Problem adding a new NIC
aindriu
I just added a new NIC to increase transfer speed on my LAN but it is not showing up in FreeNAS(pic). The card I bought was a Ugreen PCI-E PCI E Express:
https://www.aliexpress.com/item/32819991354.html?spm=a2g0s.9042311.0.0.26b84c4dDp3jwo
I just read some threads about compatibility issues but never thought of it at the time of purchase.
I have the network card in the computer and the network lights are flashing away (pic) so its not broken but as I said it doesn't appear.
I have set a static IP to FreeNAS & piHole because I have mapped drives on my PC to FreeNAS and piHole really needs a static IP - I specified the NIC on the motherboard to do this so maybe I have to set a static IP for the new device? Is there a way I can merge two NIC's to have one IP address?
I took a screenshot of the console on FreeNAS after boot, is it recognizing two network cards? epair0a and epair0b ?
Thanks for your help!
D
dlavigne
Guest
What is the full output of ifconfig (within code tags please)?
Which version of FreeNAS?
aindriu
OS Version:
FreeNAS-11.2-U6
(Build Date: Sep 17, 2019 0:16)
undefined        FreeNAS (c) 2009-2019, The FreeNAS Development Team
        All rights reserved.
        FreeNAS is released under the modified BSD license.
        For more information, documentation, help or support, go here:
        http://freenas.org
Welcome to FreeNAS
Could not chdir to home directory /nonexistent: No such file or directory
% ifconfig
re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
        ether e0:d5:5e:29:70:f5
        hwaddr e0:d5:5e:29:70:f5
        inet 192.168.1.6 netmask 0xffffff00 broadcast 192.168.1.255
        media: Ethernet autoselect (100baseTX <full-duplex>)
        status: active
re1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE                                                         >
        ether 00:e0:4c:6e:bf:1b
        hwaddr 00:e0:4c:6e:bf:1b
        status: active
        options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
        groups: lo
tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: Attached to pihole
        options=80000<LINKSTATE>
        ether 00:bd:93:dc:f7:00
        hwaddr 00:bd:93:dc:f7:00
        nd6 options=1<PERFORMNUD>
        status: active
        groups: tap
        Opened by PID 3936
        ether 02:c0:3c:f7:88:00
        groups: bridge
        member: vnet0:3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 8 priority 128 path cost 2000
        member: vnet0:2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 7 priority 128 path cost 2000
        member: vnet0:1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 6 priority 128 path cost 2000
        member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 1 priority 128 path cost 55
        member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 4 priority 128 path cost 2000000
vnet0:1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: syncthing as nic: epair0b
        options=8<VLAN_MTU>
        ether e0:d5:5e:5b:07:f8
        hwaddr 02:63:d0:00:06:0a
        status: active
        groups: epair
vnet0:2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: plex as nic: epair0b
        options=8<VLAN_MTU>
        ether e0:d5:5e:14:fa:09
        hwaddr 02:63:d0:00:07:0a
        status: active
        groups: epair
vnet0:3: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: piholejail as nic: epair0b
        options=8<VLAN_MTU>
        ether e0:d5:5e:36:7d:de
        hwaddr 02:63:d0:00:08:0a
        status: active
        groups: epair
% FreeBSD 11.2-STABLE (FreeNAS.amd64) #0 r325575+5920981193f(HEAD): Mon Sep 16 23:00:13 UTC 2                                                         019
Badly placed (.
        groups: lo
% tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
%         FreeNAS (c) 2009-2019, The FreeNAS Development Team
Badly placed ()'s.
%         ether 00:bd:93:dc:f7:00
        status: active
        groups: tap
        Opened by PID 3936
All: Command not found.
        groups: bridge
%         FreeNAS is released under the modified BSD license.
FreeNAS: Command not found.
%         member: vnet0:3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
%         For more information, documentation, help or support, go here:
For: Command not found.
%         http://freenas.org
http://freenas.org: Command not found.
        options=8<VLAN_MTU>
% Welcome to FreeNAS
Welcome: Command not found.
        status: active
        groups: epair
% Could not chdir to home directory /nonexistent: No such file or directory
Could: Command not found.
        options=8<VLAN_MTU>
% % ifconfig
%: Too many arguments.
%         media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>)
        status: active
UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST: No such file or directory.
        groups: epair
%         options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
        options=8<VLAN_MTU>
Missing name for redirect.
%         ether e0:d5:5e:36:7d:de
ether: Command not found.
        status: active
        groups: epair
%         hwaddr e0:d5:5e:29:70:f5
hwaddr: Command not found.
%         inet 192.168.1.6 netmask 0xffffff00 broadcast 192.168.1.255
inet: Command not found.
%         nd6 options=9<PERFORMNUD,IFDISABLED>
%         media: Ethernet autoselect (100baseTX <full-duplex>)
Badly placed ()'s.
%         status: active
status:: Too many arguments.
% re1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
BROADCAST,SIMPLEX,MULTICAST: No such file or directory.
%         options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE                                                         >
%         ether 00:e0:4c:6e:bf:1b
%         hwaddr 00:e0:4c:6e:bf:1b
Badly placed ()'s.
%         status: active
% lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
UP,LOOPBACK,RUNNING,MULTICAST: No such file or directory.
%         options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
%         inet6 ::1 prefixlen 128
inet6: Command not found.
%         inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
%         inet 127.0.0.1 netmask 0xff000000
%         nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
%         groups: lo
groups:: Too many arguments.
%         description: Attached to pihole
description:: Too many arguments.
%         options=80000<LINKSTATE>
%         hwaddr 00:bd:93:dc:f7:00
%         nd6 options=1<PERFORMNUD>
media:: Too many arguments.
%         status: active
%         groups: tap
%         Opened by PID 3936
Opened: Command not found.
% bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST: No such file or directory.
%         ether 02:c0:3c:f7:88:00
%         groups: bridge
%         id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15
id: 00:00:00:00:00:00: no such user
%         maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200
maxage: Command not found.
%         root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0
root: Command not found.
%                 ifmaxaddr 0 port 8 priority 128 path cost 2000
ifmaxaddr: Command not found.
%         member: vnet0:2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
%                 ifmaxaddr 0 port 7 priority 128 path cost 2000
%         member: vnet0:1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
%                 ifmaxaddr 0 port 6 priority 128 path cost 2000
%         member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
%                 ifmaxaddr 0 port 1 priority 128 path cost 55
%         member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
%                 ifmaxaddr 0 port 4 priority 128 path cost 2000000
% vnet0:1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
%         description: associated with jail: syncthing as nic: epair0b
%         options=8<VLAN_MTU>
%         ether e0:d5:5e:5b:07:f8
%         hwaddr 02:63:d0:00:06:0a
Badly placed ()'s.
%         status: active
%         groups: epair
% vnet0:2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
%         description: associated with jail: plex as nic: epair0b
%         ether e0:d5:5e:14:fa:09
%         hwaddr 02:63:d0:00:07:0a
Badly placed ()'s.
%         status: active
%         groups: epair
% vnet0:3: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
%         description: associated with jail: piholejail as nic: epair0b
%         hwaddr 02:63:d0:00:08:0a
Badly placed ()'s.
%         status: active
%         groups: epair
%: No current job.
% clear
% ifconfig
        status: active
        options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
        status: active
        groups: lo
        status: active
        groups: tap
        Opened by PID 3936
        groups: bridge
        options=8<VLAN_MTU>
        status: active
        groups: epair
        options=8<VLAN_MTU>
        status: active
        groups: epair
        options=8<VLAN_MTU>
        status: active
        groups: epair
aindriu
The NIC is appearing now, The new GUI kind of hid it from me ><.
I'm trying to add these two NIC's together into one link aggregation to increase speed but they don't appear under link aggregation.
I was following this video https://www.youtube.com/watch?v=wqSH_uQSArQ
Why don't they appear under Link Aggregation? How can I make use of the new faster NIC?
aindriu
Sort of, FreeNAS is new to me but I finally copped that the problem is with the switch. I have a Netgear GS208 unmanaged Gigabit switch and I get gigabit LAN if I use one NIC. If I want to use two NIC's I probably need the Netgear Managed Pro Switch which does Link aggregation.
