-02-04 21:21 35 **************** ... ..( 6 skipped). .. **************** 127 2018-02-04 21:28 35 **************** 128 2018-02-04 21:29 34 *************** ... ..( 10 skipped). .. *************** 139 2018-02-04 21:40 34 *************** 140 2018-02-04 21:41 33 ************** ... ..( 19 skipped). .. ************** 160 2018-02-04 22:01 33 ************** 161 2018-02-04 22:02 34 *************** ... ..( 6 skipped). .. *************** 168 2018-02-04 22:09 34 *************** 169 2018-02-04 22:10 35 **************** ... ..( 11 skipped). .. **************** 181 2018-02-04 22:22 35 **************** 182 2018-02-04 22:23 36 ***************** ... ..( 46 skipped). .. ***************** 229 2018-02-04 23:10 36 ***************** SCT Error Recovery Control: Read: 70 (7.0 seconds) Write: 70 (7.0 seconds) Device Statistics (GP Log 0x04) not supported SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 2 0 Command failed due to ICRC error 0x0002 2 0 R_ERR response for data FIS 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0005 2 0 R_ERR response for non-data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS 0x0008 2 0 Device-to-host non-data FIS retries 0x0009 2 3 Transition from drive PhyRdy to drive PhyNRdy 0x000a 2 3 Device-to-host register FISes sent due to a COMRESET 0x000b 2 0 CRC errors within host-to-device FIS 0x000f 2 0 R_ERR response for host-to-device data FIS, CRC 0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC 0x8000 4 1986384 Vendor specific
