Plugins will not appear in tree
enigma2060
I'm attempting to install CrashPlan, it shows as ver 3.6.3 After installation completes crashplan never appears under the Plugins section of the tree. Therefore I cannot proceed with the Java portion. Also the service will not start. This issue is not just isolated to crashplan but any plugin i attempt to install. Simply put, no plugin will install. First i did an upgrade, thinking it would resolve this, when it did not I did a full install from scratch.
FreeNas ver (was 9.2.1.5) upgraded to 9.3
what log files can I pull to find what is in the way?
any info is appreciated.
Fuganater
Did you upload it or install from the catalog?
enigma2060
I installed from Catalog Available. Crashplan shows up in the Installed tab but will not start and does not appear in the tree.
D
dlavigne
Guest
What error do you get when you try to start it? Anything in /var/log/messages?
enigma2060
Here is what I see
enigma2060
from /var/log/messages
Oct 25 09:55:16 freenas manage.py: [plugins.utils:92] Couldn't retrieve http://1
92.168.0.7/plugins/crashplan/3/_s/status: No JSON object could be decoded
Oct 25 09:55:36 freenas manage.py: [freeadmin.navtree:573] Couldn't retrieve htt
p://192.168.0.7/plugins/crashplan/3/_s/treemenu: timed out
