Problem installing Ports and how to solve
FloRho
Two weeks ago I installed on my TrueNAS a jail for NextCloud and used ports to install certbot. Everything worked fine.
This week I tried to create a second NextCloud instance for a tutorial and when I tried to install ports I got the following error:
Ports Collection support for your FreeBSD version has ended, and no ports are guaranteed to build on this system. Please upgrade to a supported release
You can skip this error by using the following command instead, with enabled -DALLOW_UNSUPPORTED_SYSTEM switch:
make -DALLOW_UNSUPPORTED_SYSTEM install clean
With this command everything works.
My question: Is this a new problem, maybe because of an update of ports or because the NextCloud plugin has been updated?
I am using TrueNAS Core in version TrueNAS-12.0-STABLE and jail version 12.1-RELEASE-p13
Thanks,
Florian
Samuel Tai
Jailer
Not strong, but bad
12.1 is EOL and no longer supported. Upgrade your jail to 12.2-RELEASE.
