SOLVED OS on USB w/no storage found
Darkhlmt
So,
I'm running FreeNAS on a UBS drive. I have two hard drives in the machine. I'm in FreeNAS and can move about. However, I cannot get the computer to find the drives. I have walked through the guide and haven't been able to resolve.
I shall continue my attempts. But, if anyone can help point me in the right direction. I do greatly appreciate it!
Darkhlmt
Your hardware compatible with FreeBSD?
You provided zero info as requested by the forum rules...
Darkhlmt
System setup
FreeNAS v. 9.2.1.1 (64-bit)
Computer HP dc-5750
CPU - AMD Athlon 64 X2 3800 (2 GHz)
RAM - 4 x 1GB dimms (DDR2 PC-5300)
NIC - Broadcom 5755
No RAID in use
Hard Drives
- Western Digital 80GB (WD800AAJS-22PSA0) (SATA-0)
- Seagate 500GB (ST500DM002-1BC142) (SATA-3)
- UBS 16GB (Boot drive)
Darkhlmt
So,
Darkhlmt
So,
Darkhlmt
# dmidecode 2.12
SMBIOS 2.4 present. Handle 0x0001, DMI type 0, 24 bytes BIOS Information Vendor: Hewlett-Packard Version: 786E3 v02.10 Release Date: 01/25/2007 Address: 0xE0000 Runtime Size: 128 kB ROM Size: 1024 kB Characteristics: PCI is supported PNP is supported BIOS is upgradeable BIOS shadowing is allowed Boot from CD is supported Selectable boot is supported EDD is supported Japanese floppy for Toshiba 1.2 MB is supported (int 13h) 5.25"/360 kB floppy services are supported (int 13h) 5.25"/1.2 MB floppy services are supported (int 13h) 3.5"/720 kB floppy services are supported (int 13h) Print screen service is supported (int 5h) 8042 keyboard services are supported (int 9h) Serial services are supported (int 14h) Printer services are supported (int 17h) ACPI is supported USB legacy is supported LS-120 boot is supported ATAPI Zip drive boot is supported BIOS boot specification is supported Function key-initiated network boot is supported Targeted content distribution is supported BIOS Revision: 2.10 Handle 0x0032, DMI type 13, 22 bytes BIOS Language Information Language Description Format: Long Installable Languages: 1 en|US|iso8859-1 Currently Installed Language: en|US|iso8859-1
Darkhlmt
# dmidecode 2.12 SMBIOS 2.4 present. Handle 0x0001, DMI type 0, 24 bytes BIOS Information Vendor: Hewlett-Packard Version: 786E3 v02.10 Release Date: 01/25/2007 Address: 0xE0000 Runtime Size: 128 kB ROM Size: 1024 kB Characteristics: PCI is supported PNP is supported BIOS is upgradeable BIOS shadowing is allowed Boot from CD is supported Selectable boot is supported EDD is supported Japanese floppy for Toshiba 1.2 MB is supported (int 13h) 5.25"/360 kB floppy services are supported (int 13h) 5.25"/1.2 MB floppy services are supported (int 13h) 3.5"/720 kB floppy services are supported (int 13h) Print screen service is supported (int 5h) 8042 keyboard services are supported (int 9h) Serial services are supported (int 14h) Printer services are supported (int 17h) ACPI is supported USB legacy is supported LS-120 boot is supported ATAPI Zip drive boot is supported BIOS boot specification is supported Function key-initiated network boot is supported Targeted content distribution is supported BIOS Revision: 2.10 Handle 0x0032, DMI type 13, 22 bytes BIOS Language Information Language Description Format: Long Installable Languages: 1 en|US|iso8859-1 Currently Installed Language: en|US|iso8859-1
D
dlavigne
Guest
ZFS Volume Manager won't let you create a pool out of drives of different sizes. You can use the Manual Setup button but you will get terrible performance on drives that different in size and the pool will be limited by the size of the smaller disk.
Darkhlmt
Would that prevent me from even seeing the phyiscal disks through FreeNAS.
As an FYI, I'm still a child in linux terms. I have been attempting to identify errors that have occurred and the only one that I've located and fixed was an issue with date/time. Now, I'm looking for a way to pause the output of dmesg. As of right now I use the command and it just spits out a bunch of info to which I can only see the last part.
Darkhlmt
Can you remove this post. I completely missed a section regarding bios settings. I have corrected the issue which was addressed in another thread.
Darkhlmt
Finally,
Solved my no detection issue. Within the HP bios for this computer I had to change the default from Legacy to Native IDE. Once I did that, drives popped up no problem.
Thank you to all for the help!
Darkhlmt
