jeffmnelson
Neophyte
- May 8, 2018
My Plex jail just stopped working about a week ago. After exhausting every option I could think of, I removed Plex and tried to re-install it. When I tried to install the Plex plugin I get the following error:
Exception Value: [MiddlewareError: Failed to download http://download.freenas.org/plugins/9/x64: HTTP Error 404: Not Found]
I am able to install other plugins so I know the issue is just with Plex for some reason.
To get around this, I installed Plex by downloading the latest PBI from http://download.freenas.org/plugins/9/x64/. This allowed me to install it but it installs version 1.9. I figured I could install it and then just update it but when I SSH into the new, custom jail and run the PMS_Updater update script I have always used in the past, it doesn't work. The script runs properly but when I then fire up Plex again, it's still running an old version.
From what I've read, this is because the PMS_Updater isn't designed to run on custom jails and only updates when installing from the Plugin menu. I also tried the PKG Update from within the jail but that doesn't seem to do anything either. What I'm looking for is either a way to install using the plugin menu so I can do things the way I've always done or a way to update my new, working plex install in my custom jail.
Thanks
Thanks
