Pool tank state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaf
ASap
I've seen a couple of this topic, but the resolution is still unclear.
So, earlier this morning, I got an alert email from my TrueNAS server saying:
TrueNAS @ truenas
New alerts:
Pool tank state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
Current alerts:
All hardware and disk are new (specs in my signature spoiler)
It's 4 x IronWolf Pro 4TB in RaidZ.
root@truenas[/home/admin]# zpool status
  pool: boot-pool
 state: ONLINE
	NAME         STATE     READ WRITE CKSUM
	boot-pool    ONLINE       0     0     0
	  nvme1n1p3  ONLINE       0     0     0
errors: No known data errors
  pool: tank
 state: ONLINE
status: One or more devices has experienced an unrecoverable error.  An
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
	tank                                      ONLINE       0     0     0
	  raidz1-0                                ONLINE       0     0     0
	    3e5220fe-8ccb-116a-826a-03b929bd1508  ONLINE       0     0     0
	    dd68c5bb-11d7-1621-afaa-f657d7123f8e  ONLINE       0     0     1
	    a67b45e4-ff4a-131c-82a6-39e0149158c1  ONLINE       0     0     1
	    a6cf187f-cc39-19a0-b793-61bf337e300c  ONLINE       0     0     0
	logs
	  ba9483e5-1165-4d5e-b7a3-2ef7be454869    ONLINE       0     0     0
From the Web Interface seems there's no way of clearing this error.
This is my first time having this error after two days of uptime. Is it safe to ignore? Or is something gone wrong? I don't want it to get more sinister in the future.
I've run the Conveyancing S.M.A.R.T. test, and all drives returned successfully.
NugentS
zpool clear - as it states in the text you posted
Run the smartctl -t long test as well.
You have two devices reporting cksum errors, usually, but not always cable related
ChrisRJ
If it is more than cables, you should check up on your backups. If you don't have a current one, now is the time for it.
ASap
Thanks for the responses, I've run an extended S.M.A.R.T test on all drives, and all returned successfully.
I scrubbed the pool, and it didn't find any errors.
And I figured the checksum error happened when I failed to copy one of the @eaDir-directories created by my previous Synology NAS.
Because when I tried to copy that again, it caused my 3rd drive to show checksum failed, and that folder was inaccessible even from the CLI. After some research on the Internet, it turns out that's just an extended attribute for Synology NAS and not related to the actual data. So I went ahead and deleted it.
So here's what I did:
root@truenas[~]# zpool status
  pool: boot-pool
 state: ONLINE
  pool: tank
 state: ONLINE
  scan: scrub repaired 0B in 00:44:05 with 0 errors on Sat Dec 31 22:10:17 2022
    tank                                      ONLINE       0     0     0
        a6cf187f-cc39-19a0-b793-61bf337e300c  ONLINE       0     0     1
    logs
      ba9483e5-4165-1d5e-b7a3-2ef7be454869    ONLINE       0     0     0
root@truenas[~]# zpool clear tank
  pool: boot-pool
 state: ONLINE
  pool: tank
 state: ONLINE
    tank                                      ONLINE       0     0     0
        dd68c5bb-11d7-1621-afaa-f657d7123f8e  ONLINE       0     0     0
        a67b45e4-ff4a-131c-82a6-39e0149158c1  ONLINE       0     0     0
    logs
root@truenas[~]#
Hey, Happy New Year 2023, everyone :cool:
NugentS
I notice you have a SLOG drive (log vdev) - what are you using for that?
ChrisRJ
Also, the SLOG device is not mentioned in your system specs (from signature). So you might want to add it there :smile:
ASap
I thought the SLOG would speed up any Sync writes to the disk.
I was thinking of removing it since it's not bringing many benefits.
NugentS
"I thought the SLOG would speed up any Sync writes to the disk."
It might - are you actually doing any? SMB is async. Most sync writes are from ESX or NFS
ASap
Just SMB predominantly.
ChrisRJ
Check out this.
SMB from Mac is synchronous according to people I trust on this topic.
ASap
Has anyone here tried NFS on Mac?
I can see both SMB and NFS protocols are supported in macOS.
Top Bottom
