Plex on NAS
Steff0252
Hello
Has built iTrueNas about 36TB distributed on some poles
I am a total beginner in both NAS values and Plex
I have previously saved movies, music, etc. in various folders.
I have subscribed to Plex and want to install it on my Nas
I have watched various YouTube videos how, but have not been able to find anyone who can help me install Plex on already created folders with media content.
Is there any such help?
The video help I have watched is for totally empty folders where you have to add material!
Is it possible to install Plex on existing content folders?
Would be grateful for help
Steff
NugentS
Yes - but bear two things in mind.
1. You have to set up mount points to mount the existing media into the TN jail/docker
2. Permissions - the user running inside the jail / docker needs permissions on the files. You do this by finding the UID the in jail user is using and then duplicate that in Core/Scale and then giving that user permissions to the files
Steff0252
Hello
Thanks for your reply
Since I'm new to this, maybe you know if there is any video (YouTube), on the whole, that would have made it easier?
Steff
kherr
Many ......
ddaenen1
2 things need to be done:
1. you need to define mountpoints in the jail
2. You need to add the directories to your library in Plex
NugentS
1.5 Permissions - the user running inside the jail / docker needs permissions on the files. You do this by finding the UID the in jail user is using and then duplicate that in Core/Scale and then giving that user permissions to the files
Otherwise plex won't see the files - potentially, depending upon what the default ACL is set to
Steff0252
Thanks for your advice
I have tried to give permission to everyone in jail, but when I get Plex it does not find the folders
But I will not give up
Thanks
NugentS
The permissions must be applied at the TN level. Not the Jail (assuming the source folders are outside the jail)
NugentS
TrueNAS
Steff0252
Sorry, of course, have not started thinking about abbreviations
You mean I have to give permission to the user and group, as I have done
I have created datasets in my pool's (which I have seen on video) entered the ACL and given permission as user and root
I have shared in Share SMB for each pool and dataset
Where else should I give permission in TN
NugentS
So plex runs inside the plex jail as user ID xxx (probably 900 and something) - look in /etc/passwd
Create a user in TN with that UID and give that user permissions to the Datasets that are being mounted
Steff0252
now I understand, so what I see in the shell that plex is XXX, then I have to create a user with that number and assign it in the ACL and everywhere else?
My TN
NugentS
Not on the SMB Share, thats irrelavent. On the dataset itself
