I have FreeNAS-8.0.4-RELEASE-p1-x86 (11059) trying to upgrade to 9.2.1.5. I have confirmed that I have a good 9.2.1.5 x86 iso by checking the SHA256 number. I burned the CD disk using Disk-at-once.
I follow the direction from the Upgrading FreeNas guide from doc.freenas.org.
When I confirm to upgrade I get this error:
-install_worker2.sh: ERROR: could not load the avatar.conf file from the destination directory (/var/tmp/data/etc)
-The FreeNAS upgrade on ada3 has failed. Press any key to continue...
I looked up the directory on the machine and /var/tmp exist but there is no sub-directory data or etc.
How do I fix this problem?
Thanks
Computer Specs:
Dell GX280
Intel Pentium 4 2.8 GHz
RAM 4 GB DDR2
SAMSUNG CD-ROM SC-148A B403 is IDE
40 GB Western Digital SATA Hard Drive <- FreeNAS 8.0.4 installed; ada3
Fasttrak TX4310 PCI Raid Card
- 2 Seagate 1TB SATA hard drives in Raid 1(same model number); ada0 and ada2
Thanks
Computer Specs:
Dell GX280
RAM 4 GB DDR2
