Mannekino
 - Nov 14, 2012
:D
I managed to get it to work. The problem was with the setting
Is the share you want to access located on a FreeNAS server also or is it some other kind of server?
Here it is:
Also don't forget I had to enable a kernel module on the FreeNAS server I was connecting from for this to work:
server min protocol you can find this in /etc/local/smb4.conf. This was changed in FreeNAS 11.1-U6 you can find more information here including a permanent solution by adding a tuneable. Remember this has to be done on the FreeNAS server you're connecting to.Is the share you want to access located on a FreeNAS server also or is it some other kind of server?
Here it is:
root@freenas[~]# mount_smbfs -I 192.168.178.10 //<user>@freeas-test/testing /mnt/testing/ Password: root@freenas[~]# cd /mnt/testing root@freenas[/mnt/testing]# ls -al total 16 drwxr-xr-x 1 root wheel 16384 Jan 1 1970 . drwxr-xr-x 5 root wheel 256 Feb 10 23:20 .. -rwxr-xr-x 1 root wheel 8 Feb 13 07:10 Test.txt
kldload smbfs
