Plex jail died (again)
ajschot
EDIT: It took too much time, so problem is not solved, but i just setup a new jail and new library to have it work.
Wow since i am back in jails i have all the problems again!
I hate jails!!!! Sure they need less recources but they break all the time and have to install it all again and setup.... i am getting so frustrated about this!
Please somebody i need help!
Yesterday i needed to install plex again, day before too and... you guess what.... today again!
Please help! It is just that the server is not reacheable any more, the service is running and i can not reach it even restart jail or restart fn11 won't work!
What to install again and have my metadata so won't have to setup everything again this is making me so angry! All the time this ^*(#@%^&*!% old FN shit shits on me.... i miss docker!
I just connected when i got kicked and the server got unreacheable and from that point on it does not work anymore this happens all the time.
I tried normal plex and plex pass but it does not matter
No smart errors nor errors when i did a scrub so it is something really strange that let the thing die
ajschot
tried to update or upgrade but also this does not work please anybody know?
Currently ran a standard created jail with plexpass version on FN11-RC4
adrianwi
You probably already know this, but if you're looking for a more stable experience then stop using the bleeding edge versions!
I'm running FreeNAS 9.10.1-U4 and Plex 1.5.5 and haven't had a single issue with either.
scrappy
Haven't really had any problems with my Plex jail and jails are generally pretty stable. That said, I didn't go the plug-in route. Instead, I created a basic jail and manually installed the plexmediaserver-plexpass package from the pkg manager.
SweetAndLow
Sweet'NASty
Hardware specs required for every new post.
Is Plex running in the jail? pa auxw | grep plex
Jailer
Not strong, but bad
The important piece from his sig
Running ESXi with Windows 10, macOS, FreeNAS Corral, FreeNAS 11 (stable train)
ajschot
This is exactly my route....
The plex service is running but i updated the library and then it stopped working and i can start the service but it does not load gui and does not connect to my plex account.
ajschot
Pleas this is really not relevant for this situation i am sure about this i am not the only one running in ESXi and there are no good working alternatives for my setup.
Also it is no help to only start about this i need to know why plex crashes
Jailer
Not strong, but bad
Check your jails advanced settings and make sure they don't have the same MAC address causing a conflict. A few users have been reporting this problem lately.
SweetAndLow
Sweet'NASty
Can you please provide proof that it's running. If you just shoot down every idea without providing more info or proof don't bother asking for help.
What is the output of service plexmediaserver onestart?
ajschot
Hardware specs are just in my sign....
ESXi 96Gb EEC ram Xeon E5-2658v4 host with FN11 RC4 ( i know it is still not the final release but i would like to find a problem and not people start to get angry why things are not working when it is released) 64Gb reserved for FN11 and 16 cores.
I run 2 LSI 9211-8i IT (direct passthrough) with a bunch of disk for 3 zpools. One of them is for jails which are 2 64GB SSD's in mirror.
I had it working, copied some content in the mounted map. On data pool. Updated library and then lost connection.
Things i tried:
- restarted jail
- update, upgrade jail
- reboot FN11 vm
I know it will work in a new jail but why will it not work..... this happens now a couple of times and i would like to know why
Last logs from plex are empty files.
ajschot
I already checked besides that i did not make new jails in that time. But i can check that again it would mean that the mac addresses changed out of knowere.... that would be a bug
EDIT: no double mac address
SweetAndLow
Sweet'NASty
You keep avoiding the fact that you haven't provided any information. As far as I know you don't even have Plex installed.
ajschot
root@PlexServer:/ # service plexmediaserver_plexpass start
plexmediaserver_plexpass already running?  (pid=62927).
root@PlexServer:/ #
ajschot
Are you trying to help or are you just bashing everyone that has a problem and you mark as the most stupid noob out here?
ajschot
Also here is the system process showing it is running
Well, when you make nonsensical universal statements that are inconsistent with the experience of the vast majority here, it's hard to take you very seriously. When you're running pre-release software and complaining about instability, it's hard to take you seriously. When you start a thread about a problem with pre-release software, and don't put it in the forums for testing pre-release software, more of the same.
But yeah, jails suck. Docker rules. Whatever.
ajschot
At first i was running 9.10 then i saw that there was a FreeNAS 11- Stable Train so i thought they finished it, when installed i saw it was RC1. But i am now not going back so maybe making a stable train is not smart to start with.
ajschot
Hello all,
I have a problem reagrding to jails in FN11 (RC3 and now RC4)
Plex jail is not reacheable anymore, service is running but for some reason the web gui is not reachable.
To be clear it was running, i had this also a couple of days ago but for some reason yesterday it stopped working again.
I tried the normal plex media server first, but after 2 days it was not reachable and then i created a new jail with plex-pass, but now after 1,5 days of running fine i have the same problem.
plexmediaserver_plexpass already running?  (pid=53619).
root@PlexServer:/ #
last pid: 56379;  load averages:  0.09,  0.18,  0.16  up 0+23:17:09	10:49:28
81 processes:  1 running, 80 sleeping
Mem: 12M Active, 995M Inact, 61G Wired, 794M Free
ARC: 54G Total, 10G MFU, 42G MRU, 1359K Anon, 214M Header, 1756M Other
Swap: 24G Total, 131M Used, 24G Free
  PID USERNAME	THR PRI NICE   SIZE	RES STATE   C   TIME	WCPU COMMAND
26121 root		  1  21	0   343M 24324K select  9  68:30   1.37% smbd
7370 root		 16  20	0   528M   155M umtxn  13   1:49   0.10% uwsgi
3551 root		 12  20	0   207M 15332K nanslp 12   8:25   0.00% collectd
9323 root		  7  20	0   116M 22484K nanslp  4   4:51   0.00% nzbget
3477 root		 43  46	0   102M 20760K uwait   3   2:40   0.00% consul
57240 root		  2  20	0   127M 30980K select 13   2:31   0.00% python3.6
3434 root		  1  23	0   302M 38448K select 12   1:24   0.00% python3.6
9369	950		2  20	0   291M   102M kqread  5   1:17   0.00% python2.7
9807	921		4  20	0 90436K  6264K kqread 15   1:00   0.00% transmission-daemon
37590 media		20  20	0   203M 69900K select 10   0:57   0.00% python2.7
2531 root		  2  20	0 58984K  3840K select 15   0:43   0.00% vmtoolsd
31519 root		  6  20	0   171M 72608K select  0   0:16   0.00% python2.7
  215 root		  6  20	0   410M 83476K kqread  4   0:11   0.00% python3.6
3445 root		  1  20	0   408M 71576K kqread  2   0:09   0.00% uwsgi
3481 root		 44  20	0 71152K  9456K uwait  14   0:08   0.00% consul-alerts
53663	972	   22  41	0   162M 30932K usem	8   0:07   0.00% Plex DLNA Server
1624 root		  1  20	0 62008K  3028K kqread 11   0:06   0.00% syslog-ng
53652	972	   14  52   15   184M 48736K piperd 18   0:06   0.00% Plex Script Host
As you can see the service is running.
But when i try to reach it at IP:32400/web and also in plex.tv it can't find the server anymore, and not in apps DNLA is also not reachable.
I can't anymore, it stopped when i tried to let the library scan for new files.
I have no idea, i tried to restart the jail, update, upgrade and restart the whole FN11, also checked if the IP address was doubled and if the mac address of the jail was doubled but that was not the issue.
Also just did a forced install and that also did not do the trick.
I run FN11 in ESXi 6.5 with 16 cores avialeble of my E5-2658v4 and 64GB ECC reserved memory for just only this VM. 2x LSI9211-8i IT passthrough VM. I have some other jails running that are working fine at the moment.
Only thing i did what maybe involved is that i set all up already for the other Plex before that when i made the new jail i copied the macaddress from the old deleted jail.
Is tere a reason why this happend or any way to find this out?
Also for now important is there a way to get this working again or do i have to install again an set everything up again from the start?
Jailer
Not strong, but bad
How are your jails getting their IP address, static or DHCP? With other jails working and the Plex service running it sure sounds like an IP conflict.
