Pool offline after replacing disk
Paengaroa
Ok, doing that now.
Fingers crossed.
(In bed on my iPad cause it’s 11pm here)
Paengaroa
Yes, if that's an option, go for it.
Didn’t work sadly.
  File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 367, in run
    await self.future
  File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 403, in __run_body
  File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/replace_disk.py", line 93, in replace
    enc_disks = await self.middleware.call(
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1238, in call
    return await self._call(
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1195, in _call
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/format_disks.py", line 56, in format_disks
    await asyncio_map(format_disk, disks.items(), limit=16)
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/asyncio_.py", line 16, in asyncio_map
    return await asyncio.gather(*futures)
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/asyncio_.py", line 13, in func
    return await real_func(arg)
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/format_disks.py", line 29, in format_disk
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1206, in _call
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1110, in run_in_executor
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/disk_/format.py", line 25, in format
    raise CallError(f'Failed to wipe disk {disk}: {job.error}')
middlewared.service_exception.CallError: [EFAULT] Failed to wipe disk ada0: [EFAULT] Command dd if=/dev/zero of=/dev/ada0p2 bs=1M count=32 failed (code 1):
dd: /dev/ada0p2: Input/output error
28+0 records in
27+0 records out
28311552 bytes transferred in 572.102738 secs (49487 bytes/sec)
OK, I think we should just do it in CLI then.
zpool replace VOL-1gptid/existing_disk gptid/new_disk
Where you will need to replace existing_disk with the gptid from zpool status of the first (good) disk in mirror-1 and replace new_disk with the gptid we saved earlier from ada0p2
Paengaroa
Ok, so here are the GPTIDs from the earlier thing for new_disk:
gptid/db6b19b3-ad7f-11eb-bf92-94de80d4625f N/A ada0p1
gptid/f9c45ce7-ad7f-11eb-bf92-94de80d4625f N/A ada0p2
Where exactly do I get the existing_disk GPTID?
Paengaroa
so
zpool replace VOL-1gptid/c821b7a9-160e-11e8-b0ee-94de80d4625f  gptid/f9c45ce7-ad7f-11eb-bf92-94de80d4625f
Paengaroa
root@freenas:~ # glabel status | grep ada0
root@freenas:~ # gptid/db6b19b3-ad7f-11eb-bf92-94de80d4625f     N/A  ada0p1
gptid/db6b19b3-ad7f-11eb-bf92-94de80d4625f: Command not found.
root@freenas:~ # gptid/f9c45ce7-ad7f-11eb-bf92-94de80d4625f     N/A  ada0p2
gptid/f9c45ce7-ad7f-11eb-bf92-94de80d4625f: Command not found.
root@freenas:~ # zpool import -f VOL-1
cannot import 'VOL-1': one or more devices is currently unavailable
root@freenas:~ #
root@freenas:~ # zpool import -F VOL-1
root@freenas:~ #
root@freenas:~ #
root@freenas:~ # zpool status
  pool: VOL-1
 state: DEGRADED
status: One or more devices is currently being resilvered.  The pool will
        continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
  scan: resilver in progress since Mon May  3 18:00:52 2021
        1.03T scanned at 205M/s, 678G issued at 132M/s, 6.71T total
        309M resilvered, 9.86% done, 13:23:35 to go
        VOL-1                                           DEGRADED     0     0     0
          mirror-0                                      DEGRADED     0     0     0
            gptid/c73d4498-160e-11e8-b0ee-94de80d4625f  ONLINE       0     0     0  (resilvering)
            5428397735157554866                         UNAVAIL      0     0     0  was /dev/gptid/c821b7a9-16                                    0e-11e8-b0ee-94de80d4625f
          mirror-1                                      ONLINE       0     0     0
            gptid/460fc065-275d-11e9-aed9-94de80d4625f  ONLINE       0     0     0
            gptid/4700b30d-275d-11e9-aed9-94de80d4625f  ONLINE       0     0     0
errors: No known data errors
  pool: freenas-boot
 state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
        still be used, but some features are unavailable.
        the features. See zpool-features(5) for details.
  scan: scrub repaired 0B in 00:04:08 with 0 errors on Wed May  5 03:49:08 2021
        NAME          STATE     READ WRITE CKSUM
        freenas-boot  ONLINE       0     0     0
          da0p2       ONLINE       0     0     0
root@freenas:~ #
OK, so you can get the gptid of the existing disk from the zpool status you have there...
What's concerning is the resilver already in progress... maybe the GUI operation was sort-of successful.
I think there's some merit to waiting to allow that to complete... it's saying 13 hours. Although on top of that it's saying the resilver began on Monday... (2 days ago).
Paengaroa
Yeah not sure what is going on. I'm at work now remoted in. The resilver is complete.
Should I try replace again?
Paengaroa
Ok so I'm getting the GPTID of the bad disk, for "existing_disk" ? and the replacement disk for GPTID for "new_disk"?
Yes. That's right. I was thinking about attaching a new member and not the replace action when I mentioned the other disk before.
Paengaroa
Ok great, I will run that now.
Paengaroa
Thanks so much again for all your time.
Getting so close!
root@freenas:~ # zpool replace VOL-1 gptid/c821b7a9-160e-11e8-b0ee-94de80d4625f                                         gptid/f9c45ce7-ad7f-11eb-bf92-94de80d4625f
cannot open 'gptid/f9c45ce7-ad7f-11eb-bf92-94de80d4625f': no such device in /dev
must be a full path or shorthand device name
root@freenas:~ #
Patrick M. Hausen
So the second gptid (your new disk) is not correct. Use gpart list to check again. The rawuuid field.
Paengaroa
Ok thanks
root@freenas:~ # gpart list
Geom name: ada1
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 7814037127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada1p1
   Mediasize: 2147483648 (2.0G)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(1,GPT,45ff4356-275d-11e9-aed9-94de80d4625f,0x80,0x400000)
   rawuuid: 45ff4356-275d-11e9-aed9-94de80d4625f
   rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada1p2
   Mediasize: 3998639456256 (3.6T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   efimedia: HD(2,GPT,460fc065-275d-11e9-aed9-94de80d4625f,0x400080,0x1d180be00)
   rawuuid: 460fc065-275d-11e9-aed9-94de80d4625f
   rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 3998639456256
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 7814037119
   start: 4194432
Consumers:
1. Name: ada1
   Mediasize: 4000787030016 (3.6T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e3
Geom name: ada2
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 7814037127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada2p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   efimedia: HD(1,GPT,c72d7f2d-160e-11e8-b0ee-94de80d4625f,0x80,0x400000)
   rawuuid: c72d7f2d-160e-11e8-b0ee-94de80d4625f
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada2p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   efimedia: HD(2,GPT,c73d4498-160e-11e8-b0ee-94de80d4625f,0x400080,0x1d180be00)
   rawuuid: c73d4498-160e-11e8-b0ee-94de80d4625f
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 7814037119
   start: 4194432
Consumers:
1. Name: ada2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r2w2e5
Geom name: ada3
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 7814037127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada3p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   efimedia: HD(1,GPT,46f25454-275d-11e9-aed9-94de80d4625f,0x80,0x400000)
   rawuuid: 46f25454-275d-11e9-aed9-94de80d4625f
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada3p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   efimedia: HD(2,GPT,4700b30d-275d-11e9-aed9-94de80d4625f,0x400080,0x1d180be00)
   rawuuid: 4700b30d-275d-11e9-aed9-94de80d4625f
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 7814037119
   start: 4194432
Consumers:
1. Name: ada3
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r2w2e5
Geom name: da0
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 30274711
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: da0p1
   Mediasize: 272629760 (260M)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 20480
   Mode: r0w0e0
   efimedia: HD(1,GPT,15dec071-1679-11e8-a514-08002744d9f5,0x28,0x82000)
   rawuuid: 15dec071-1679-11e8-a514-08002744d9f5
   rawtype: c12a7328-f81f-11d2-ba4b-00a0c93ec93b
   label: (null)
   length: 272629760
   offset: 20480
   type: efi
   index: 1
   end: 532519
   start: 40
2. Name: da0p2
   Mediasize: 15227998208 (14G)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 272650240
   Mode: r1w1e1
   efimedia: HD(2,GPT,1737ef14-1679-11e8-a514-08002744d9f5,0x82028,0x1c5d468)
   rawuuid: 1737ef14-1679-11e8-a514-08002744d9f5
   label: (null)
   length: 15227998208
   offset: 272650240
   type: freebsd-zfs
   index: 2
   end: 30274703
   start: 532520
Consumers:
1. Name: da0
   Mediasize: 15500673024 (14G)
   Sectorsize: 512
   Mode: r1w1e2
So [/CODE} 15dec071-1679-11e8-a514-08002744d9f5 [/CODE] ?
Paengaroa
Or
Paengaroa
Ok, replacing is no longer an option, it says disks in use or partitioned won't show as available. So the new disk is partitioned now maybe by the attempted replace last night?
Paengaroa
Ok, so I think I got it. But new issue.
The disk is too small? Should I -f?
root@freenas:~ # zpool replace VOL-1 gptid/c821b7a9-160e-11e8-b0ee-94de80d4625f gptid/15dec071-1679-11e8-a514-08002744d9f5
cannot replace gptid/c821b7a9-160e-11e8-b0ee-94de80d4625f with gptid/15dec071-1679-11e8-a514-08002744d9f5: device is too small
root@freenas:~ #
Paengaroa
root@freenas:~ #
this is the gptid for da0p2
Patrick M. Hausen
da0 is probably your boot device (USB key)? gpart list shows 3 SATA disks with partition tables. What about camcontrol devlist?
Paengaroa
Oh the disk isn't showing up anywhere now. aho.
