Resource icon
Qemu Guest Agent for TrueNAS Core 13 2022-11-08
zamana
Hi!
Thank you very much for this new build.
Unfortunately, the link to the previous version build instructions is not working...
Regards.
zamana
Perfect!
Just an additional info: if you are just using the files instead of building them, don't forget to enable the executable bit (chmod +x) on files qemu-ga and qemu-guest-agent where you saved them, before to copy them to their destination folders.
Thank you!
