Scharbag
- Feb 1, 2012
I have decided to change things up and get rid of some old drives (some are going on 8 years of in-service time) and a lot of them are 5400 RPM SMR Seagates.
I have decided to go with 4 20TB CRM drives in a mirrored pool (2x2 mirrored vDevs) and I just wanted to check in with the community before I do so.
My current spinning rust pools are all RaidZ2. I plan on replacing my production pool (2x6 RaidZ2 made up of 6TB (mostly CMR) and 4TB (all SMR) drives) with the above mirrored pool. After that, I will reconfigure the old production drives to a new backup pool so that I can get rid of my current 2x9 RaidZ2 backup pool made up of older 4TB and 3TB SMR drives. Overall goal is to remove 18 spinning drives from my system due to their age as well as their energy/heat use/production. I will likely go with a wider RaidZ2 on the backup pool as I care not about its speed. I may even go RaidZ1 (hurts my soul to even say that). We will see what I come up with...
My thoughts are that mirrored vDevs make it much easier to expand in the future. Adding 2 more drives is easy. Yes it is space inefficient but with large drives, I do not much care about space efficiency.
Currently my production pool has 2@16GB (CAM Control) SSDs in a ZIL. I plan on moving those to the new mirrored production pool. Use case of my production pool is bulk storage as well as an iSCSI target for ESXi VMs. I also have another faster SSD based pool for some other VMs using iSCSI.
All this is running on SAS 2008 HBA infrastructure (see sig).
Anyway, any comments are welcome as I do not want to make a fatal error as I upgrade my system.
Thank you,
Thank you,
