ports failing due to EOL jails in FreeNAS 11
anika200
Just wanted to put this out there for discussion and correction if needed.
Having just built a brand new jail on FreeNAS 11 I find I can not build any software???
So after googling and wasting so much time I finally find a thread in here on the forums that explains the problem.
The error faced is thus
"Ports Collection support for your FreeBSD version has ended, and no ports are
guaranteed to build on this system. Please upgrade to a supported release."
Is it a bug that needs filed?
the fix (work around) is to add "ALLOW_UNSUPPORTED_SYSTEM=yes" without quotes to the file /etc/make.conf.
D
dlavigne
Guest
Jails created in 11.1 won't have this issue as it won't be EoL'd for some time. Once RELEASE is out (some time next week), you'll want to recreate your jails that you plan to update.
raidflex
So is iocage fully implemented at least in the new GUI so that we don't have to re-created jails AGAIN in the future?
Jailer
Not strong, but bad
I wouldn't get too worked up about re creating jails AGAIN. Every major release of FreeNAS that updates the base OS will require jails to be rebuilt if you want to stay current on updates. You will at some point have to re create jails AGAIN if you want to stay current when new versions are released.
raidflex
I thought one of the benefits of iocage was that it would not be necessary to rebuild them every time...
D
dlavigne
Guest
Base OS is a different thing as the ABI changes with each major version of FreeBSD.
anika200
Update is quite nice :) I do not know what changed but my memory usage was cut by more than half, sweet. I only have to rebuild one jail so no big deal.
