scurrier
- Jan 2, 2014
I'm setting up OpenVPN on my tester FreeNAS box. I am at a stage where I need to create a pkcs12 certificate for use on my android phone. So I used the command line
It seems to work normally and asks me to type in my password to protect the file until importing it. But after I type the password twice, it goes all crazy and gives me a bunch of garbage output. See the picture below (deleted 1/26/2014).
A similar thing happened when I was initially using ssh via putty.
Any ideas on what this might be? openssl is a built in FreeNAS command.
openssl pkcs12 -export -in sdcnexus5.crt -inkey sdcnexus5.key -certfile ca.crt
