Update problems
nivarox
Updates always worked but without any changes the update function stopped working:
Apr 2 15:07:04 freenas updated.py: [freenasOS.Installer:590] Delta package 9.3-STABLE-5721388-01034a4-d191868->9.3-STABLE-896d06d-e006356-d191868 cannot upgrade current version 9.3-STABLE-896d06d-e006356-d191868
Apr 2 15:07:04 freenas updated.py: [freenasOS.Installer:756] Unable to install package base-os
Apr 2 15:07:04 freenas updated.py: [freenasOS.Update:726] Unable to install packages
Apr 2 15:07:04 freenas updated.py: [freenasOS.Update:744] Update got exception during update: Unable to install packages
Apr 2 15:07:04 freenas kernel: <118>Apr 2 15:07:04 freenas updated.py: [freenasOS.Installer:590] Delta package 9.3-STABLE-5721388-01034a4-d191868->9.3-STABLE-896d06d-e006356-d191868 cannot upgrade current version 9.3-STABLE-896d06d-e006356-d191868
Apr 2 15:07:04 freenas kernel: <118>Apr 2 15:07:04 freenas updated.py: [freenasOS.Installer:756] Unable to install package base-os
Apr 2 15:07:04 freenas kernel: <118>Apr 2 15:07:04 freenas updated.py: [freenasOS.Update:726] Unable to install packages
Apr 2 15:07:04 freenas kernel: <118>Apr 2 15:07:04 freenas updated.py: [freenasOS.Update:744] Update got exception during update: Unable to install packages
Apr 2 15:07:08 freenas manage.py: [middleware.exceptions:38] [MiddlewareError: Unable to install packages]
Stop refresh
Any ideas?
Best regards
Andy
esamett
I failed to update today. Per question above I have 11 boot environments. 8 gb usb I think. similar error.
Originally I tried to update but download froze so I cancelled. Some update or reboot went through and I got error about da15:umass-sim0... error and boot froze on starting nut.
I rebooted using 201503200528 instead of 201503270027 and I have unable to install packages error. I don't know date code of update that FreeNAS tried to install today.
D
dlavigne
Guest
You are running out of space on the boot device. Use System -> Boot to remove the boot environments you no longer need so that you only have 2 or 3 left.
esamett
seems to have worked after deletion. strange that flash drive was only about half full to have caused such trouble. o_O Perhaps this usb drive clean up can happen automatically in future versions.
