Permission problem after upgrade
shadowempire
Hi TrueNAS community,
maybe somebody can help with my problem...
I have a HP Microserver Gen8 which I just upgraded from "TrueNAS CORE 12.0-U5.1" to "TrueNAS-SCALE-21.08-BETA.1".
Upgrade did not work, got some error messages (maybe because I changed booting from "with USB chainloader" to "Raid boot").
But this is another story...
So in the end I did a fresh install.
Now I did an import from my data pools, created a new user and share, assigned the user permissions to the share...
Under Windows I can connect to the share with the user, and I can create folders....
But I can not access the existing folders within the share.
My username is roci
root@truenas:/# ls -lrta /mnt
total 19
drwxr-xr-x 20 root root 30 Aug 31 01:23 ..
drwxr-xr-x  3 root root  3 Sep 13 14:05 Pool4TB
drwxr-xr-x  5 root root  5 Sep 13 14:06 .
drwxr-xr-x  6 root root  6 Sep 13 14:07 PoolSSD256GB
drwxr-xr-x  3 root roci  3 Sep 14 11:15 tray3
root@truenas:/# ls -lrta /mnt/tray3/
total 10
drwxr-xr-x 5 root root 5 Sep 13 14:06 ..
drwxrwx--- 6 roci roci 6 Sep 14 10:40 media
drwxr-xr-x 3 root roci 3 Sep 14 11:15 .
root@truenas:/# ls -lrta /mnt/tray3/media/
total 27
d---------  3 roci roci  3 May  2 13:56  archiv
d--------- 10 roci roci 12 Sep  2 18:08  downloads
d---------  8 roci roci  8 Sep 13 19:11  2watch
drwxrwxrwx  2 roci roci  2 Sep 14 10:40 'Neuer Ordner'
drwxrwx---  6 roci roci  6 Sep 14 10:40  .
drwxr-xr-x  3 root roci  3 Sep 14 11:15  ..
I think it is related to acl reset permissions, but I could not figure it out.
thx for an help!
shadowempire
ls -l is the wrong tool to see ACLs. If it's nfs4 acl `nfsxdr_getfacl` if posix1e `getfacl`.
root@truenas:~# getfacl /mnt getfacl: Removing leading '/' from absolute path names # file: mnt # owner: root # group: root user::rwx group::r-x other::r-x root@truenas:~# getfacl /mnt/tray3 getfacl: Removing leading '/' from absolute path names # file: mnt/tray3 # owner: root # group: roci user::rwx group::r-x other::r-x root@truenas:~# getfacl /mnt/tray3/media/ getfacl: Removing leading '/' from absolute path names # file: mnt/tray3/media/ # owner: roci # group: roci user::rwx group::rwx other::---
anodos
Sambassador
If this came from FreeBSD it should have NFSv4 acltype if you want to preserve your permissions. POSIX1e getfacl will fake-up and ACL if one is not present. These particular tools are not meant to be user facing and so they are somewhat inconvenient. You can also try `midclt call filesystem.getacl <path>` which will show the right thing regardless of ACL type.
shadowempire
well, I am on TrueNAS-SCALE-21.08-BETA.1 which runs under Linux.
here is more info:
root@truenas:~# uname -a Linux truenas.local 5.10.42+truenas #1 SMP Mon Aug 30 21:54:59 UTC 2021 x86_64 GNU/Linux root@truenas:~# midclt call filesystem.getacl /mnt {"uid": 0, "gid": 0, "acl": [{"default": false, "tag": "USER_OBJ", "id": -1, "perms": {"READ": true, "WRITE": true, "EXECUTE": true}}, {"default": false, "tag": "GROUP_OBJ", "id": -1, "perms": {"READ": true, "WRITE": false, "EXECUTE": true}}, {"default": false, "tag": "OTHER", "id": -1, "perms": {"READ": true, "WRITE": false, "EXECUTE": true}}], "flags": {"setuid": false, "setgid": false, "sticky": false}, "acltype": "POSIX1E", "trivial": true} root@truenas:~# midclt call filesystem.getacl /mnt/tray3 {"acl": [{"tag": "owner@", "id": -1, "perms": {"READ_DATA": true, "WRITE_DATA": true, "EXECUTE": true, "APPEND_DATA": true, "DELETE_CHILD": false, "DELETE": false, "READ_ATTRIBUTES": true, "WRITE_ATTRIBUTES": true, "READ_NAMED_ATTRS": true, "WRITE_NAMED_ATTRS": true, "READ_ACL": true, "WRITE_ACL": true, "WRITE_OWNER": true, "SYNCHRONIZE": true}, "flags": {"BASIC": "NOINHERIT"}, "type": "ALLOW"}, {"tag": "group@", "id": -1, "perms": {"READ_DATA": true, "WRITE_DATA": false, "EXECUTE": true, "APPEND_DATA": false, "DELETE_CHILD": false, "DELETE": false, "READ_ATTRIBUTES": true, "WRITE_ATTRIBUTES": false, "READ_NAMED_ATTRS": true, "WRITE_NAMED_ATTRS": false, "READ_ACL": true, "WRITE_ACL": false, "WRITE_OWNER": false, "SYNCHRONIZE": true}, "flags": {"BASIC": "NOINHERIT"}, "type": "ALLOW"}, {"tag": "everyone@", "id": -1, "perms": {"READ_DATA": true, "WRITE_DATA": false, "EXECUTE": true, "APPEND_DATA": false, "DELETE_CHILD": false, "DELETE": false, "READ_ATTRIBUTES": true, "WRITE_ATTRIBUTES": false, "READ_NAMED_ATTRS": true, "WRITE_NAMED_ATTRS": false, "READ_ACL": true, "WRITE_ACL": false, "WRITE_OWNER": false, "SYNCHRONIZE": true}, "flags": {"BASIC": "NOINHERIT"}, "type": "ALLOW"}], "trivial": false, "uid": 0, "gid": 0, "path": "/mnt/tray3", "nfs41_flags": {"protected": false, "autoinherit": true}, "acltype": "NFS4"} root@truenas:~# midclt call filesystem.getacl /mnt/tray3/media {"acl": [{"tag": "owner@", "id": -1, "perms": {"READ_DATA": true, "WRITE_DATA": true, "EXECUTE": true, "APPEND_DATA": true, "DELETE_CHILD": true, "DELETE": false, "READ_ATTRIBUTES": true, "WRITE_ATTRIBUTES": true, "READ_NAMED_ATTRS": true, "WRITE_NAMED_ATTRS": true, "READ_ACL": true, "WRITE_ACL": true, "WRITE_OWNER": true, "SYNCHRONIZE": true}, "flags": {"BASIC": "NOINHERIT"}, "type": "ALLOW"}, {"tag": "group@", "id": -1, "perms": {"READ_DATA": true, "WRITE_DATA": true, "EXECUTE": true, "APPEND_DATA": true, "DELETE_CHILD": true, "DELETE": false, "READ_ATTRIBUTES": true, "WRITE_ATTRIBUTES": false, "READ_NAMED_ATTRS": true, "WRITE_NAMED_ATTRS": false, "READ_ACL": true, "WRITE_ACL": false, "WRITE_OWNER": false, "SYNCHRONIZE": true}, "flags": {"BASIC": "NOINHERIT"}, "type": "ALLOW"}, {"tag": "everyone@", "id": -1, "perms": {"READ_DATA": false, "WRITE_DATA": false, "EXECUTE": false, "APPEND_DATA": false, "DELETE_CHILD": false, "DELETE": false, "READ_ATTRIBUTES": true, "WRITE_ATTRIBUTES": false, "READ_NAMED_ATTRS": true, "WRITE_NAMED_ATTRS": false, "READ_ACL": true, "WRITE_ACL": false, "WRITE_OWNER": false, "SYNCHRONIZE": true}, "flags": {"BASIC": "NOINHERIT"}, "type": "ALLOW"}], "trivial": true, "uid": 1001, "gid": 1001, "path": "/mnt/tray3/media", "nfs41_flags": {"protected": false, "autoinherit": false}, "acltype": "NFS4"}
shadowempire
Got no support yet :(
somebody else experiencing this problem or having a solution? - thx
Is there a command to repair my permissions?
oumpa31
I had the same issues I ended up removing all the permissions on all of my datasets and starting over. It took a couple hours but finally had access to everything. I noticed when i was trying to set ACL permissions in Scale21.08 it wouldn't set them recursively. I had to do that in windows.
anodos
Sambassador
There's a webui bug in 21.08 unfortunately that prevents setting permissions recursively. With nfs4 acltype, you can force inheritance by running the command `nfs4xdr_winacl -a clone -rv -p <path>`
shadowempire
thx, will try.
I agree, looks like there is a bug setting permissions recursively.
shadowempire
thx, seems it worked!
