OMG! A funtioning SATA drive with HOW MANY Power On Hours?
BigDave
FreeNAS Enthusiast
These drives (smart tests shown below) are part of a test platform contained in my new CSE-836 chassis build.
I purchased 16 used/refurbished drives (40GB) for <$3 each for the intended purpose of testing the backplane.
I just recently set up SMART testing a couple of weeks ago and logged in to SSH when the forum went down
around lunch time today (I was bored). I was shocked to see some of the drives have a huge number for atribute #9
I'm interested to see the Brand Names/Model Numbers that will surface in the responses,
come on, dig out those oldies but goodies!
Can anyone beat my 6 MILLION hours?
You must run a passed SMART test (long or short) in order to have bragging rights. Let's have some fun! Here's mine...
[root@brookhollow] ~# smartctl -a /dev/da7
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:  SAMSUNG SP0411C
Serial Number:  S048J20Y754240
Firmware Version: UU100-05
User Capacity:  40,020,664,320 bytes [40.0 GB]
Sector Size:  512 bytes logical/physical
Device is:  Not in smartctl database [for details use: -P showall]
ATA Version is:  ATA/ATAPI-7 T13/1532D revision 0
Local Time is:  Fri Nov 11 11:59:07 2016 CST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
  was completed without error.
Self-test execution status:  (  0) The previous self-test routine completed
  been run.
data collection:  ( 1500) seconds.
capabilities:  (0x5b) SMART execute Offline immediate.
  command.
  Self-test supported.
SMART capabilities:  (0x0003) Saves SMART data before entering
  power-saving mode.
Error logging capability:  (0x01) Error logging supported.
  No General Purpose Logging support.
Short self-test routine
recommended polling time:  (  1) minutes.
Extended self-test routine
recommended polling time:  (  25) minutes.
ID# ATTRIBUTE_NAME  FLAG  VALUE WORST THRESH TYPE  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate  0x000f  100  100  051  Pre-fail  Always  -  0
  3 Spin_Up_Time  0x0007  100  100  025  Pre-fail  Always  -  4800
  4 Start_Stop_Count  0x0032  100  100  000  Old_age  Always  -  852
  5 Reallocated_Sector_Ct  0x0033  100  100  011  Pre-fail  Always  -  0
  7 Seek_Error_Rate  0x000f  100  100  051  Pre-fail  Always  -  0
  8 Seek_Time_Performance  0x0025  100  100  015  Pre-fail  Offline  -  0
  9 Power_On_Hours  0x0032  093  093  000  Old_age  Always  -  4543413
 10 Spin_Retry_Count  0x0033  100  100  051  Pre-fail  Always  -  0
 11 Calibration_Retry_Count 0x0012  100  100  000  Old_age  Always  -  0
 12 Power_Cycle_Count  0x0032  100  100  000  Old_age  Always  -  487
194 Temperature_Celsius  0x0022  133  088  000  Old_age  Always  -  35
195 Hardware_ECC_Recovered  0x001a  100  100  000  Old_age  Always  -  2112314
196 Reallocated_Event_Count 0x0032  100  100  000  Old_age  Always  -  0
197 Current_Pending_Sector  0x0012  100  100  000  Old_age  Always  -  0
198 Offline_Uncorrectable  0x0030  100  100  000  Old_age  Offline  -  0
199 UDMA_CRC_Error_Count  0x003e  200  200  000  Old_age  Always  -  0
200 Multi_Zone_Error_Rate  0x000a  100  100  051  Old_age  Always  -  0
201 Soft_Read_Error_Rate  0x000a  100  100  051  Old_age  Always  -  0
(edit: content removed for brevity)
Num  Test_Description  Status  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline  Completed without error  00%  37851  -
# 2  Extended offline  Completed without error  00%  37762  -
# 3  Short offline  Completed without error  00%  37578  -
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
  1  0  0  Not_testing
  2  0  0  Not_testing
  3  0  0  Not_testing
  4  0  0  Not_testing
  5  0  0  Not_testing
Here is the other Samsung drive
[root@brookhollow] ~# smartctl -a /dev/da8
Device Model:  SAMSUNG SP0411C/R
Serial Number:  S0DAJ1IL314296
Local Time is:  Fri Nov 11 12:03:43 2016 CST
  been run.
  command.
  power-saving mode.
  3 Spin_Up_Time  0x0007  100  100  025  Pre-fail  Always  -  4544
  4 Start_Stop_Count  0x0032  100  100  000  Old_age  Always  -  199
  9 Power_On_Hours  0x0032  094  094  000  Old_age  Always  -  4212267
 11 Calibration_Retry_Count 0x0012  100  100  000  Old_age  Always  -  17
 12 Power_Cycle_Count  0x0032  100  100  000  Old_age  Always  -  184
194 Temperature_Celsius  0x0022  139  088  000  Old_age  Always  -  33
195 Hardware_ECC_Recovered  0x001a  100  100  000  Old_age  Always  -  693423
Oopsie, We have to raise the benchmark! Check this out...
[root@brookhollow] ~# smartctl -a /dev/da12
Serial Number:  S048J10X966410
Local Time is:  Fri Nov 11 12:21:25 2016 CST
  been run.
  command.
  power-saving mode.
  1 Raw_Read_Error_Rate  0x000f  098  097  051  Pre-fail  Always  -  1740
  3 Spin_Up_Time  0x0007  100  100  025  Pre-fail  Always  -  4864
  4 Start_Stop_Count  0x0032  100  100  000  Old_age  Always  -  249
  9 Power_On_Hours  0x0032  090  090  000  Old_age  Always  -  6541445
 11 Calibration_Retry_Count 0x0012  100  100  000  Old_age  Always  -  2
194 Temperature_Celsius  0x0022  127  088  000  Old_age  Always  -  37
195 Hardware_ECC_Recovered  0x001a  100  100  000  Old_age  Always  -  15565615
Mlovelace
Something is very wrong with those smart results... There's only 8760 hours in a year. So your 6 million+ hours drive has been in service for more than 685 years o_O
Jailer
Not strong, but bad
Meh, best I can do is 65K hours on an old Seagate. It's currently residing in my pfsense rig. I'm going to run it til it dies. :D
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-RELEASE-p9 amd64] (local build)
Model Family:	 Seagate Barracuda 7200.8
Device Model:	 ST3250823AS
Serial Number:	3ND01VNZ
Firmware Version: 3.01
User Capacity:	250,058,268,160 bytes [250 GB]
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ATA/ATAPI-7 (minor revision not indicated)
Local Time is:	Fri Nov 11 15:34:13 2016 EST
					been run.
data collection:		 (  430) seconds.
					command.
					power-saving mode.
recommended polling time:	  (  84) minutes.
SCT capabilities:			(0x0001)	SCT Status supported.
  1 Raw_Read_Error_Rate	 0x000f   067   045   006	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0003   098   097   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   093   093   020	Old_age   Always	   -	   7174
  5 Reallocated_Sector_Ct   0x0033   100   100   036	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x000f   079   060   030	Pre-fail  Always	   -	   87294642
  9 Power_On_Hours		  0x0032   026   026   000	Old_age   Always	   -	   65517
10 Spin_Retry_Count		0x0013   100   100   097	Pre-fail  Always	   -	   0
12 Power_Cycle_Count	   0x0032   094   094   020	Old_age   Always	   -	   7021
194 Temperature_Celsius	 0x0022   029   055   000	Old_age   Always	   -	   29 (0 14 0 0 0)
195 Hardware_ECC_Recovered  0x001a   066   045   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0010   100   100   000	Old_age   Offline	  -	   0
200 Multi_Zone_Error_Rate   0x0000   100   253   000	Old_age   Offline	  -	   0
202 Data_Address_Mark_Errs  0x0032   100   253   000	Old_age   Always	   -	   0
SMART Error Log Version: 1
ATA Error Count: 835 (device log contains only the most recent five errors)
	CR = Command Register [HEX]
	FR = Features Register [HEX]
	ER = Error register [HEX]
	ST = Status register [HEX]
Error 835 occurred at disk power-on lifetime: 31001 hours (1291 days + 17 hours)
  ER ST SC SN CL CH DH
  10 51 01 2e 51 1c ed
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  37 00 01 2e 51 1c ed 00	  20:04:23.699  SET NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  27 00 00 2e 51 1c e0 00	  20:04:23.572  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  37 00 00 2e 51 1c ed 00	  20:04:23.572  SET NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  27 00 01 2e 51 1c e0 00	  20:04:21.433  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  37 00 01 2e 51 1c ed 00	  20:04:21.433  SET NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 834 occurred at disk power-on lifetime: 31001 hours (1291 days + 17 hours)
  37 00 01 2e 51 1c ed 00	  20:04:18.465  SET NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  27 00 00 2e 51 1c e0 00	  20:04:18.464  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  37 00 00 2e 51 1c ed 00	  20:04:18.464  SET NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  27 00 01 6f 59 1c e0 00	  20:04:21.433  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  29 00 01 6f 59 1c e0 00	  20:04:21.433  READ MULTIPLE EXT
Error 833 occurred at disk power-on lifetime: 30994 hours (1291 days + 10 hours)
  37 00 01 2e 51 1c ed 00	  12:54:15.930  SET NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  27 00 00 2e 51 1c e0 00	  12:54:15.930  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  37 00 00 2e 51 1c ed 00	  12:54:20.716  SET NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  27 00 01 2e 51 1c e0 00	  12:54:20.716  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  37 00 01 2e 51 1c ed 00	  12:54:20.589  SET NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 832 occurred at disk power-on lifetime: 30994 hours (1291 days + 10 hours)
  37 00 00 2e 51 1c ed 00	  12:54:15.930  SET NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  27 00 01 6f 59 1c e0 00	  12:54:15.483  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  29 00 01 6f 59 1c e0 00	  12:54:15.483  READ MULTIPLE EXT
Error 831 occurred at disk power-on lifetime: 30994 hours (1291 days + 10 hours)
  37 00 01 2e 51 1c ed 00	  12:50:41.622  SET NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  27 00 00 2e 51 1c e0 00	  12:50:41.622  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  37 00 00 2e 51 1c ed 00	  12:50:39.483  SET NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  27 00 01 2e 51 1c e0 00	  12:50:39.483  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  37 00 01 2e 51 1c ed 00	  12:50:39.357  SET NATIVE MAX ADDRESS EXT [OBS-ACS-3]
# 1  Short offline	   Completed without error	   00%	 65278		 -
# 2  Extended offline	Completed without error	   00%	 63303		 -
# 3  Short offline	   Completed without error	   00%	 63301		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
BigDave
FreeNAS Enthusiast
Dude, you are such a buzzkill, could you have just waited until some of these geeks went through the trouble of
digging through some boxes in the basement before showing us how smart you are? I bet your really fun at a party...;)
Spearfoot
He of the long foot
I'm guessing that Relativistic Time Dilation is involved... Perhaps the drives were accelerated to near the speed-of-light? :smile:
joeschmuck
Old Man
Even before I got to the second posting I was thinking that the numbers had to have been edited just a bit. Either you're late or too early for April 1st.
BigDave
FreeNAS Enthusiast
Perhaps the figure stated is minutes, instead of hours?
6541445 min. / 60 = 109,024 hrs. / 8760 hrs per year = 12.45 years ???
"Even before I got to the second posting I was thinking that the numbers had to have been edited just a bit. Either you're late or too early for April 1st."
No editing here, no kidding, I'll post a screen shot. Stand by...
Makes sense for 40GB drives. That would also make them very early SATA drives, presumably still using PATA to SATA bridges and PATA drive controllers.
joeschmuck
Old Man
Here is my screen capture. Then WD Reds sure last a long time ;)
BigDave
FreeNAS Enthusiast
Do I sense some skepticism Mark?
These drives were first available (according to my research) in April, 2005.
The #9 attribute almost certainly has to be minutes. I'm gonna shut down the server later and see if I can pull the
drive and post a pic of the label, I'm curious to see the date of manufacture now.
Mlovelace
This is the oldest set I've got in service on my home NAS:
[root@homenas] ~# smartctl -x /dev/da1
Vendor:			   HP
Product:			  MM1000FBFVR
Revision:			 HPD5
User Capacity:		1,000,204,886,016 bytes [1.00 TB]
Logical block size:   512 bytes
Rotation Rate:		7200 rpm
Form Factor:		  2.5 inches
Logical Unit id:	  0x5000c50042139e27
Serial number:		9XG29MFZ00009248ZMU7
Device type:		  disk
Transport protocol:   SAS (SPL-3)
Local Time is:		Fri Nov 11 16:46:51 2016 MST
SMART support is:	 Available - device has SMART capability.
Temperature Warning:  Enabled
Read Cache is:		Enabled
Writeback Cache is:   Disabled
SMART Health Status: OK
Current Drive Temperature:	 38 C
Drive Trip Temperature:		65 C
Manufactured in week 25 of year 2012
Specified cycle count over device lifetime:  10000
Accumulated start-stop cycles:  103
Specified load-unload count over device lifetime:  300000
Accumulated load-unload cycles:  103
Elements in grown defect list: 5
Vendor (Seagate) cache information
  Blocks sent to initiator = 569127595
  Blocks received from initiator = 2633690060
  Blocks read from cache and sent to initiator = 1881027254
  Number of read and write commands whose size <= segment size = 181284019
  Number of read and write commands whose size > segment size = 0
Vendor (Seagate/Hitachi) factory information
  number of hours powered up = 25024.80
  number of minutes until next internal SMART test = 42
Error counter log:
		   Errors Corrected by		   Total   Correction	 Gigabytes	Total
			   ECC		  rereads/	errors   algorithm	  processed	uncorrected
		   fast | delayed   rewrites  corrected  invocations   [10^9 bytes]  errors
read:		  0		0		 0  1381162656		  0	 216929.544		   0
write:		 0		0		 0		 0		  0	   7979.542		   0
Non-medium error count:	   99
SMART Self-test log
Num  Test			  Status				 segment  LifeTime  LBA_first_err [SK ASC ASQ]
	 Description							  number   (hours)
# 1  Background short  Completed				   -   24989				 - [-   -	-]
# 2  Background long   Completed				   -   24963				 - [-   -	-]
# 3  Background short  Completed				   -   24917				 - [-   -	-]
# 4  Background short  Completed				   -   24844				 - [-   -	-]
# 5  Background long   Completed				   -   24794				 - [-   -	-]
# 6  Background short  Completed				   -   24772				 - [-   -	-]
# 7  Background short  Completed				   -   24748				 - [-   -	-]
# 8  Background long   Completed				   -   24722				 - [-   -	-]
# 9  Background short  Completed				   -   24675				 - [-   -	-]
#10  Background short  Completed				   -   24602				 - [-   -	-]
#11  Background long   Completed				   -   24553				 - [-   -	-]
#12  Background short  Completed				   -   24531				 - [-   -	-]
#13  Background short  Completed				   -   24458				 - [-   -	-]
#14  Background short  Completed				   -   24386				 - [-   -	-]
#15  Background long   Completed				   -   24384				 - [-   -	-]
#16  Background short  Completed				   -   24313				 - [-   -	-]
#17  Background short  Completed				   -   24240				 - [-   -	-]
#18  Background long   Completed				   -   24214				 - [-   -	-]
#19  Background short  Completed				   -   24168				 - [-   -	-]
#20  Background short  Completed				   -   24095				 - [-   -	-]
Long (extended) Self Test duration: 12000 seconds [200.0 minutes]
Background scan results log
  Status: waiting until BMS interval timer expires
	Accumulated power on time, hours:minutes 25024:48 [1501488 minutes]
	Number of background scans performed: 972,  scan progress: 0.00%
	Number of background medium scans performed: 972
Protocol Specific port log page for SAS SSP
relative target port id = 1
  generation code = 10
  number of phys = 1
  phy identifier = 0
	attached device type: SAS or SATA device
	attached reason: unknown
	reason: loss of dword synchronization
	negotiated logical link rate: phy enabled; 6 Gbps
	attached initiator port: ssp=1 stp=1 smp=1
	attached target port: ssp=0 stp=0 smp=0
	SAS address = 0x5000c50042139e25
	attached SAS address = 0x544a84201faf4e02
	attached phy identifier = 3
	Invalid DWORD count = 0
	Running disparity error count = 0
	Loss of DWORD synchronization = 20
	Phy reset problem = 0
	Phy event descriptors:
	 Invalid word count: 0
	 Running disparity error count: 0
	 Loss of dword synchronization count: 20
	 Phy reset problem count: 0
relative target port id = 2
  number of phys = 1
  phy identifier = 1
	attached device type: no device attached
	reason: unknown
	negotiated logical link rate: phy enabled; 1.5 Gbps
	attached initiator port: ssp=0 stp=0 smp=0
	SAS address = 0x5000c50042139e26
	attached SAS address = 0x0
	attached phy identifier = 0
	Loss of DWORD synchronization = 0
	 Loss of dword synchronization count: 0
Edit: number of hours powered up = 25024.80 (if you didn't want to dig through the SAS smart info)
BigDave
FreeNAS Enthusiast
It's confirmed! the two results below show time stamp and the difference in the Power On Hours results
show that this Samsung Spinpoint model shows minutes, NOT hours. I guess I don't have to call the Guinness
Book people about a possible world record :p
Local Time is:  Fri Nov 11 18:41:13 2016 CST
  been run.
  command.
  power-saving mode.
  9 Power_On_Hours  0x0032  090  090  000  Old_age  Always  -  6542159
194 Temperature_Celsius  0x0022  124  088  000  Old_age  Always  -  38
ATA Error Count: 404 (device log contains only the most recent five errors)
Error 404 occurred at disk power-on lifetime: 53936 hours (2247 days + 8 hours)
  04 51 07 00 08 00 e0
  f5 ff 07 00 08 00 e0 00  00:00:07.125  SECURITY FREEZE LOCK
  ec ff 08 00 08 00 e0 00  00:00:07.125  IDENTIFY DEVICE
  c6 ff 08 00 00 00 e0 00  00:00:06.625  SET MULTIPLE MODE
  10 ff 01 82 3e 00 e0 00  00:00:06.625  RECALIBRATE [OBS-4]
  91 ff 3f 00 00 00 af 00  00:00:06.625  INITIALIZE DEVICE PARAMETERS [OBS-6]
Error 403 occurred at disk power-on lifetime: 53936 hours (2247 days + 8 hours)
  f5 ff 07 00 08 00 e0 00  00:00:07.063  SECURITY FREEZE LOCK
  ec ff 08 00 08 00 e0 00  00:00:07.000  IDENTIFY DEVICE
  c6 ff 08 00 00 00 e0 00  00:00:06.688  SET MULTIPLE MODE
  10 ff 01 82 3e 00 e0 00  00:00:06.688  RECALIBRATE [OBS-4]
  91 ff 3f 00 00 00 af 00  00:00:06.688  INITIALIZE DEVICE PARAMETERS [OBS-6]
Error 402 occurred at disk power-on lifetime: 53936 hours (2247 days + 8 hours)
  04 51 00 01 10 5a a0
  b1 c1 00 01 10 5a a0 00  00:00:26.688  DEVICE CONFIGURATION FREEZE LOCK [OBS-ACS-3]
  e3 03 00 01 10 5a a0 00  00:00:26.688  IDLE
  91 03 3f 01 10 5a ef 00  00:00:26.688  INITIALIZE DEVICE PARAMETERS [OBS-6]
  c6 03 10 01 a5 5a a0 00  00:00:26.688  SET MULTIPLE MODE
  ef 03 45 01 a5 5a a0 00  00:00:26.688  SET FEATURES [Set transfer mode]
Error 401 occurred at disk power-on lifetime: 53936 hours (2247 days + 8 hours)
  04 51 01 00 00 00 00
  b1 c2 01 00 00 00 00 00  00:01:47.750  DEVICE CONFIGURATION IDENTIFY [OBS-ACS-3]
  ec 00 01 00 00 00 00 00  00:01:47.750  IDENTIFY DEVICE
  b0 d0 00 00 4f c2 00 00  00:01:47.563  SMART READ DATA
  ec 00 01 00 00 00 00 00  00:01:47.500  IDENTIFY DEVICE
Error 400 occurred at disk power-on lifetime: 53936 hours (2247 days + 8 hours)
  b1 c1 00 01 10 5a a0 00  00:01:28.688  DEVICE CONFIGURATION FREEZE LOCK [OBS-ACS-3]
  e3 03 00 01 10 5a a0 00  00:01:28.688  IDLE
  91 03 3f 01 10 5a ef 00  00:01:28.688  INITIALIZE DEVICE PARAMETERS [OBS-6]
  c6 03 10 01 a5 5a a0 00  00:01:28.688  SET MULTIPLE MODE
  ef 03 45 01 a5 5a a0 00  00:01:28.688  SET FEATURES [Set transfer mode]
# 1  Short offline  Completed without error  00%  54501  -
# 2  Extended offline  Completed without error  00%  54411  -
# 3  Short offline  Completed without error  00%  54227  -
# 4  Extended offline  Completed without error  00%  2  -
  1  0  0  Not_testing
  2  0  0  Not_testing
  3  0  0  Not_testing
  4  0  0  Not_testing
  5  0  0  Not_testing
Local Time is:  Fri Nov 11 18:42:05 2016 CST
  been run.
  command.
  power-saving mode.
  9 Power_On_Hours  0x0032  090  090  000  Old_age  Always  -  6542160
  1  0  0  Not_testing
  2  0  0  Not_testing
  3  0  0  Not_testing
  4  0  0  Not_testing
  5  0  0  Not_testing
Arwen
I had a 72GB SCSI drive in a Sun server that was in service 8.5 years. Finally had to take it
down so I could replace the old data disk that failed years ago. Then use it to mirror the OS.
Edit: Forgot to mention, it was a Seagate drive... Back then they made solid SCSI & Fibre
Channel drives.
joeschmuck
Old Man
Dave, when are you going to run the SMART Long test on that drive? Love to see if it passes. But that is impressive, over 12 years of power on time. Was this drive actually an active drive or just something in a standby capacity, sitting there and waiting? Do you know if it was spinning the entire time it had power applied as well? Just curious.
BigDave
FreeNAS Enthusiast
I know nothing of the drive's use history as it was purchased from Microcenter as a refurbished unit for less than $3.00
I wanted to test my new 16 bay SuperMicro chassis' backplane, so I
just bought 16 SATA hard drives and threw them in. I knew going in that the drives were not going to have any value to me, other than making sure the backplane I switched out was fully functional. The 16 drives have served their purpose and now I'm just playing with them.
I will perform a long SMART test in a while and post the output as soon as I complete a few "honey do" tasks for the better half.
BigDave
FreeNAS Enthusiast
This is odd, look at the latest smart tests and the hours indicated by THAT! 5433 wtf!
Local Time is:  Sat Nov 12 19:48:45 2016 CST
  been run.
  command.
  power-saving mode.
  1 Raw_Read_Error_Rate  0x000f  099  097  051  Pre-fail  Always  -  1740
  9 Power_On_Hours  0x0032  090  090  000  Old_age  Always  -  6544990
195 Hardware_ECC_Recovered  0x001a  100  100  000  Old_age  Always  -  18078354
# 1  Short offline  Completed without error  00%  54533  -
# 2  Extended offline  Completed without error  00%  54533  -
# 3  Short offline  Completed without error  00%  54501  -
# 4  Extended offline  Completed without error  00%  54411  -
# 5  Short offline  Completed without error  00%  54227  -
# 6  Extended offline  Completed without error  00%  2  -
  1  0  0  Not_testing
  2  0  0  Not_testing
  3  0  0  Not_testing
  4  0  0  Not_testing
  5  0  0  Not_testing
joeschmuck
Old Man
So now it's saying 6.2 years? Weird!
Did you ever pull the drive to see when it was manufactured?
