calgarychris
- Aug 27, 2011
I've successfully installed Owncloud in a jail and am wondering how other folks have set it up, with regards to mounts to your data outside the jail. Is it best to set up a mount point and use that in the initial setup (when you create the first user) or create mount points later after you create users (and then mount under their "Files" directory)?
Thanks
Chris
Thanks
Chris
