I had a failing harddrive in a mirrored configuration, the harddrive has been replaced and resilvered with the pool.
however I get the message 'Pool SATA_3_6_TB state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected'
and the storage pool in the ui reporting ' unhealthy '
zpool status -v:
I had some corruptions before, they were from the emby cache, that was running i guess when the resilvering was going on ?
I have removed those files from the cache, however the error remains ?
So, my question here, how do clear the corrupted files ? (These are my backup drives)
zpool status -v:
pool: SATA_3_6_TB
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
scan: resilvered 887G in 04:24:22 with 0 errors on Sat Aug 6 23:03:35 2022
NAME STATE READ WRITE CKSUM
SATA_3_6_TB ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
5c33cdaa-6da3-4bc9-9afb-2e8905234e69 ONLINE 0 0 0
1c72f9f6-0d06-43a8-b397-030821842826 ONLINE 0 0 0
SATA_3_6_TB/Big MIrror:<0xd2441>
SATA_3_6_TB/Big MIrror:<0xd2343>
SATA_3_6_TB/Big MIrror:<0xd395f>
SATA_3_6_TB/Big MIrror:<0xd25eb>
