Pool offline after replacing disk
Paengaroa
Disks
OK, very good.
So we're going to start by partitioning the disk ready for use as a pool member:
gpart create -s gpt /dev/ada0 (working under the assumption it's currently not partitioned at all... you may need to do gpart destroy -F /dev/ada0 first if it's not blank)
Then we create the swap and data partitions:
gpart add -s 2G -t freebsd-swap /dev/ada0
gpart add -t freebsd-zfs /dev/ada0
Paengaroa
OK, very good.
Ok, done,
OK, so now we'll get the gptid of that partition with glabel status | grep ada0
OK, note down (copy paste to notepad or something) the gptid for ada0p2, we'll use that a little later.
Now we should import the pool.
Let's try first with a normal import (zpool import VOL-1)
I'm expecting this to result in an indication that we'll need to use -f to go ahead, but want to check that first.
Paengaroa
Ok, it's still thinking.
Issue is I can't copy for some reason,.
You'll need to type it out manually then... not fun.
You could enable the SSH service and then use Putty (assuming you use Windows) which will get you in a terminal window that can copy/paste.
Paengaroa
Ok, I'll go manual for now just to be safe.
Is this expected to take a while? It's not broken?
the zpool import should take no more than a minute... with a missing member disk in the pool, perhaps it's doing some extra checks, but that shouldn't mean waiting for a long time.
We can give it a few more minutes, then I think a reboot is the next step if it remains stuck.
Paengaroa
Ok ,it says it cannon import VOL-1, one or more devices are unavailable
OK, so the next step is to do it again but with the force switch:
zpool import -f VOL-1
Paengaroa
Paengaroa
root@freenas:~ # zpool import -f VOL-1
cannot import 'VOL-1': one or more devices is currently unavailable
root@freenas:~ #
OK, so we'll try the last resort...
zpool import -F VOL-1
Paengaroa
Ok the Pool VOL-1 is online but degraded. Mirror 1 which is supposed to have drives ADA2 and ADA0 is showing only ADA2.
Progress!
Paengaroa
Should I just replace the unidentified disk with ADA0?
