Quick & dirty guide for compiling FreeNAS 9.10
Thilo
Neophyte
Thank you, this is really good.
One question though:
You describe how to install the build using the ISO/USB, but
how do I update the running FreeNAS without going through the ISO/USB stick installation?
Is it possible to (on the command line) create a new snapshot on the root and just untar something onto the RFS?
Or is it possible to utilize the web-gui interface to point it to my self build OS ?
Any hints are appreciated
Thilo
JustinClift
Senior Member
how do I update the running freenas without going through the ISO/USB stick installation?
  1. In theory ;) , it's possible to push a newly compiled FreeNAS ISO/USB onto an existing remote one, via ssh. The "Updating an existing installation" bit at the bottom here gives the commands, which look very simple:
    https://github.com/freenas/freenas-build#updating-an-existing-installation
    It's not something I've ever needed to do, which is why I say "in theory". Haven't tried it myself. ;)
    There's no reason it shouldn't work though.
  2. It should be possible to change the expected update locations in the WebUI, to be a server you've put new builds on.
    I haven't yet found the source file where it's defined, so I'm not sure on the best way to override it.
    If you log into a FreeNAS box, the "UPDATE_SERVER" variable seems to be set in:
    /usr/local/lib/freenasOS/__init__.py​
    It's defined in a few places in that /usr/local/lib/freenasOS folder, but the 2nd definition in the __init__.py file seems to be where it takes effect (for a test system here).
    No idea where the freenasOS source lives on GitHub though. If you find it, let me know. :)
JustinClift
Senior Member
Thilo
Neophyte
Yes it does,
- unfortunately I am stuck right now with trying to build freenas in a freenas jail.....
Which seems to break at strange places.
(Since I am a netbsd guy and new to freebsd, all the jail stuff takes some time to understand)
Once I get the chicken and egg problem solved, I will post the details needed.
JustinClift
Senior Member
Er... why are you trying to build FreeNAS in a FreeNAS jail?
That's super unlikely to work.
Are you able to do it in a VM instead? (make sure it has 30GB+ free)
Thilo
Neophyte
:smile:
Just because I can.
It does work, after I added all possible rights to the jail,
A VM ? Why would I want to have an hypervisor in between? Freenas is in the end just freebsd isn't it?
And Yes it took a while (with trial and error) to figure out that the jail needs:
param.allow.mount.zfs=true
param.allow.mount.tmpfs=true
param.allow.mount.linsysfs=true
param.allow.mount.linprocfs=true
param.allow.mount.procfs=true
param.allow.mount.nullfs=true
param.allow.mount.fdescfs=true
param.allow.mount.devfs=true
param.allow.mount=true
param.allow.socket_af=true
param.allow.chflags=true
param.children.max=5
But the build finishes and works.
Just the update via the web-interface is not yet working
JustinClift
Senior Member
Heh Heh Heh, learn something every day.
Really didn't think that would work, but yeah, it's nifty that it does. :D
Well done. :)
