mistermanko
- Jan 27, 2020
Would be very neat of you if you could share your complete script either here as attachment - or even better - as a git(hub). So everybody can join in to further improve this.Here's how to get the PID fan controller Perl script on TrueNAS SCALE. I started with this script and had it running for years on freeNAS then TrueNAS Core. I originally had it for SATA drives, then moved to SAS and had to customize it for the output of those so I can start tracking the SAS temps. Moving to SCALE was... interesting as all stopped working. Hello there, Linux.I had to further customize mine to fit my setup as I discovered camcontrol is gone and so is sysctl. Joy. But, in the end, it turned out quite okay and the changes were minimal. I keep my folder with the fan controller in /root/nas_fan_control-master and start it in SCALE with the command (in GUI it is command not script): bash /root/start_fan_controller, which a single-liner to start the pl file and log it.
Code:#!/bin/bash echo "Starting Fan Controller..." /root/nas_fan_control-master/PID_fan_control.pl &>> /root/nas_fan_control-master/PID_fan_control.log &
The only changes required when moving from FreeBSD to Linux were:
1. perl, ipmitool locations:
fromtoCode:$ipmitool = "/usr/local/bin/ipmitool";Look through your script's files for /usr/local/bin and remove the /local so it becomes /usr/bin/whateverCode:$ipmitool = "/usr/bin/ipmitool";
2. With camcontrol gone I switched to lsblk:
fromtoCode:$disk_list = `camcontrol devlist | grep -v "SSD" | grep -v "Verbatim" | grep -v "Kingston" | grep -v "Elements" | sed 's:.*(::;s:).*::;s:,pass[0-9]*::;s:pass[0-9]*,::' | egrep '^[a]*da[0-9]+\$' | tr '\012' ' '`;All I did was ssh into my SCALE, then ran lsblk -d -n -o model,name, that pulled up drive model and identifier. Then I started grepping what I did not need (the SSD) and then I amended the sed part to remove my model till all I had left was the name of the drives, in my cases those were sda through sdk (sdl was the ssd so it was grep -v for it).Code:$disk_list = `lsblk -d -n -o model,name | grep -v "SSD" | grep -v "Verbatim" | grep -v "Kingston" | grep -v "Elements" | sed 's:YOURDRIVEMODEL .::;' | tr '\012' ' '`;
3. Another example of a small tweak (grep and vals of note here). Sorry, did not bother to change the comments:
fromtoCode:foreach my $item (@hd_list) { my $disk_dev = "/dev/$item"; my $command = "/usr/local/sbin/smartctl -A $disk_dev | grep Temperature_Celsius"; my $output = `$command`; my @vals = split(" ", $output); # grab 10th item from the output, which is the hard drive temperature (on Seagate NAS HDs) my $temp = "$vals[9]"; chomp $temp;Code:foreach my $item (@hd_list) { my $disk_dev = "/dev/$item"; my $command = `/usr/sbin/smartctl -A $disk_dev | grep "Current Drive Temperature"`; my $output = $command; my @vals = split(" ", $output); # grab 10th item from the output, which is the hard drive temperature (on Seagate NAS HDs) my $temp = "$vals[3]"; chomp $temp;
3. With sysctl gone I switched to sensors for cpu temp reading since it came preinstalled on SCALE:
fromtoCode:my $core_temps = `sysctl -a dev.cpu | egrep -E \"dev.cpu\.[0-9]+\.temperature\" | awk '{print \$2}' | sed 's/.\$//'`;Code:my $core_temps = `sensors | egrep -E \"Core [0-9]+\" | awk '{print \$3}' | tr -d '+' | sed 's/.0°C//'`; chomp($core_temps);
Of course it will greatly depend on your disk types and cpus you use: Intel/AMD, SATA vs SAS etc. I cannot stress this enough: use the awesome debug! Get it to 4 and a lot will become obvious. It's a lot of:
1. ps aux | grep -i PID_fan_control
2. kill -9 thePIDfromAbove
3. Upload via filezilla the new .pl file
4. Delete the old log files (otherwise the incorrectly logged values for disks you do NOT need will still show up in your .log and mess up your view - will make your values out of order/misplaced/skewed).
5. Start the script.
6. Wait for initial spin up and for all to quiet down (about 30s-45s)
7. Pull logs (debug and normal), inspect, make .pl corrections. Rinse and repeat.
Here's the output from my working setup after the changes I made. As you can tell from the timestamps... I just got it working:
Code:PID Fan Controller Log --- Target 6 Disk HD Temperature = 39.00 deg C --- PID Control Gains: Kp = 5.333, Ki = 0.000, Kd = 48.0 Max Ave Temp Fan Fan Fan % CPU P I D Fan 2023-01-14 sda sdb sdc sdd sde sdf sdg sdh sdi sdj sdk Temp Temp Err Mode RPM Old/New Temp Corr Corr Corr Duty 19:11:12 36 36 36 36 37 38 37 38 36 39 38 ^39 37.83 -1.17 Full 2800 30/21 41 -9.33 -0.00 0.00 20.67% 19:12:43 36 36 34 36 37 38 37 38 34 39 38 ^39 37.83 -1.17 Full 2300 21/11 40 -9.33 -0.00 0.00 11.33% 19:14:13 36 36 36 36 37 38 37 38 36 39 38 ^39 37.83 -1.17 Full 2200 11/10 41 -9.33 -0.00 0.00 10.00% 19:15:42 36 37 36 36 37 38 38 38 36 39 39 ^39 38.17 -0.83 Full 2400 10/14 40 -6.67 -0.00 10.67 14.00% 19:17:13 36 37 36 37 37 38 38 38 36 39 38 ^39 38.00 -1.00 Full 2200 14/10 42 -8.00 -0.00 -5.33 10.00% 19:18:42 36 37 36 37 37 38 38 38 36 39 39 ^39 38.17 -0.83 Full 2200 10/10 40 -6.67 -0.00 5.33 10.00% 19:20:13 36 37 36 37 37 38 38 38 36 39 39 ^39 38.17 -0.83 Full 2200 10/10 41 -6.67 -0.00 0.00 10.00% 19:21:43 36 37 36 37 37 39 38 39 36 39 39 ^39 38.50 -0.50 Full 2500 10/17 41 -4.00 -0.00 10.67 16.67% 19:23:13 36 37 36 37 37 39 38 38 36 39 39 ^39 38.33 -0.67 Full 2200 17/10 41 -5.33 -0.00 -5.33 10.00% 19:24:43 36 37 36 37 37 39 38 39 36 39 39 ^39 38.50 -0.50 Full 2200 10/11 43 -4.00 -0.00 5.33 11.33% 19:26:12 36 37 36 37 37 39 38 39 36 39 39 ^39 38.50 -0.50 Full 2200 11/10 41 -4.00 -0.00 0.00 10.00% 19:27:43 37 37 37 37 37 39 38 39 36 39 39 ^39 38.50 -0.50 Full 2200 10/10 42 -4.00 -0.00 0.00 10.00% 19:29:12 37 37 36 37 38 39 38 39 37 39 39 ^39 38.67 -0.33 Full 2300 10/13 41 -2.67 0.00 5.33 12.67% 19:30:43 37 38 37 37 38 39 38 39 37 39 39 ^39 38.67 -0.33 Full 2200 13/10 41 -2.67 -0.00 0.00 10.00% 19:32:13 37 38 37 37 38 39 38 39 37 39 39 ^39 38.67 -0.33 Full 2200 10/10 42 -2.67 -0.00 0.00 10.00% 19:33:42 37 38 37 37 38 39 38 39 37 39 39 ^39 38.67 -0.33 Full 2200 10/10 42 -2.67 -0.00 0.00 10.00% PID Fan Controller Log --- Target 6 Disk HD Temperature = 39.00 deg C --- PID Control Gains: Kp = 5.333, Ki = 0.000, Kd = 48.0 Max Ave Temp Fan Fan Fan % CPU P I D Fan 2023-01-14 sda sdb sdc sdd sde sdf sdg sdh sdi sdj sdk Temp Temp Err Mode RPM Old/New Temp Corr Corr Corr Duty 19:36:09 37 38 37 38 38 39 38 39 37 39 39 ^39 38.67 -0.33 Full 3100 30/27 42 -2.67 -0.00 0.00 27.33%
Hope this helps someone. My respect to the creator(s) of the script for their amazing work.
Thanks!
