Problems with the latest upgrade
ovizii
See error log for the exact versions, any ideas how to proceed? I tried this twice with the same result
Jun 20 11:41:32 freenas updated.py: [freenasOS.Installer:635] Delta package 9.3-STABLE-23f1401-3df1120-dc3cbb7->9.3-STABLE-47b35fb-14e08f2-cee4950 cannot upgrade current version 9.3-STABLE-47b35fb-14e08f2-cee4950
Jun 20 11:41:32 freenas updated.py: [freenasOS.Installer:813] Unable to install package base-os
Jun 20 11:41:32 freenas updated.py: [freenasOS.Update:1047] Unable to install packages
Jun 20 11:41:32 freenas updated.py: [freenasOS.Update:1078] Update got exception during update: Unable to install packages
Jun 20 11:41:39 freenas mountd[4986]: can't delete exports for /var/tmp/tmppSDsmd/dev: Invalid argument mount option <size> is unknown
Jun 20 11:41:43 freenas manage.py: [middleware.exceptions:38] [MiddlewareError: Unable to install packages]
###edit###
I ran a Verify Install and got this which should not pose a problem:
The following Inconsistencies were found in your Current Install:
List of Checksum Mismatches:
/conf/base/etc/resolv.conf
ovizii
Not sure its related but also having problems updating an installed plugin:
Jun 20 12:34:26 freenas manage.py: [common.pipesubr:59] Popen()ing: /sbin/umount -f '/mnt/fiver/jails/syncthing_1/mnt/_whitey-TitaniumBackup'
Jun 20 12:34:27 freenas manage.py: [middleware.exceptions:38] [MiddlewareError: umount: /mnt/fiver/jails/syncthing_1/mnt/_whitey-TitaniumBackup: not a file system root directory
Jun 22 21:14:55 freenas manage.py: [common.pipesubr:70] Popen()ing: /sbin/umount -f '/mnt/fiver/jails/plexmediaserver_1/mnt/Movies'
Jun 22 21:14:55 freenas manage.py: [common.pipesubr:70] Popen()ing: /sbin/umount -f '/mnt/fiver/jails/plexmediaserver_1/mnt/Series'
Jun 22 21:14:56 freenas manage.py: [middleware.exceptions:38] [MiddlewareError: There was a problem creating the PBI]
And when mounting stuff I see 2 extra mnt directories? =>
Not sure a reboot would help right now so waiting for feedback.
D
dlavigne
Guest
What is the size of the boot device? How much capacity is used according to System -> Boot?
DrKK
FreeNAS Generalissimo
The resolv.conf thing is not an error. It's a bug. You can safely ignore that.
ovizii
The problem seems to have solved itself!?
I got the delivery of my 16GB ECC RAM so I shut down my NAS, replaced the RAM, booted and voila freeNAS says there's no update available and its currently on version: FreeNAS-9.3-STABLE-201506162331
If I manually check for an update I see this in the console:
Jun 22 20:46:29 freenas manage.py: [freenasOS.Update:1167] Cached sequence, FreeNAS-9.3-STABLE-201506042008, does not match system sequence, FreeNAS-9.3-STABLE-201506162331
Jun 22 20:46:29 freenas manage.py: [freenasOS.Update:789] Cached sequence does not match system sequence
In addition to that I see this error when booting, any ideas?
Jun 22 20:35:53 freenas collectd[2905]: plugin_load: Could not find plugin "zfs_arc_v2" in /usr/local/lib/collectd
and there's a md_size file now in my /mnt folder !?
freenas# pwd
/mnt
freenas# ls -al
total 48
drwxr-xr-x   3 root  wheel  80 Jun 22 20:43 .
drwxr-xr-x  21 root  wheel  29 Jun 20 01:08 ..
drwxr-xr-x  10 root  wheel  10 Jun 22 20:43 fiver
-rw-r--r--   1 root  wheel   5 Jun 20 01:00 md_size
with the content 8192
That md_size file has been there for a very long time.. since 8.0.0 unless I'm mistaken. ;)
ovizii
Currently downloading today's updates: base-os-9.3-STABLE-47b35fb-14e08f2-cee4950-9.3-STABLE-d1ba193-5d42663-cee4950.tgz
hoping that will solve the problem :-(
ovizii
And now my current OS is: FreeNAS-9.3-STABLE-201506222346 but I still can't update any plugins (same errors as stated above)
