What sort of power saving features are you looking for?
It is usually recommended to not use other power saving features than shutting off the machine on a regular basis other than if it would not be accessed let's say - once every week or so.
[root@nas] ~# ataidle /dev/da0 Model: Serial: Firmware Rev: ATA revision: unknown/pre ATA-2 LBA 48: no Geometry: 0 cyls, 0 heads, 0 spt Capacity: 0MB SMART Supported: no Write Cache Supported: no APM Supported: no AAM Supported: no
[root@nas] ~# camcontrol identify da0 camcontrol: ATA ATAPI_IDENTIFY via pass_16 failed
ataidle /dev/da0 and camcontrol identify da0 on my system, but da0 denotes one of my mirrored USB boot devices.[root@nas] ~# smartctl -a /dev/da0 smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: WD Product: WD2001FYYG Revision: D1R2 Compliance: SPC-4 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Logical block size: 512 bytes Rotation Rate: 7200 rpm Form Factor: 3.5 inches Logical Unit id: 0x50014ee50002c250 Serial number: WCC160025823 Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Sun Oct 2 08:00:54 2016 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Disabled or Not Supported
~# ataidle /dev/ada0 Model: WDC WD30EFRX-68EUZN0 Serial: WD-WMC4N0E6K1VF Firmware Rev: 82.00A82 ATA revision: ATA-9 LBA 48: yes Geometry: 16383 cyls, 16 heads, 63 spt Capacity: 2794GB SMART Supported: yes SMART Enabled: yes Write Cache Supported: yes Write Cache Enabled: yes APM Supported: no AAM Supported: no
~# camcontrol identify ada0 pass0: <WDC WD30EFRX-68EUZN0 82.00A82> ACS-2 ATA SATA 3.x device pass0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) protocol ATA/ATAPI-9 SATA 3.x device model WDC WD30EFRX-68EUZN0 firmware revision 82.00A82 serial number WD-WMC4N0E6K1VF WWN 50014ee65a574394 cylinders 16383 heads 16 sectors/track 63 sector size logical 512, physical 4096, offset 0 LBA supported 268435455 sectors LBA48 supported 5860533168 sectors PIO supported PIO4 DMA supported WDMA2 UDMA6 media RPM 5400 Feature Support Enabled Value Vendor read ahead yes yes write cache yes yes flush cache yes yes overlap no Tagged Command Queuing (TCQ) no no Native Command Queuing (NCQ) yes 32 tags NCQ Queue Management no NCQ Streaming no Receive & Send FPDMA Queued no SMART yes yes microcode download yes yes security yes no power management yes yes advanced power management no no automatic acoustic management no no media status notification no no power-up in Standby yes no write-read-verify no no unload yes yes general purpose logging yes yes free-fall no no Data Set Management (DSM/TRIM) no Host Protected Area (HPA) yes no 5860533168/5860533168 HPA - Security no
smartctl -x /dev/da0 or camcontrol identify da0, either one will work. I suspect that you will have no APM or AAM support. When I checked my drives, which I know do support these features, I was a bit surprised to find out that they were not available. In my case I suspect it's because I'm running on a ESXi machine while I expected the pass-through to work perfectly, yet apparently it doesn't and I think ESXi itself is to blame.[root@nas] ~# camcontrol identify da0 camcontrol: ATA ATAPI_IDENTIFY via pass_16 failed
[root@nas] ~# smartctl -x /dev/da0 smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: WD Product: WD2001FYYG Revision: D1R2 Compliance: SPC-4 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Logical block size: 512 bytes Rotation Rate: 7200 rpm Form Factor: 3.5 inches Logical Unit id: 0x50014ee50002c250 Serial number: WCC160025823 Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Sun Oct 2 16:09:28 2016 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Disabled or Not Supported Read Cache is: Enabled Writeback Cache is: Disabled === START OF READ SMART DATA SECTION === SMART Health Status: OK Current Drive Temperature: 33 C Drive Trip Temperature: 64 C Manufactured in week 01 of year 2012 Specified cycle count over device lifetime: 1048576 Accumulated start-stop cycles: 42 Specified load-unload count over device lifetime: 1114112 Accumulated load-unload cycles: 11150 Elements in grown defect list: 0 Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 40622883 0 2 40622883 0 72343.528 0 write: 108371973 2 61 108371975 2 12564.756 0 Non-medium error count: 511 SMART Self-test log Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ] Description number (hours) # 1 Background short Completed 48 16941 - [- - -] # 2 Background short Completed 48 16917 - [- - -] # 3 Background short Completed 48 16893 - [- - -] # 4 Background short Completed 48 16869 - [- - -] # 5 Background short Completed 48 16845 - [- - -] # 6 Background short Completed 48 16821 - [- - -] # 7 Background long Completed 48 16803 - [- - -] # 8 Background short Completed 48 16797 - [- - -] # 9 Background short Completed 48 16773 - [- - -] #10 Background short Completed 48 16749 - [- - -] #11 Background short Completed 48 16725 - [- - -] #12 Background short Completed 48 16701 - [- - -] #13 Background short Completed 48 16677 - [- - -] #14 Background short Completed 48 16654 - [- - -] #15 Background long Completed 48 16638 - [- - -] #16 Background short Completed 48 16632 - [- - -] #17 Background short Completed 48 16608 - [- - -] #18 Background short Completed 48 16584 - [- - -] #19 Background short Completed 48 16560 - [- - -] #20 Background short Completed 48 16536 - [- - -] Long (extended) Self Test duration: 15620 seconds [260.3 minutes] Background scan results log Status: waiting until BMS interval timer expires Accumulated power on time, hours:minutes 17169:15 [1030155 minutes] Number of background scans performed: 65, scan progress: 0.00% Number of background medium scans performed: 65 Protocol Specific port log page for SAS SSP relative target port id = 1 generation code = 0 number of phys = 1 phy identifier = 0 attached device type: SAS or SATA device attached reason: power on reason: unknown negotiated logical link rate: phy enabled; 6 Gbps attached initiator port: ssp=1 stp=1 smp=1 attached target port: ssp=0 stp=0 smp=0 SAS address = 0x50014ee50002c252 attached SAS address = 0x5000000080000000 attached phy identifier = 0 Invalid DWORD count = 0 Running disparity error count = 0 Loss of DWORD synchronization = 2 Phy reset problem = 0 Phy event descriptors: Transmitted SSP frame error count: 0 Received SSP frame error count: 0 relative target port id = 2 generation code = 0 number of phys = 1 phy identifier = 1 attached device type: no device attached attached reason: unknown reason: unknown negotiated logical link rate: phy enabled; unknown attached initiator port: ssp=0 stp=0 smp=0 attached target port: ssp=0 stp=0 smp=0 SAS address = 0x50014ee50002c253 attached SAS address = 0x0 attached phy identifier = 0 Invalid DWORD count = 0 Running disparity error count = 0 Loss of DWORD synchronization = 0 Phy reset problem = 0 Phy event descriptors: Transmitted SSP frame error count: 0 Received SSP frame error count: 0
I can, only because the majority of our users won't use power management on the hard drives in a NAS. The drives you purchased were intended for enterprise data storage which means continuous use, not sleeping or even parking the heads because that would induce delays in data transfers. Minor delays but in the grand scheme of things like in a data center, it all adds up.I can not believe i am the first one to want to use this feature with the card...
Code:[root@nas] ~# ataidle -s da0 ataidle: error opening da0
Agreed, should be/dev/da0
ataidle -S 300 /dev/da0
