So I built a 8 bay rack server about 8 years. ill post specs when i get home from work cant remember off the top of my head. But its all server type hardware with a dedicated raid controller.
I am currently running windows server 2012 r2, i was going to do some fancy stuff back in the day and thought i needed the power of server software. It ended up just being used as just a NAS, and a dedicated plex server. it has a raid6 with 4 / 8 drive bays being used. that raid is pretty much full using 5tb drives.
I am about to order 4 new 12tb drives and build a new raid6 array. But my question is since i dont need any of the power windows server offers should i now make the switch to freenas? The server will only be used as NAS and hosting plex. My questions are below.
1) should I go with freenas Core or Scale or just stick with server 2012? Looking for just simplicity and upgradeability.
2) Would i have any issues if i make the OS switch and create the new "raid6" with the (4) 12tb drives getting the data from the old raid6 from the current windows raid? and would it be difficult?
3) does having the raid controller create issues with freenas as that is whats is being used to plug the raid bays in?
4) All the computers in the house are windows 10/11 is the interaction to the server if swapped to freenas simple and clean?
5) the server is currently headless so all access and editing is done using remote desktop. I can plug a monitor in temporally to do a fresh install if needed is this something i need to do?
6) My biggest concern is getting the data off the old raid6 drives and onto the "new" array.
