Plex Plugin: Not finding all media
florian123
Hi
I recently set up my first FreeNas machine. Everything is working as I wanted it to, except for the Plex plugin. I have a folder full of movies (a few thousand, some in subfolders). The Plex Server is running and I can play stuff from it, but the majority of the content is missing. Subfolders of Folders appear, but the films in them don't. I'm a beginner and don't know how I could solve this.
nojohnny101
Have you made sure that your media follows standard plex naming conventions?
Plex can be a bit tricky sometime and I have personally experienced cases where plex pretended like media wasn't there but after a simple filename change, it all of a sudden showed up.
See here
Also make sure you have correct settings on the "server settings" portion of the configuration for plex. That you have local assets set a a place it can pull metadata from.
