Pool is offline. i/o failure. don't use sata to pci 1x cards.. Drives are fine.
No idea if it would be the motherboard. But your pool looks like it's available. The next question that I don't think you ever answered: What happens when you try to import the pool using the GUI? You'd talked about trying to create a new pool, which is definitely the wrong answer. Go to Storage -> Pools -> Add, select Import an existing pool, next, No, continue with import, next. Does it list your pool in the drop-down?
CookieMonster1
This pool is doing fine. Not offline. Look at the drives might show the same thing. I do know this pool is SMR and that's why I got the new 4x16TB drives. This is a pool I don't really use, so its really empty.
Pool 1
4x8TB
root@truenas[~]# smartctl -a /dev/ada2
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p1 amd64] (local build)
Model Family:     Seagate BarraCuda 3.5 (SMR)
Device Model:     ST8000DM004-2U9188
Serial Number:
LU WWN Device Id: 5 000c50 0dbf1ae62
Firmware Version: 0001
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Oct 18 12:39:49 2022 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (    0) seconds.
capabilities:                    (0x73) SMART execute Offline immediate.
                                        command.
                                        No Offline surface scan supported.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        (1006) minutes.
Conveyance self-test routine
SCT capabilities:              (0x30a5) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   072   064   006    Pre-fail  Always       -       15642679
  3 Spin_Up_Time            0x0003   092   091   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       49
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   085   060   045    Pre-fail  Always       -       287698890
  9 Power_On_Hours          0x0032   093   093   000    Old_age   Always       -       6710h+48m+52.923s
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       48
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0 0 0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   057   052   040    Old_age   Always       -       43 (Min/Max 41/48)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       24
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       50
194 Temperature_Celsius     0x0022   043   048   000    Old_age   Always       -       43 (0 23 0 0 0)
195 Hardware_ECC_Recovered  0x001a   072   064   000    Old_age   Always       -       15642679
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       6685h+35m+00.986s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       2325685573
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       4707377187
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%       304         -
# 2  Short offline       Completed without error       00%       285         -
# 3  Short offline       Completed without error       00%       285         -
root@truenas[~]# smartctl -a /dev/ada3
Device Model:     ST8000DM004-2CX188
Serial Number:
LU WWN Device Id: 5 000c50 0dc3a6fa4
Rotation Rate:    5425 rpm
Local Time is:    Tue Oct 18 12:40:18 2022 PDT
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 995) minutes.
  1 Raw_Read_Error_Rate     0x000f   071   063   006    Pre-fail  Always       -       11613650
  3 Spin_Up_Time            0x0003   093   091   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       95
  7 Seek_Error_Rate         0x000f   086   060   045    Pre-fail  Always       -       354934005
  9 Power_On_Hours          0x0032   093   093   000    Old_age   Always       -       6710h+53m+13.567s
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       47
190 Airflow_Temperature_Cel 0x0022   058   053   040    Old_age   Always       -       42 (Min/Max 40/47)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       289
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       362
194 Temperature_Celsius     0x0022   042   047   000    Old_age   Always       -       42 (0 24 0 0 0)
195 Hardware_ECC_Recovered  0x001a   071   064   000    Old_age   Always       -       11613650
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       6651h+13m+56.710s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       2314477859
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       4803286699
No Errors Logged
# 1  Extended offline    Completed without error       00%      5872         -
# 2  Extended offline    Completed without error       00%      5637         -
# 3  Extended offline    Completed without error       00%      5437         -
# 4  Extended offline    Interrupted (host reset)      90%      5105         -
# 5  Extended offline    Interrupted (host reset)      00%       286         -
# 6  Short offline       Completed without error       00%       285         -
# 7  Short offline       Completed without error       00%       285         -
root@truenas[~]# smartctl -a /dev/ada7
Serial Number:
LU WWN Device Id: 5 000c50 0dc426ce7
Add. Product Id:  DELL(tm)
Local Time is:    Tue Oct 18 12:40:47 2022 PDT
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1002) minutes.
  1 Raw_Read_Error_Rate     0x000f   083   064   006    Pre-fail  Always       -       209194139
  3 Spin_Up_Time            0x0003   096   091   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       458
  7 Seek_Error_Rate         0x000f   083   060   045    Pre-fail  Always       -       211418140
  9 Power_On_Hours          0x0032   093   093   000    Old_age   Always       -       6954h+19m+21.658s
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       458
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       0 0 64
190 Airflow_Temperature_Cel 0x0022   055   053   040    Old_age   Always       -       45 (Min/Max 42/45)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       436
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       897
194 Temperature_Celsius     0x0022   045   047   000    Old_age   Always       -       45 (0 24 0 0 0)
195 Hardware_ECC_Recovered  0x001a   083   064   000    Old_age   Always       -       209194139
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       6779h+21m+03.415s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       1607510212
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       4816067514
No Errors Logged
# 1  Extended offline    Completed without error       00%      1092         -
# 2  Short offline       Completed without error       00%      1076         -
# 3  Short offline       Completed without error       00%      1076         -
root@truenas[~]# smartctl -a /dev/ada9
Serial Number:
LU WWN Device Id: 5 000c50 0c9540cf0
Local Time is:    Tue Oct 18 12:42:00 2022 PDT
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1005) minutes.
  1 Raw_Read_Error_Rate     0x000f   064   063   006    Pre-fail  Always       -       209672089
  3 Spin_Up_Time            0x0003   093   092   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       109
  7 Seek_Error_Rate         0x000f   086   060   045    Pre-fail  Always       -       438990868
  9 Power_On_Hours          0x0032   086   086   000    Old_age   Always       -       12448h+59m+50.268s
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       62
190 Airflow_Temperature_Cel 0x0022   056   051   040    Old_age   Always       -       44 (Min/Max 42/47)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       417
193 Load_Cycle_Count        0x0032   098   098   000    Old_age   Always       -       5534
194 Temperature_Celsius     0x0022   044   049   000    Old_age   Always       -       44 (0 24 0 0 0)
195 Hardware_ECC_Recovered  0x001a   083   064   000    Old_age   Always       -       209672089
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       10803h+06m+14.150s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       14621176501
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       40590116712
No Errors Logged
# 1  Extended offline    Interrupted (host reset)      00%      6024         -
# 2  Short offline       Completed without error       00%      6023         -
# 3  Short offline       Completed without error       00%      6023         -
CookieMonster1
Pool 0
2x4TB
root@truenas[~]# smartctl -a /dev/ada0
Device Model:     ST4000DM004-2CV104
Serial Number:
LU WWN Device Id: 5 000c50 0b49baec5
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Local Time is:    Tue Oct 18 12:49:40 2022 PDT
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 481) minutes.
  1 Raw_Read_Error_Rate     0x000f   078   064   006    Pre-fail  Always       -       64822308
  3 Spin_Up_Time            0x0003   097   096   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   098   098   020    Old_age   Always       -       2494
  7 Seek_Error_Rate         0x000f   078   060   045    Pre-fail  Always       -       56496258
  9 Power_On_Hours          0x0032   074   074   000    Old_age   Always       -       23033h+31m+20.188s
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       509
190 Airflow_Temperature_Cel 0x0022   055   054   040    Old_age   Always       -       45 (Min/Max 41/46)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       339
193 Load_Cycle_Count        0x0032   090   090   000    Old_age   Always       -       20003
194 Temperature_Celsius     0x0022   045   046   000    Old_age   Always       -       45 (0 22 0 0 0)
195 Hardware_ECC_Recovered  0x001a   078   064   000    Old_age   Always       -       64822308
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       12680h+12m+20.899s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       35744619388
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       46513723252
No Errors Logged
# 1  Short offline       Completed without error       00%     16608         -
# 2  Short offline       Completed without error       00%     16608         -
root@truenas[~]# smartctl -a /dev/ada5
Serial Number:
LU WWN Device Id: 5 000c50 0bf104d20
Local Time is:    Tue Oct 18 12:50:09 2022 PDT
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 478) minutes.
  1 Raw_Read_Error_Rate     0x000f   100   064   006    Pre-fail  Always       -       226961
  4 Start_Stop_Count        0x0032   099   099   020    Old_age   Always       -       1880
  7 Seek_Error_Rate         0x000f   078   060   045    Pre-fail  Always       -       59275443
  9 Power_On_Hours          0x0032   075   075   000    Old_age   Always       -       22333h+15m+22.938s
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       499
190 Airflow_Temperature_Cel 0x0022   058   054   040    Old_age   Always       -       42 (Min/Max 38/44)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       379
193 Load_Cycle_Count        0x0032   092   092   000    Old_age   Always       -       17935
194 Temperature_Celsius     0x0022   042   046   000    Old_age   Always       -       42 (0 22 0 0 0)
195 Hardware_ECC_Recovered  0x001a   100   064   000    Old_age   Always       -       226961
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       12308h+53m+46.795s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       29963498239
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       45738748661
No Errors Logged
# 1  Short offline       Completed without error       00%     15908         -
# 2  Short offline       Completed without error       00%     15907         -
CookieMonster1
CookieMonster1
You know, it's really hard to help you when you keep running off on tangents rather than directly answering our questions.
If I was having a power supply problem it would show inside the all the other drives. Its only seems to be having the a problem with my 4x16TB pool.
Not necessarily; even within the problem pool, the power cycle counts are very inconsistent.
That pool is showing the problem to a greater degree, but at least some of the other disks you've posted have very inconsistent power cycle counts too. See ada7, for example.
ada7 going offline is a problem, but as it isn't part of Rabbit2, shouldn't be directly relevant--though it may indicate (as has been suggested elsewhere in this thread) broader hardware problems. But what's strange is that the GUI is showing Rabbit2 as kind of there, kind of not. Does zpool status Rabbit2 show it online? If not, try zpool import -F Rabbit2 and see if it will import.
CookieMonster1
Reran the commands and same thing. Please tell me it still can be fine at least a bit. If anything I do have a backup but its from 1 year ago and would lose over 2TB of data..
HoneyBadger
actually does care
Administrator
A question that I don't know if I ever saw an answer to:
My hard drives are connect through sata to pci. 2x cards. 4x sata cables. Total of 12 drives running.
Please describe in detail these "SATA to PCI" cards.
